Like Tree1Likes
Old 12-06-2012, 07:24 AM   #8221
DARKSIDE's Avatar
wish I had that type of work area...maybe I would work on my stuff
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
'17 USVTA Summer Slam @ The Gate
July 28th-30th,2017
DARKSIDE is offline   Reply With Quote
Old 12-06-2012, 07:33 AM   #8222
IndyHobbies.com's Avatar
My son and I are running our TC6 in USGT. We are very happy with the way it drives. The only continous problem we have are the front arm mounts. Most of the time, if we hit anything, even lightly, the front axle pulls out of the arm mounts. Usually ruining the mounting hole so that the mount has to be replaced.
It doesn't seem to happen on my TC5 as much.
Do you guys experience the same thing with your TC6's? Is there something I can do to help prevent that from happening? Its a cheap fix, so I'd rather have that happen then the arm break or worse, but it just pulls out too easy it seems.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 12-06-2012, 07:37 AM   #8223
Jones Auto's Avatar
Im a neat freak. My auto shop is the same way. Heres the far shot.[IMG][/IMG]
Jones Auto is offline   Reply With Quote
Old 12-06-2012, 07:37 AM   #8224
Scottmisfits's Avatar
I just run a longer srew. For whatever shims I use to get the spacing I want, I use a scre thats close to flush in the bulkhead.
Scottmisfits is offline   Reply With Quote
Old 12-06-2012, 07:41 AM   #8225
DARKSIDE's Avatar
RSD makes some blocks that will fix it...but Ive taken the screw and added a little AE locktite. I put the locktite to the screw and let it dry..then put it back together..it still comes loose from time to time...but its a lot better
July 28th-30th,2017
Old 12-06-2012, 07:41 AM   #8226
slakr's Avatar
Trader Rating: 28 (100%+)
Check out the RSD TC6 Suspension Block Locks
http://www.reflexracing.net/RSD-TC6-...ocks_p_18.html
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 12-06-2012, 07:43 AM   #8227
DARKSIDE's Avatar
my new background pic for my CPU...maybe the wifey will get the pitcure..lol
July 28th-30th,2017
Old 12-06-2012, 07:50 AM   #8228
The screw stays tight, but the mount rotates out of the way and lets the axle out of the hole.
The RSD solution looks ideal. Their page has them out of stock, but I'll print the page you sent and come back and check later.
Thanks!
USVTA #144
Old 12-06-2012, 07:54 AM   #8229
YoDog's Avatar
Trader Rating: 26 (100%+)
It looks like you are using a shim under the standard hinge pin block. You should use the offset blocks without any shims or flip the aluminum insert around backwards which will act as the shim. I found this was more solid and you don't loose any thread contact. Also as mentioned before, longer screws can help too. I have only had one screw pull out very early on then I switched to slightly longer screws and no problem since. I also notice you are running really high roll center. How's that working for you?
YoDog is offline   Reply With Quote
Old 12-06-2012, 08:02 AM   #8230
bertottius's Avatar
Trader Rating: 18 (100%+)
Yes. Looks like it's shimmed out way too much.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 12-06-2012, 08:03 AM   #8231
The only way thos blocks will roll is if the screw comes loose. The plastic cant rotate on he bushing, they are keyed together.
I normally just leave them both a little loose and then pinch them tight, while still allowing the arm to rotate freely, and tighten them up under pressure where they need to be.
Old 12-06-2012, 08:07 AM   #8232
YoDog's Avatar
Yupp, you should pick up a set of the offset hinge blocks. They are much better as they have a larger contact area against the bulkhead since no shims are needed. This equates to less rotation. You would be surprised how much more secure the blocks are by flipping the insert and adding a washer behind the screw head in the mean time until you get the offset blocks.
Old 12-06-2012, 08:09 AM   #8233
YoDog's Avatar
Not true at all... Sure the insert can't rotate in the block but the whole block and insert can rotate.
Old 12-06-2012, 08:28 AM   #8234
It would have to be one hard impact, or the screws come loose.
One solution might be to put a set screw in the blocks to touch the hinge pin. This might keep them from rolling on impact and/or the screw coming loose. The hinge pin is long enought that it shouldn't be able to fall out unless those blocks roll a long way. Maybe they are worn out to much and you just need new blocks. I have never experienced this or heard of theis problem until now so I am just trying to think of options.
Old 12-06-2012, 08:31 AM   #8235
I should have clarified...that's NOT a photo of my car. That's just one I grabbed off the Associated website showing the arm mounts. Sorry about that!
My car is not set up the same as the photo. I'm using the "0" mounts with shims.
USVTA #144
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
