Like Tree1Likes
Old 11-02-2012, 04:12 AM   #7936
KCChief-It was making something that everyone has- electrical tape under the battery.It works and cheap fix. Look back afew pages you'll find it. I did it to mine-3 strips of tape and it worked fine.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 11-02-2012, 06:01 AM   #7937
when i tried the yokomo springs i did cut rings of lexan and glued to the springcups to make them fit better
didnt like the feeling in them so didnt bother to find a better solution. for me they were too progressive. i do love the rsd springs!
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 11-02-2012, 07:53 AM   #7938
Resqnu's Avatar
Trader Rating: 37 (100%+)
Default Front spool/diff question
Just finished the build, all went well. Had 2 small issues. Missing 2 screws, but found them in another pack and installed wrong washers on diff. Manual wasn't clear on which size went where. Be sure and put small diff washer on the diff outdrives and larger under the sun gear.
I have raced 4wd sct and 1/8 e buggy for a few years. All diffs are gear diffs.
My question is about the front spool/diff. Why does the front diff not allow the tires to work independently? The front drives are locked together. Is it not needed or are you guys upgrading to the front slipper or gear diff. Any info on this matter would be helpful to understand.
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 11-02-2012, 08:17 AM   #7939
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by KC10Chief View Post
Okay. I could have sworn I saw something in this thread about something for the battery to sit on. I just bought the RSD battery hold down thing for my 6.1 WC. I installed it tonight. I'd like to just but a small strip or two of something down to keep it from sliding around so much. Maybe some sort of adhesive backed felt?
This is what you are looking for:
http://www.petitrc.com/reglages/asso...erLiPoBattery/
Its easy and seems to work great. I use tape to hold my battery in, but I dont see why it wouldnt work with velcro or the RSD system.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 11-02-2012, 08:46 AM   #7940
Funny, I had the exact same problems. Which screws were missing?
I had read a build guide online that said to make sure the bigger shim went on the outside of the gear diff. Everything went great until I tried to put the bearings on ugh. Ended up having to take it apart and rebuild it the correct way.
I went with a front gear diff after some research. I guess it's largely a feel thing but a lot of the pros use a gear diff front and rear. Also most people will say to use a super heavy oil/putty in the front so that it almost acts like a spool, but again if you look at some race winning setups from the pros they use what most people would say is "light" oil in their diffs.
Looking at pros setups has been very educational.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 11-02-2012, 08:59 AM   #7941
Resqnu's Avatar
Default *
Originally Posted by Vostok 7 View Post
Funny, I had the exact same problems. Which screws were missing? Think they were 3x8mm
I had read a build guide online that said to make sure the bigger shim went on the outside of the gear diff. Everything went great until I tried to put the bearings on ugh. Ended up having to take it apart and rebuild it the correct way. Must have read the same guide..lol
I went with a front gear diff after some research. I guess it's largely a feel thing but a lot of the pros use a gear diff front and rear. Also most people will say to use a super heavy oil/putty in the front so that it almost acts like a spool, but again if you look at some race winning setups from the pros they use what most people would say is "light" oil in their diffs. What gear diff? Only see one way and slipper spool online.
Old 11-02-2012, 09:12 AM   #7942
Originally Posted by 008-Racer View Post
Sorry to ask a daft question!
I have purchased a set of Yokomo springs to try out but how do you guys get them to sit correctly on the shocks?
The Yokomos have a larger diameter than most other brands?
On mine they just slide around and catch the suspension arms and as they move about they change the ride height!!
Does anyone else have any suggestions on this?
008-Racer is offline   Reply With Quote
Old 11-02-2012, 10:34 AM   #7943
CristianTabush's Avatar
Make sure you take up the side to side slack on the battery by using some servo tape and/or Lexan on the battery stop at the center of the chassis to space the battery out slightly. Using our Belt tensioner/ battery spacer can help as well.
When setting up the tabs, leave 0.3-0.5mm of space in between the battery and the tabs. Since all battery brands are slightly different, you will need to use slightly different spacing to get this done right. Adjust it by shimming the posts up and down.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-02-2012, 10:37 AM   #7944
Use Spec-R1 Shock Rod ends and Spring cups. Tamiya will work as well, but are more expensive.
Old 11-02-2012, 11:07 AM   #7945
An AE gear diff will fit front or rear, just have to make sure the bearing cams are put on the right sides, should be "flipped" compared to the rear.
There's also a Spec-R gear diff that will fit front or rear but my understanding is that the AE diff is actually smoother and more forgiving to build.
My screw troubles came when installing the rear bearing caps, I was supposed to use 4 M3x6mm button heads but I only had two, so I ended up using two M3x8mm button heads that seemed to be left over.
Old 11-02-2012, 12:42 PM   #7946
the ae diff is better, just build it after the manual and it should be fine
Old 11-02-2012, 02:30 PM   #7947
rigelkent09's Avatar
Trader Rating: 44 (100%+)
Default set up help
copy mike haynes set up in my tc6.1, his belt tensioner/holder in the rear gear diff was in position 6 and i did notice a little loose in the rear belt, is it normal??thanks for the help...
rigelkent09 is offline   Reply With Quote
Old 11-02-2012, 05:27 PM   #7948
wtcc's Avatar
As long as there is no slip he might have used it to finetune the carbehaviour on acceleration. Otherwise just make it a little tighter.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 11-02-2012, 05:37 PM   #7949
I use HD Velcro for my battery straps. Had some pretty good hits and it did not move. Maybe later I'll try the other battery holder.
Old 11-02-2012, 07:48 PM   #7950
Resqnu's Avatar
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 Yesterday 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
