Like Tree1Likes
Old 11-05-2012, 02:45 PM   #7981
Maybell's Avatar
Originally Posted by maximuspowell View Post
can any of you guys tell me what size the 2 bearings are inside of the Associated ball diff 31336? Lost one and have to order another.
Part#31400. 5x8mm
The same bearings are in the TC5 diffs.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-05-2012, 07:45 PM   #7982
Resqnu's Avatar
Trader Rating: 37 (100%+)
Default My new Toy
This is my first TC and must say it exceeds my expectations. I have only run it in the street so far, but this car is a blast! Can't wait to try it out on a road track. I really enjoyed the build and painting the TC body. Thought I would share a few pics.
Team Associated TC6 Thread-img_3446a.jpg   Team Associated TC6 Thread-img_3458a.jpg
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 11-06-2012, 08:38 AM   #7983
RussF's Avatar
Trader Rating: 21 (100%+)
Nice job on the paint. Sure wish I could paint like that.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 11-06-2012, 09:24 AM   #7984
Resqnu's Avatar
Old 11-06-2012, 02:38 PM   #7985
IndyHobbies.com's Avatar
+1
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 11-06-2012, 06:10 PM   #7986
KC10Chief's Avatar
Where is a good place to start for my gear ratio? My car came with a 48P/87T spur gear. I am going to be running 17.5 blinky mode, indoors on carpet. We use 26mm foam tires all the way around the car. My motor is currently a Turnigy Track Star 17.5. ESC is a 60A Turnigy Track Star. I just ordered a Brushless Hobbies LT4 80A ESC to give that a try. I have no issues changing out the spur gear. I just need to figure out where a good place is to start my gear ratio and I can probably figure out the gearing from there. Thanks!
KC10Chief is offline   Reply With Quote
Old 11-06-2012, 06:22 PM   #7987
4.0 is a good starting point. 96 spur, 48p in 64 pitch. Or 72 spur, 36 pinion in 48p.
-Mike
Old 11-06-2012, 06:30 PM   #7988
Resqnu's Avatar
I asked the same question and was given alot of good info. Read pages 520 and 521 of this thread. I found the info very helpful. I went with the 72t spur and 48p pinions since I already have several a little less prone to small rock damage in parking lots while I get use to the TC. Once racing I may switch to 64p gears. Enjoy
Old 11-06-2012, 07:03 PM   #7989
Suspended
I've changed nothing on my setup & not crashed but now my car when accelerating into/out of RIGHT hand turns spins out like its on ice... the rear whips around uncontrollably. Turning left it holds great. What could be wrong?
Mysterious is offline   Reply With Quote
Old 11-06-2012, 10:28 PM   #7990
S_fender's Avatar
Shaft or front blade broken ?
S_fender is offline   Reply With Quote
Old 11-07-2012, 12:29 AM   #7991
aittam's Avatar
Hi,
my tc6.1 arrived yesterday. I cannot properly build the gear diff.
I did everything by the book. On one side: outdrive, small washer, big oring, small oring, diff box, large washer, pin, sun gear, 4 gears and 4 washers on the cross pins, gasket. On the other side: outdrive, small washer, big oring, small oring, diff lid, large washer, pin, sun gear.
The problem comes when i close the diff and tight the 4 screws. It is not 100% sealed. Only the parts close to the screws. The plastic of the diff box among the screws is a bit open (warped) and let some fluid out.
I thought the gasket was not properly inserted into the groove, so i disassembled the diff, checked the gasket, closed the diff, but nothing changed.
I opened the diff again and removed some fluid, trying to reduce pressure, but nothing changed.
Any advice?
Mattia.
http://rcmanici.blogspot.com
aittam is offline   Reply With Quote
Old 11-07-2012, 12:57 AM   #7992
Originally Posted by aittam View Post
Hi,
Any advice?
Mattia.
How full is the diff? Are you putting the screws in a star pattern and tightening each one a little at a time so it seats evenly?
Are the flats of the diff pins mating? Did you put the diff pins and gears in the right slots?
Pictures might help.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 11-07-2012, 01:14 AM   #7993
aittam's Avatar
Hi,
the first time i filled the diff till the cross pins were all covered. Then i removed some oil and now the oil level reaches the flat part of the lower cross pin.
I close the diff lid tightening the screws in a star pattern.
The flats of the cross pins match.
What do you mean with "Did you put the diff pins and gears in the right slots?"?
I put the cross pins the highlighted slots. Do the slots have different heights?
Mattia.
Old 11-07-2012, 01:23 AM   #7994
Hi,
Mattia.
I think you have everything right then, I was just going through "duh" stuff. Have you tried emptying the diff halves and putting them on a flat surface to see if they are warped or something?
Old 11-07-2012, 03:49 AM   #7995
does anybody know what springs are included in the TC6.1 FT kit not the WC.
I think the manual is not correct with green / silver - all look the same only blank silver.
It seems they are a bit soft on my indoor carpet track.
Do you recomment to order the spring set AE offers - to play arround
http://www.teamassociated.com/pictur...88/3988_md.jpg
or is there a better spring set that fits from X-Ray or any other vendor?
racer_hh is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
