Like Tree1Likes
Old 11-02-2012, 08:40 PM   #7951
adriang79's Avatar
My new TC6.1 FT is due to arrive Monday, think I got one of the last kits they had at Team Associated.
First new touring car I have had in many years, looking forward to building it.
www.stmcc-hobart.weebly.com STMCC Secretary
Team Associated TC7 - Hobbywing V3.1 Stock spec -Team Powers Actinium 13.5
http://stmcc-hobart.weebly.com/rcmaker-tas-challenge.html
adriang79 is offline   Reply With Quote
Old 11-03-2012, 08:21 AM   #7952
Mike Haynes's Avatar
Originally Posted by rigelkent09 View Post
copy mike haynes set up in my tc6.1, his belt tensioner/holder in the rear gear diff was in position 6 and i did notice a little loose in the rear belt, is it normal??thanks for the help...
Originally Posted by wtcc View Post
As long as there is no slip he might have used it to finetune the carbehaviour on acceleration. Otherwise just make it a little tighter.
Yes I usually run the rear belt pretty loose, if you hear it slip on acceleration then tighten it up. The actual number you have set at will vary depending on the age of the belt, I shoot for the front belt being snug, and the rear fairly loose.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-03-2012, 08:42 AM   #7953
rosko's Avatar
I have my belt at factory settings and my rear belt seems fairly snug and my front belt not so much guess ill have to readjust off of feel then.
rosko is online now   Reply With Quote
Old 11-03-2012, 10:15 AM   #7954
Hey All,
What other DCJ driveshafts work with the TC6.1 (SpecR for Tamiya, Yokomo, etc)? I just want an alternative to RSDs option.
Thanks,
Kane
Kane-o is offline   Reply With Quote
Old 11-03-2012, 10:31 AM   #7955
rigelkent09's Avatar
Trader Rating: 43 (100%+)
thanks for the clarification mike, actually my 6.1 is newly built have not try it run on the track yet, my front is 12, rear 6, i will be racing it this afternoon hope i can get positive result
rigelkent09 is offline   Reply With Quote
Old 11-03-2012, 12:00 PM   #7956
Has anybody used ball diffs in the car yet, are they worth getting?
Mugen MBX7R Eco
SC5M
Mugen MBX7R Werks B6/2 Pro
Futaba 3PKS
maximuspowell is offline   Reply With Quote
Old 11-03-2012, 12:47 PM   #7957
I had contemplated waiting but I'm glad I didn't considering they seem to be sold out now!
Have fun, it was fun to build.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 11-03-2012, 02:23 PM   #7958
Losiho's Avatar
Originally Posted by Vostok 7
I learned that the inner camber link ballstuds for the FT do NOT work with the WC vertical ballstud bearing caps. They work in the outermost hole, but any other hole is going to interfere with the bearing carriers, and even in the outermost hole they are a little too long for my taste; I have some AE 3.5mm TiN ballstuds on the way.
Originally Posted by Losiho View Post
Has anyone else had a problem with this ? I have yet to build by TC6.1, but my new WC chassis, shock towers and vertical ballstud bearing caps have arrived.
Bump.
Losiho is offline   Reply With Quote
Old 11-03-2012, 04:14 PM   #7959
If your in a pinch your dremel with a cutoff wheel can cut down the kit studs. It is important not to have the ballstud too long it will damage the diffholders and bind up your driveline.
Old 11-03-2012, 04:31 PM   #7960
wtcc's Avatar
I used the common ball diff for the rear for some races in the 17.5t class. Worked very good and saves you some weight. In the end an oil filled gear diff gives you more options, less maintenance and a better working drivetrain especially with strong motors. So I will not continue to invest in a balldiff even though the AE balldiff is of a very good quality!
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 11-03-2012, 05:45 PM   #7961
The WC supplement is finally up on the AE site and I was surprised that they specify 5mm ballstuds for the WC bearing caps. I'm surprised because 5mm would still poke out of the bottom of the hole and seems to me like it could still bind... I feel much more comfortable with the 3.25mm studs.
Old 11-03-2012, 06:52 PM   #7962
In most cases we run a 1or 2mm shim under the inside ballstud, a 3.25 will be too short unless running 0 shim
Old 11-03-2012, 06:54 PM   #7963
Originally Posted by Kane-o View Post
Hey All,
Thanks,
Kane
The version 2 spec r for tc6 is a drop in fit. I prefer the rsd ones as I think they last longer but have used the spec r with good success as well.
Old 11-03-2012, 07:38 PM   #7964
Including using the stock wheel hexes?
Serzoni is offline   Reply With Quote
Old 11-03-2012, 08:02 PM   #7965
Yes stock axle pin and hex on the ones I had
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
