Like Tree1Likes
Old 01-25-2013, 09:37 PM   #8641
kewdawg's Avatar
Originally Posted by JustWill75 View Post
All joke aside, I rather keep replacing blades then a dogbone or a spool. At $3.00 for a bag of blades, that design makes sense to me....
I said the same thing to someone! I broke a couple of spool plastic outdrives on a 417, last year and it didn't really bother me because I knew they were cheap to replace and it absorbed a lot of the impact that would have probably broken more parts if the outdrives were metal, like the c-hub and steering knuckle). The TC6's plastic spool outdrives and CVD blades were a selling point for me. I knew I wouldn't spend a lot of money replacing front drivetrain parts - and I haven't.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-25-2013, 09:44 PM   #8642
El Nitro's Avatar
Originally Posted by jha07 View Post
I switched to a slipper spool for this exact reason. Handles just like a regular spool, but has some give if you crash. I haven't broken a blade since I put it in, except one time when I tore the C-hub and steering Knuckle off, but that was a very bad high speed crash.
Thanks for the replies Guys.
What slipper spool are you using?
Cheers
El Nitro is offline   Reply With Quote
Old 01-25-2013, 09:54 PM   #8643
bhambrent's Avatar
Cheers
I'v been using the tc6 slipper spool in my TC6.1 WC. prat#31337
http://www3.towerhobbies.com/cgi-bin...?&I=LXAGZE&P=7
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 01-25-2013, 09:58 PM   #8644
El Nitro's Avatar
Originally Posted by evochick View Post
you need to pick up a set of reflex alloy outdrives, they stop the blade from wearing as much and breaking in an accident, since putting these in i have only ever lost 1 blade (but it was a big hit and broke some ballcups as well)
For a fast flowing track i can only suggest something like ear putty in a front gear diff to take some give while still being very locked.
Thanks,
I have done various google searches but nothing shown up.
Where did you buy the alloy spool outdrives.
Cheers
Old 01-25-2013, 10:03 PM   #8645
bhambrent's Avatar
http://www.reflexracing.net/RSD-AE-T...pc_p_1126.html
Old 01-25-2013, 10:07 PM   #8646
RSD does aluminum out drives.
RSD Spec TC6.1, Tekin RS, MMM, Sav÷x, Sorex.
Steve89 is offline   Reply With Quote
Old 01-25-2013, 10:08 PM   #8647
El Nitro's Avatar
F%#@&^$$ I didn't know they made a slipper spool for the TC6.1WC.
Whats the difference between a slipper spool and a ball diff.
It appears the only difference in the parts photos is no ball bearings in the slipper spool.
Cheers
Old 01-25-2013, 10:13 PM   #8648
bhambrent's Avatar
You do not use the ball's or diff lube. Just lock it down and go.
Old 01-25-2013, 10:33 PM   #8649
El Nitro's Avatar
Steve89 RSD does aluminum out drives.
Thanks for the quick replies Guys,
So you buy two of these, but only use the aluminium outdrives, or can you use the spool as well with the TC6.1.
Cheers
Old 01-25-2013, 11:28 PM   #8650
bigtez's Avatar
I have the TC6 Slipper Spool. Just have to make sure you build them with the thrust washer and bearings in them or they will unwind themselves, as I found out through experience.
500k or 1mil would suit EPR better than 300k. I feel like my car lacks a bit of drive out of some corners and definitely has way to much steering.
bigtez is online now   Reply With Quote
Old 01-26-2013, 12:06 AM   #8651
Can anyone tell me what ball cups to use on the suspension?? Also has anyone got a better bumper that works on the TC6.1??
Old 01-26-2013, 02:06 AM   #8652
El Nitro's Avatar
Anyone know the difference between the TC6 Diff (ball) and the TC6 Slipper Spool.
Theres a photo of each on Towers website, but they've used the same parts photos.
The Spool say it comes with balls.
The diff doesn't say exactly what parts are included.
The Diff is $54 and the spool is $35. So what parts are different.
TC6 Diff (ball)
http://www3.towerhobbies.com/cgi-bin...?&I=LXAGZD&P=7
TC6 Slipper Spool
Team Associated TC6 Thread-tc6-diff-ball-.jpg   Team Associated TC6 Thread-tc6-slipper-spool.jpg
Old 01-26-2013, 02:29 AM   #8653
The main difference is the rings that retain the balls I believe... One actually acts like a diff (ball) where as the slipper spool acts like a spool but slips under load/hits so you don't break as much in the front end.
Old 01-26-2013, 02:57 AM   #8654
bigtez's Avatar
The balls and metal rings are replaced with soft 'pads' (part no. 31173). Everything else is the same.
Old 01-26-2013, 03:43 AM   #8655
El Nitro's Avatar
bigtez The balls and metal rings are replaced with soft 'pads' (part no. 31173). Everything else is the same.
Ok, Thanks for the info.
Surprised there is a $20 price difference for what is basically the same parts.
The slipper says it comes with bearings and balls, perhaps that's incorrect.
Anyway, that gives me four options to try.
Thanks all.
Cheers
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Triple A
