Like Tree1Likes
Old 11-27-2012, 03:47 PM   #8131
rc pete's Avatar
Originally Posted by Resqnu View Post
How often should the bearings need to be replaced in the TC6.1?
Definitely have some 5x10's on hand as spares, and maybe one or two 10x15's.
The internal bearings (top shaft, steering and diff) last a long time. The 5x10 wheel bearings are a big improvement over the 6x10's in the previous ride in durability due to being higher profile, but if you smack a wall pretty good they'll still get notchy.
Check them by taking them out, spinning on a pencil (with some pressure to simulate cornering, not just freewheeling). If they're crunchy, replace.
The ceramics are a good upgrade, they stay smoother much longer even with abuse.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-27-2012, 04:19 PM   #8132
Resqnu's Avatar
Trader Rating: 37 (100%+)
Thanks, I have about 15 hours of actual runtime racing on an asphalt parking lot. Wasn't sure how often bearing wore out. Racing off road, I would replace about every 10-12 races. I am running this car more often with longer run times since we are racing near the house in a school parking lot. I've been running for 1 1/2 hours each time I go race since I'm getting 45min on a 5000mah battery. This car is a blast!
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 11-27-2012, 05:04 PM   #8133
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Do Xray rear body posts fit directly on the rear TC6 shock tower? Looking for something beefier to install.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 11-27-2012, 05:07 PM   #8134
G4ZZ4's Avatar
i have some on mine
cheers Garry
YOKOMO BD7, 21.5 boosted M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 11-27-2012, 05:42 PM   #8135
Trader Rating: 32 (100%+)
Originally Posted by G4ZZ4 View Post
i have some on mine
yup... i am using them as well on my tc6.1..
hobbs is offline   Reply With Quote
Old 11-27-2012, 07:09 PM   #8136
Resqnu's Avatar
Anymore input?
Old 11-27-2012, 07:33 PM   #8137
Front insert number up, rear number down. If you look at the back of the inserts closely, they interlock... they don't actually fit in the block if both numbers are up, unless you jam them.
Oh I jammed them Pete! Then I trimmed the excess to make them smooth in the arm. Fail! Give me an off-road car to build! Well I am sure if I like the car with zero degrees caster I will like it even more with four degrees.
Thanks,
Kane
Kane-o is offline   Reply With Quote
Old 11-27-2012, 08:55 PM   #8138
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
Hey guys I ordered the Reflex racing floating servo mount. Do I have to change my steering belcrank? Or am, I good with just the original worlds kit?
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - AE DC4 LE VTA -- Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 11-27-2012, 10:49 PM   #8139
trigger's Avatar
Unless you have the ability to drill and countersink your chassis, you'll need the RSD chassis with the RSD bellcrank.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-27-2012, 11:24 PM   #8140
KC10Chief's Avatar
I received and installed my DCJs from Reflex Racing. What a difference! I highly recommend them for the 6.1
KC10Chief is offline   Reply With Quote
Old 11-28-2012, 12:40 AM   #8141
rbarciko's Avatar
I use the 3rcacing body posts for the Sakura FF, as they are extra long at the front and rear if you want to try different body shells (eg. vintage touring car):
http://www.rcmart.com/3racing-sakf18...=595_1419_1503
rbarciko is offline   Reply With Quote
Old 11-28-2012, 10:37 PM   #8142
KC10Chief's Avatar
Is anybody using the RSD6 conversion from Reflex Racing? Are you using the 2.0mm or the 2.5mm? Is it worth it? I love my TC6.1, but I do not like the steering servo setup. What are some other advantages? Does everything bolt up as nicely as it does to the stock chassis?
I'm also looking at some of the shock pistons they sell on there. Anybody using any of them? We are running foam tires on carpet in my club. Thanks for any input!
Old 11-28-2012, 11:17 PM   #8143
wtcc's Avatar
I don't have the RSD6 chassis, but I can strongly recommend every shock tuning part Reflex offers. I for myself use the bladders, o-rings, pistons and springs. I use them for rubber and foam and it works great. The pistons give you a lot of abilities to try and find the perfect ones for your case!
If you only need more space on lower deck you can buy their new servo mount and drill+countersunk one hole to use it on your stock chassis. Or you go buy the RSDevo chassis for even more aftermarket opportunities.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 11-28-2012, 11:57 PM   #8144
I run the RSD. The normal version with some upgrades. I like the way the car transfers more speed into the corner than my TC6(.1). If you just don't like it, go for the shock upgrades RSD has (like wtcc says), they make your shocks buttersmooth.
Good luck.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-29-2012, 07:53 AM   #8145
BAD007SUZUKI's Avatar
Trader Rating: 93 (100%+)
Send a message via Skype™ to BAD007SUZUKI
Default rear end
Hi guys, coming from a serpent 411 to the new worlds car, does any know why the rear chatters or "skips" around corners? med/high grip carpet? I've tried everything except diff oil. which is stock. i also have the dual cardan from rsd and the aluminum spool outdrives.
Ive tried:
every camber link potition/length.
2mm inside ball stud all around.
2mm outside rear ball stud.
roll centers -h,m,l
droop
shock position (upper)
everything is free and smooth. car only has one race day and one practice day on it. im using a handmedown r9 body for now. my mazdas will be at the hobby shop today. the car is literally within grams from tire to tire and front to back. ive also tried sweep 32's and jaco blues. both do it.
R/C Fun Park 12990 SR23 Granger, Indiana 46530
BAD007SUZUKI is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
