Like Tree1Likes
Old 01-21-2013, 02:26 PM   #8626
98NYFINESTVETTE's Avatar
I bought a few gears today. I want to try two different spur gets to see if there would a noticeable difference. I am using a 96 spur, I bought a few different pinion gears that will equal the same ratio as with the 75 spur. I plan on doing some timed sprints to compare to which will work best.
I am sure some have tried this. Any feedback would be helpful.
SC10 4x4, HPI Baja 5sc, LOSI 5ive T, XO-1, Airplanes & Boats.
We need an Off Road Track in Central Jersey (1/10 & 1/5). When not traveling the country racing in the NMCA, I race off road and on road RC with my son - PRICELESS.
South River Hobby & Bike to the rescue (732) 387-2828.
98NYFINESTVETTE is offline   Reply With Quote
Old 01-21-2013, 05:09 PM   #8627
rangerjkb's Avatar
Trader Rating: 36 (100%+)
Send a message via MSN to rangerjkb
Originally Posted by TonyD. View Post
DO you guys use the sway bars?
Yes, on the 6.1 & 6.1WC I've used 1.1 Yellow front and 0.9 White rear sway bars on carpet tracks. When I ran TC6 on medium traction asphalt track, I removed sway bars and the car was incredibly hooked up. Something to possibly play with when practicing with setup.
Jason Burks
Murfdogg Products~Psycho Cells Racing~Hal's Hobby Warehouse~Avid RC~Kal-Gard~VP Powermaster
rangerjkb is offline   Reply With Quote
Old 01-22-2013, 12:34 AM   #8628
kewdawg's Avatar
Yes. Yellow and white for low to medium bite, red and blue medium-high to high bite.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-22-2013, 10:52 PM   #8629
Oops, double!
Mikes Hobby Shop--> mikeshobbyshop.com
-Viper-RC Solutions-
Team Tree Top!
Damon_English is offline   Reply With Quote
Old 01-22-2013, 10:53 PM   #8630
Hello all,
I am selling my almost new worlds kit. Please pm me for inquires!
Team Tree Top!
Old 01-23-2013, 08:32 PM   #8631
evochick's Avatar
Has anyone else tried Rick Howarts 2B roll mount and arm positions from the Roar Nats ?
I have only just moved from 21.5 Blinky to Mod, and tried them for the first time with the WC chassis at our Summernats event and loved it, you wouldnt think the car would work but it does,
I didnt have any boost set while i am learning the extra speed but the corner speed was great, and the car very easy to drive.
If you havnt tried it, give it a shot.
If you read this Rick thanks for the setup
Video of me driving like a mod novice here in the A final (dark pink/purple car the camera follows)
http://youtu.be/-jYbE8zm6pk
Beth
UnRetired
evochick is offline   Reply With Quote
Old 01-24-2013, 06:30 AM   #8632
Beth
The car was handling great.
Old 01-25-2013, 04:08 PM   #8633
El Nitro's Avatar
What is the recommended diff oil for a TC6.1WC front diff.
Im having problems with the front spool outdrives. The plastic blades are too thin and break near the hole where the CVD dogbones are attached, then they screw themselves into the plastic outdrives. Very bad design IMHO.
So what wt/cst Silicone diff oils have you tried with a front diff. I race on and outdoor, fast, medium grip and bumpy asphalt track.
Cheers
El Nitro is offline   Reply With Quote
Old 01-25-2013, 04:41 PM   #8634
evochick's Avatar
you need to pick up a set of reflex alloy outdrives, they stop the blade from wearing as much and breaking in an accident, since putting these in i have only ever lost 1 blade (but it was a big hit and broke some ballcups as well)
For a fast flowing track i can only suggest something like ear putty in a front gear diff to take some give while still being very locked.
UnRetired
Old 01-25-2013, 04:59 PM   #8635
JustWill75's Avatar
Send a message via AIM to JustWill75
Cheers
I hate to be a smart a$$, but stop hitting stuff bro.
All joke aside, I rather keep replacing blades then a dogbone or a spool. At $3.00 for a bag of blades, that design makes sense to me....
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 01-25-2013, 06:21 PM   #8636
bigtez's Avatar
Cheers
I am running 300k which is about as loose as you would want to go at EPR. If you like, I can loan you my front diff to give you an idea of what it's like. I will be running a slipper spool this Friday, so i won't be needing it.
bigtez is offline   Reply With Quote
Old 01-25-2013, 07:28 PM   #8637
El Nitro's Avatar
Thanks Terry,
Ill try your diff on Friday.
Im about to order a diff so will order some 300000. (maybe 500000 too)
One of the experienced guys at EPR recommended 500000, but thought that may be a bit much for an EP diff. Just guessing though as the Mugens run 300000 in their front diff.
You say 300000 is as loose as you would recommend. Would 500000 be better, have you tried it.
What slipper spool are you using.
See you Friday.
Cheers
Old 01-25-2013, 09:10 PM   #8638
Cheers
I switched to a slipper spool for this exact reason. Handles just like a regular spool, but has some give if you crash. I haven't broken a blade since I put it in, except one time when I tore the C-hub and steering Knuckle off, but that was a very bad high speed crash.
jha07 is offline   Reply With Quote
Old 01-25-2013, 09:12 PM   #8639
kewdawg's Avatar
Thanks Terry,
See you Friday.
Cheers
Those numbers are about right. Actually, racers have started using 500,000 to1,000,000
Wt. oil for carpet racing. Going to do some testing with the million front diff next week. Stay tuned. I have a really good low-grip carpet set-up with a spool, that, I'm going to post shortly.
Quinn Moon
Old 01-25-2013, 09:15 PM   #8640
kewdawg's Avatar
Quinn Moon
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
