Like Tree1Likes
Old 12-01-2012, 07:05 PM   #8176
evochick's Avatar
Originally Posted by Rufus2010 View Post
I have a 108 tooth 64 pitch spur gear that does not fit in my XRay transmission. I was thinking of giving it to a friend of mine who just bought a used TC6 to use in the VTA class, along with a set of 54 through 58 pinions.
Apparently the Kimbrough brand spur gears will fit in the TC6?
Is a 108 64 pitch too big to fit in the chassis. Looking to gear initially in the 4.0 to 3.8 range.
Kimbrough fit fine,
use this link to determine what will and wont fit.
http://abram.eu.org/gear_tc6.php#
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 12-01-2012, 11:43 PM   #8177
Send a message via MSN to ammo
Guys,
Need some help here,
Small technical track filled with low to mid speed corners, running 17.5 blinky,
Front diff - 125k diff fluid
Rear diff - 40wt shock oil
All settings are per stock manual recommendations.
Car is easy to drive and smooth, however it doesn't have the aggression for attacks.
Front pushes out upon deceleration to corner entry.
Tire traction doesn't seem to be problem as I am traction rolling if I clip a corner wrongly.
Where can i start to induce stronger steering authority in corner entry?
ammo is offline   Reply With Quote
Old 12-02-2012, 02:43 AM   #8178
evochick's Avatar
Originally Posted by ammo View Post
Guys,
you tould try a heavier rear diff oil, start at 1K and go from there
UnRetired
Old 12-02-2012, 04:16 AM   #8179
SlideMasteR's Avatar
heavier rear diff oil will have a slower corner entry, rather try 0.5 or even 1.0 deg toe out in the front or a narrower front track width, that will give you more aggressive corner entry, if thats not enough reduce the rear toe in 0.5 deg inciments
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 12-02-2012, 12:23 PM   #8180
evochick's Avatar
strange. I was struggling with the came issue a little I just couldn't get a good initial turn in and was loosing too much time on corner entry and mid corner. I changed from 50 Wt to 1k and it really transformed my car it rotates through the slower corners so much better now. That's why I mentioned it.
Beth
UnRetired
Old 12-02-2012, 12:48 PM   #8181
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
If I am running with a 21.5 in VTA and a 48 pitch, I am hoping to run the Tekin Gen2 redline motor in my TC6.1 when I get it
Thanks for the tips guys and gals.
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 12-02-2012, 03:42 PM   #8182
cocojam's Avatar
Trader Rating: 47 (100%+)
Im having problem with the arm mount shims which gets deformed over time. Has anyone tried using alloy shims to replace these and will they work? TIA?
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 12-02-2012, 03:44 PM   #8183
oladele's Avatar
Team associated makes alluminum shims which is what I use for the very same reason
oladele is offline   Reply With Quote
Old 12-02-2012, 04:21 PM   #8184
Resqnu's Avatar
Trader Rating: 37 (100%+)
Default 3Racing aluminum shock base
I purchased the below item for my AE TC6.1 ft. When installed the front ride height will not go lower than 7mm and the rear will not go lower than 6.5mm. Any ideas to lower ride height?
3Racing Aluminium Shock Spring Base Cover 13mm For 3Racing Damper
Technical Data
The new Aluminium Shock Spring Base Cover 13mm from 3Racing successfully made a revolutionary transition from traditional plastic made to aluminum alloy. It effectively prevents spring twisting and bending, optimizing the performance of the shock. The base cover is of light-weight and cut by CNC machine precisely. Available as individual part now.
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 12-02-2012, 05:29 PM   #8185
Mr.juarez's Avatar
Whats you guys opinion on this? I see tamiyas with this position so I got busy thinkering with it.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 12-02-2012, 05:33 PM   #8186
Is there anything called setup sheet for newbies ?
I was going through the tc6.1 manual and here is what I am planning to do:
- 40w shock oil in all 4 shocks
- 2 silver springs in the front and 2 green springs in the rear
- ride height 5 mm
after this I will see how the car handles.
possibly will check/change gear differential oil with the same 40w.
does this look like a good starting point ?
I haven't checked the shock oil since I bought the tc6.1 used.
Thanks in advance.
______________
~TC6.1~Tekin RS~Futaba bls451~Futaba 4pk~FS603
www.programmerhaven.com
FourWheels is offline   Reply With Quote
Old 12-02-2012, 07:42 PM   #8187
- ride height 5 mm
Thanks in advance.
Setup Basics (different car, but some principles still apply):
http://www.youtube.com/watch?v=J-StHhhzI88
http://www.youtube.com/watch?v=srg9Glepzmk
Building Shocks (TC6 shocks are slightly different, but it's still a good watch):
http://www.youtube.com/watch?v=_mUeXYZbn5s
The Jilles Groskamp Pro Tips videos are good, too.
-Mike
Old 12-02-2012, 07:43 PM   #8188
BAD007SUZUKI's Avatar
Trader Rating: 95 (100%+)
Send a message via Skype™ to BAD007SUZUKI
i believe it adds "sprung weight" to the car. opposed to unsprung weight. thus changing the rate at which the arms compress and decompress because your adding weight to the a-arm in a sense.
im my experience with my s411 when i did this, the car didnt really change. i felt that it rolled slightly less in the corners but only at corner entry. which was when the extra weight at the tires caught up with the rest of the car and reacted the same. my lap times were within thousands of a second from mounting shocks the "standard way" and i think that was because traction came up in the track. i do not believe it lowers center of gravity enough to justify it. . . . . . .
BAD007SUZUKI is offline   Reply With Quote
Old 12-02-2012, 09:42 PM   #8189
-Mike
Oh great, will check them out.
Thanks Mike
______________
Old 12-03-2012, 09:17 AM   #8190
Technical Data
That part was designed to be used with 3Racing Damper, which is why it's not giving you the correct ride height with associated shocks. You can cut the ball end the spring base cover rides on, but be sure to cut them all equally.
Personally, I would just use the stock spring collar. I see nothing wrong with the plastic ones.
jha07 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
