Like Tree1Likes
Old 12-03-2012, 09:29 AM   #8191
Originally Posted by ammo View Post
Guys,
Need some help here,
Small technical track filled with low to mid speed corners, running 17.5 blinky,
Front diff - 125k diff fluid
Rear diff - 40wt shock oil
All settings are per stock manual recommendations.
Car is easy to drive and smooth, however it doesn't have the aggression for attacks.
Front pushes out upon deceleration to corner entry.
Tire traction doesn't seem to be problem as I am traction rolling if I clip a corner wrongly.
Where can i start to induce stronger steering authority in corner entry?
Also try putty on the front diff if you're playing on high traction track.
Good luck!
EG Racing
ExpressMotorSports
PayPal, MC & VISA
farmbridge2404 is offline   Reply With Quote
Old 12-03-2012, 12:44 PM   #8192
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Rufus2010 View Post
I have a 108 tooth 64 pitch spur gear that does not fit in my XRay transmission. I was thinking of giving it to a friend of mine who just bought a used TC6 to use in the VTA class, along with a set of 54 through 58 pinions.
Apparently the Kimbrough brand spur gears will fit in the TC6?
Is a 108 64 pitch too big to fit in the chassis. Looking to gear initially in the 4.0 to 3.8 range.
Use a 96t 64p spur in 17.5 no boost. This will give you a wide gearing and fitment range. The set you are proposing may not actually fit. Someone on here posted a total tooth range that will fit the TC6.
YoDog is offline   Reply With Quote
Old 12-03-2012, 01:47 PM   #8193
Resqnu's Avatar
Trader Rating: 37 (100%+)
Originally Posted by jha07 View Post
That part was designed to be used with 3Racing Damper, which is why it's not giving you the correct ride height with associated shocks. You can cut the ball end the spring base cover rides on, but be sure to cut them all equally.
Personally, I would just use the stock spring collar. I see nothing wrong with the plastic ones.
Thanks for the info. There's nothing wrong with the stock ones, just liked the look of the aluminum and they were only $6.50. I'll go back to stock.
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 12-03-2012, 07:13 PM   #8194
Jones Auto's Avatar
Im new to carpet racing. Ive been racing 5th scale gas for awhile. Im currently running vintage class at my local track. Does Hpi offer a wheel and tire set already mounted? I have to use HPI wheels in this class.
Jones Auto is offline   Reply With Quote
Old 12-03-2012, 07:28 PM   #8195
HPI offers several different styles of wheels with the D-compound tires mounted.
http://www3.towerhobbies.com/cgi-bin...nted&search=Go
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 12-04-2012, 08:19 AM   #8196
RussF's Avatar
Trader Rating: 21 (100%+)
At our track we can only run Tires 4793 front and 4797 Rear with stock inserts.
Rims 3805 through 3814, 3815 through 3822, 3854 through 3860, 33472 and 33473, 33474 and 33475.
And I have found no pre-mounts for them. I wish I could, as gluing these tires is not the easiest thing to do.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 12-04-2012, 09:01 AM   #8197
Hi guys, i just bought a tc6 and its currently being built. I dont have a local hobby store that stocks parts so i was looking to stock up on commonly damaged/broken parts that give up during an average crash. Can i trouble you guys for a list of parts i should order? many thanks
Tc6newbie is offline   Reply With Quote
Old 12-04-2012, 09:46 AM   #8198
TC6Newbie - From my latest experience, I would suggest these as essential:
Battery brace
Blades
C Hubs
Steering arms
Cups (on the end of each side of the diff/spool)
Also might consider spare shock caps, belts, CV axles. The car is pretty durable though.
With my latest race day I had a hard impact that yanked the screws out of the battery brace. Those little screws are hard to find and cheap (part no 31540) so you might grab some of those too.
Hope that helps.
markg is offline   Reply With Quote
Old 12-04-2012, 09:55 AM   #8199
Guys - need a quick answer. I accidentally ordered a Factory Team rear ball diff for a TC5 (part no 31182) instead of a ball diff kit for the TC6.1 (part 31336). Any chance it will work? I'm driving a TC6.1 WC kit, and was going to replace the gear diff with a ball in the rear. Thanks for any input.
Old 12-04-2012, 10:10 AM   #8200
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
The tc5 diff outdrives are longer than the tc6s. so they will not work
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 12-04-2012, 10:31 AM   #8201
Darn it - I was afraid of that. Appreciate the input. Hopefully I can return the wrong one without too much hassle..
Old 12-04-2012, 10:35 AM   #8202
bertottius's Avatar
Trust me, you want to keep that gear diff in there anyway. If anything you would want the ball diff in the front.
CHRIS BERTOTTI
Alpha Pace Racing
bertottius is offline   Reply With Quote
Old 12-04-2012, 10:36 AM   #8203
Rufus2010 - the combination you are proposing won't fit. I'm running a 64p, 96t spur and a 52t pinion, and I'm just about maxed out. I might be able to squeeze a 53 on there, but not sure. Hope that helps.
Old 12-04-2012, 10:52 AM   #8204
Send a message via AIM to Johnnytc3
Mark G,
Any reason you are swapping out the rear gear diff to a ball diff, I am in the process of building and was surprised it came with a gear diff. Was thinking about the swapping them out but figure I would give it a try first.
Johnnytc3 is offline   Reply With Quote
Old 12-04-2012, 11:29 AM   #8205
wtcc's Avatar
Both diffs from AE are great. It is also never bad to have a second non-spool-diff for low grip conditions/rain.
I even bought a one way to be prepared for everything and didn't regret it
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
