Like Tree1Likes
Old 11-17-2012, 07:24 PM   #8071
KC10Chief's Avatar
Originally Posted by grippgoat View Post
People are refering to the hpi pro4 springs. 75175 is the full set. 6543 I think is silver.
But for a tc6, I'd just go with the reflex racing ones.
-Mike
Which springs from reflex would be good for racing 17.5T blinky on carpet? We run foam tires as well.
KC10Chief is offline   Reply With Quote
Old 11-17-2012, 08:26 PM   #8072
geeunit1014's Avatar
For foam tires, im not sure the RSD springs will be stiff enough (they are suited for rubber). As a guess id probably start with AE Purple front springs and AE Blue rear.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-18-2012, 01:33 PM   #8073
Just like TC5 FT kit!
Check it in manual.
at front DIFF!!! no solid axle.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-18-2012, 06:22 PM   #8074
I set my droop by measuring the drop of the arms with a droop gauge. When I lift the chassis in the middle I noticed that the tires do not come off the ground at the same time (it is close). Do you set your final droop by measuring the arm drop with a droop gauge, or do you adjust your droop to ensure both tires leave the ground at the same time?
rossb is offline   Reply With Quote
Old 11-18-2012, 06:56 PM   #8075
trigger's Avatar
^^^You are measuring droop correctly(measuring under the arms) but when you lift the car and the wheels come off at different heights, that's chassis tweak, we'll more like shock preload from the opposite end. Meaning if the rear wheels are uneven, then the front shock preloads needs adjusting and it the fronts wheels are at different heights, then the rear preloads needs adjusting.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-18-2012, 07:03 PM   #8076
The car is even on my tweak station, front and rear. Ride height is also even left to right. The wheels lift close, just not as exact as my droop gauge seems to indicate.
Old 11-18-2012, 07:22 PM   #8077
Johnny Wishbone's Avatar
Are you setting your droop with your shocks connected? If your using blocks and the tires are off, without the shocks attached and the droop is the same, you could have a shock thats causing your difference when its all togeather.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-18-2012, 07:37 PM   #8078
I am setting it with the shocks on. They are long enough so that they do not prevent the proper droop setting.
Old 11-18-2012, 07:53 PM   #8079
mtbboy's Avatar
Check to see if your spring retainers are touching your arms.
Grind the arms where the retainers make contact.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 11-19-2012, 04:32 AM   #8080
Well I just had my first race with the TC6.1 Factory team. I really like it! Cant believe what you can get for the price. I finished second, 6 seconds behind the new 6.1 WE. I used the kit setup with 1 extra degree of toe in the rear and 35w shock oil in the rear with losi 56 piston in the rear. Didn't have much time to play around with setup much. We are running the 17.5 boosted class and I has having issues getting the right engine temp with enough boost to be fast mostly on the infield. With Boost and turbo I find the car has no punch until you get to the straight and it has no torque on the infield. I was trying a compromise between physical timing and boost to make it fast but the engine gets very hot, around 200f.
I got it down to 191f running the tekin RS pro with 20 deg physical timing, 37 boost and 10 turbo and a FDR of 6.0 . It's the best setting I have tried so far but there are 2 club members who had faster lap times and more consistent races with blinky setup. It's a rather small track. The track is short. We do a lap in 9.5 seconds average so torque is most important, does anyone have suggestions on what to do about the boost settings, gearing ant timing? I am running the tekin redline engine, maybe a different engine brand has more torque and keeps cooler?
EvetsFidrat is offline   Reply With Quote
Old 11-19-2012, 07:32 AM   #8081
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
http://www.fantomracing.com/proddeta...prod=FAN27897W ..... This is the ticket!!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 11-19-2012, 08:24 AM   #8082
MikeXray's Avatar
Trader Rating: 73 (100%+)
Tekin motors are slow, get a Duo 3.5, thunderpower or Reedy, it sounds like your track is too small to really make use of "boost", I would just play with timing and gearing.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 11-19-2012, 09:13 AM   #8083
I never use that droop gauge. It's ok for ball park adjustment, but as you've seen it doesn't work. If your chassis, tires, and all suspension parts were perfectly manufactured, maybe it would work. But since nothing is ever perfect, it's best to not use it.
After my ride height and tweak is set, I measure droop by lifting the chassis up until the tires are barely in contact with the ground. I then measure what the ride height is. This minus actual ride height is the droop. I then fine tune the droop screws to make sure both tires leave the ground equal.
jha07 is offline   Reply With Quote
Old 11-19-2012, 09:18 AM   #8084
Try to reduce your physical timing to 10, or gear down, like 6.5. Too much timing, or too high gearing will reduce torque and make the motor hot. Keep going until the motor is around 160F.
Old 11-19-2012, 09:19 AM   #8085
RussF's Avatar
Trader Rating: 21 (100%+)
Our carpet track is also small and in the 9-10 second a lap area. We can only run blinky on the ESC but can time the motor to whatever we want. I run an LRP X-12 Stock Spec 17.5 with the stock timing insert (4 dot). We found that with our shorter track that a higher FDR is better overall. We run around 4.3 - 4.6 FDR and have great torque in the infield and I still dont think the motor tops out by the end of the straight on most motors. The temps are usually in the 150-200 range some with fans some without. For my TC6.1 I run 96/44 (64p) for a FDR of 4.36 currently, but think I will try 96/43 for a 4.47 and see how that works.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
