Like Tree1Likes
Old 01-03-2013, 11:03 PM   #8521
Crashmaster's Avatar
Originally Posted by wtcc View Post
If a ball/gear diff in front is slower, a spool will be the better solution in front. That is why I only have the thin oils, ranging from 1000cst, 3000cst, 5000cst & 10000cst. 1000cst in the rear geardiff will feel like an Asso balldiff in standard setting. You can also use your shock oils. Don't use the 10000cst for the rear axle!
I would take the 30wt out and add instead 45wt, 50wt and 55wt.
I use the whole line of ReflexRacing springs which are made for the TC6. There mostly the springs between 13.5 - 15.5. For the beginning you can use the Asso springs, take green, silver and blue. With these you can adapt the car good on all tracks.
Thanks for that WTCC I'll go with that to begin with!
I don't suppose anyone can point me towards some shims to remove some slop on the hingepins?
Dan
Crashmaster is offline   Reply With Quote
Old 01-03-2013, 11:07 PM   #8522
Shims for Fore and aft movement?
Edit: If for above movement, I use the below link to help tighten, as well as fine tune, arm position.
http://www.amainhobbies.com/product_...3x5mm-Shim-Set
Mikes Hobby Shop--> mikeshobbyshop.com
-Viper-RC Solutions-
Team Tree Top!
Damon_English is offline   Reply With Quote
Old 01-04-2013, 01:28 AM   #8523
I run 17.5t blinky class in the LRP-HPI-Challenge and tried a lot of bodies. In the end one Mazda outperformed all other shells. It is the HPI 66813LW - EU Moore-Speed Mazda 6 MPS (190mm) - Lightweight. Even outdoor this body will be around one tenth faster as the LTC-R without beeing aggressive or loose. So I can highly recommend this body for the TC6.1WC. One body which is on the same level without a lightweight version is the 61733 - SUBARU IMPREZA TYPE C KAROSSERIE (190MM).
Yo Man!
I send some days ago email to you
:P
Now tell me, your body touch bumper at front or is moved forward, how much?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-04-2013, 06:54 AM   #8524
Jones Auto's Avatar
Does anyone sell the Grid Racing belt tensioner in the US?
Jones Auto is offline   Reply With Quote
Old 01-04-2013, 02:25 PM   #8525
wtcc's Avatar
Originally Posted by M.Abramowicz View Post
Yo Man!
My friend, I know and I answered, that you can have the aluminium armmounts if you want them! Please check your mail box
I run the car very short in front = 3mm wheelbase in front! So I cut away around two millimeters of the bumper and make the holes for the body posts where the wheel meets the front arc. In other words I cut the front arc like it is lined on the body and just have to look where the rear wheels are.
That means that I run the body a little rearward (not forward)...
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 01-04-2013, 07:34 PM   #8526
Trader Rating: 68 (100%+)
What would I need to run the dcj on a tc6 not the .1 just got the car thanks
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 01-04-2013, 08:45 PM   #8527
kewdawg's Avatar
Default "Bladder Control"
Guys, other than RSD, what other brand of bladders will fit the TC6 shocks???
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-05-2013, 01:15 PM   #8528
wtcc's Avatar
Buy the #31360 TC6.1 Steering Blocks, the #31358 TC6.1 Caster Blocks, four 5x10x4 bearings and the #31370 TC6.1 Axle Crush Tube. Then buy all the DCJ, pins and hexes from RSD...
I think I heard that Tamiya bladders fit as well, but that was two years ago...
Today the Zeppin C-Hubs arrived from Finnland:
Good manufactoring quality as far as it is visible. They look a little weak. We will see if they can take some hits.
Unfortunately the UPS-man came late so I couldn't test them today. So you guys will have to wait at least one week for an inside report. Before I will post some more pics with the C-Hubs on the car and a feedback how they fit (slop, DCJ-fitting, and so on...).
AE / Reedy / RSD
Old 01-05-2013, 02:27 PM   #8529
KC10Chief's Avatar
Where did you get those from?
KC10Chief is offline   Reply With Quote
Old 01-05-2013, 02:31 PM   #8530
Potoczak's Avatar
Trader Rating: 109 (100%+)
Zeppinracing.com sells them.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-05-2013, 02:56 PM   #8531
ho ho ho
new custom solid axle by my friend
with bd5 roche steel cups for better fit for spec-r bd5 axles
:P
Michal Abramowicz
Old 01-05-2013, 03:38 PM   #8532
wtcc's Avatar
I bought them here: http://www.eurorc.com/product/2650/z...eg-lr-for-tc61
ho ho ho
:P
Attachment 1012866
Awesome, dude!!!
AE / Reedy / RSD
Old 01-05-2013, 05:49 PM   #8533
KC10Chief's Avatar
It doesn't look like I am able to order anything from that site.
Old 01-05-2013, 06:37 PM   #8534
2canSAM's Avatar
Trader Rating: 243 (100%+)
I just picked up a T6 roller in a trade and it has the VCS2 shocks on it. I attempted to rebuild them last night and it was rather messy Does it mess up the top foam pieces if they get any oil on them?
"Who else has DIED for you?"
Selling Terms: Shipping to confirmed addresses only, low-ballers will be ignored, and I reserve the right to refuse any offer.
2canSAM is offline   Reply With Quote
Old 01-05-2013, 07:37 PM   #8535
G4ZZ4's Avatar
Hi mate give these guys a try http://www.rc-mushroom.com/ really good service
cheers Garry
YOKOMO BD7, 21.5 boosted M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
