Like Tree1Likes
Old 11-01-2012, 07:28 AM   #7921
rigelkent09's Avatar
Trader Rating: 44 (100%+)
Originally Posted by slakr View Post
size of the holes in the piston (3 holes; 1 @ 1.5, 2 @ 1)
so in haynes set up he is using 3 hole? right, and those numbers represent the size of the hole, i was confused on this, thanks a lot for the help slakr..
rigelkent09 is offline   Reply With Quote
Old 11-01-2012, 07:33 AM   #7922
slakr's Avatar
Trader Rating: 28 (100%+)
Exactly!
Here is a link to that piston...
http://www.reflexracing.net/RSD-TC6A...15mm_p_11.html
Great products and support from RSD. I highly recommend their shock bladders too!
http://www.reflexracing.net/RSD-10mm...ers_p_528.html
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 11-01-2012, 07:49 AM   #7923
Exactly!
yes i heard good things about them here, i will get one for sure, how about the rsd springs? would you recommend it?
Old 11-01-2012, 07:56 AM   #7924
Exactly!
The bladders were invaluable, especially for a first time builder like me. Being able to see air bubbles under them really helped.
I got the tuned spring set. Heard nothing but rave reviews about them.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 11-01-2012, 08:09 AM   #7925
slakr's Avatar
RSD springs are great. Very good and consitant. I bought the first set they had out (they have since released many more). I run HPI springs more frequently (along with Blue & Green AE), but they can be hard to find (HPI6543-SILVER 16.9lb, HPI6548-PINK 17.9lb, HPI6542-BLUE 15.3lb).
Old 11-01-2012, 08:39 AM   #7926
Rick Hohwart's Avatar
Exactly!
You can also buy blank pistons and drill the holes that you want. Three hole, 1.1mm is popular.
AE 1/10 Blank Shock Pistons
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 11-01-2012, 10:32 AM   #7927
Trader Rating: 21 (100%+)
Originally Posted by Vostok 7 View Post
Well, my build is done. Just need electronics now. Had only a couple hiccups, I'm really impressed. Most of the hiccups were my own stupidity (or following wrong instructions). Nothing that required replacement parts thank goodness. Only kit problems I had were that somehow two screws were missing (thankfully I found suitable replacements) and I learned that the inner camber link ballstuds for the FT do NOT work with the WC vertical ballstud bearing caps. They work in the outermost hole, but any other hole is going to interfere with the bearing carriers, and even in the outermost hole they are a little too long for my taste; I have some AE 3.5mm TiN ballstuds on the way.
Very nice build; clean!
Good info.
You mean to say the threads on the original ballstuds are too long, and the remedy would simply be to get ballstuds with shorter threads?
silencery is offline   Reply With Quote
Old 11-01-2012, 10:42 AM   #7928
Good info.
Thanks!
Yes. On the normal FT kit they go through the shock towers in to a locknut. They are 8mm long. The WC bearing caps are about 3.5mm thick, so even a 5mm ballstud is going to be slightly too long, that's why I got 3.25mm ballstuds coming (made a mistake in my original post, AE doesn't show 3.5mm ballstuds, so 3.25mm is a better choice):
http://www.teamassociated.com/parts/details/31374/
You can see in the last picture the issue, the 8mm ballstuds are far too long.
Old 11-01-2012, 01:18 PM   #7929
This is for a new build, do people still CA the CF edges?
I'm going to be building a 6.1 in the next week or so and I've always CA'd the edges, is it still a good step?
AreCee is offline   Reply With Quote
Old 11-01-2012, 04:22 PM   #7930
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Yes sir we do some add black / red / or blue / even orange paint first then
CA over it
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 11-01-2012, 07:35 PM   #7931
bhambrent's Avatar
http://www.rctech.net/forum/electric...n#post10462543
Pete are you going to make it to G.O.R.C.?
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 11-01-2012, 09:43 PM   #7932
KC10Chief's Avatar
Okay. I could have sworn I saw something in this thread about something for the battery to sit on. I just bought the RSD battery hold down thing for my 6.1 WC. I installed it tonight. I'd like to just but a small strip or two of something down to keep it from sliding around so much. Maybe some sort of adhesive backed felt?
KC10Chief is offline   Reply With Quote
Old 11-02-2012, 12:33 AM   #7933
Losiho's Avatar
Has anyone else had a problem with this ? I have yet to build by TC6.1, but my new WC chassis, shock towers and vertical ballstud bearing caps have arrived.
Losiho is offline   Reply With Quote
Old 11-02-2012, 12:50 AM   #7934
rbarciko's Avatar
The battery is supposed to move around a little, say 0.5mm - 1mm to allow the chassis to flex freely on both sides:
http://www.reflexracing.net/RSD-AE-T...em_p_1300.html
Description
This battery hold down system was designed to equalize the flex on your TC6 Chassis.
By using this innovative battery tab system, the battery is held down securely in place while at the same time not interfering with the chassis flex on the right side of the car. With any other battery holding system such as tape, velcro straps or full length battery braces, the battery becomes an integral part of the chassis' rigid structure. This creates a stiffer chassis on the battery side, making the chassis flex asymmetrically.
The Battery tab system allows the battery to "float" on top of the chassis, allowing the chassis to flex freely side to side. As a super cool added bonus, no longer will you need tape or cumbersome velcro to secure your batteries in place.
rbarciko is offline   Reply With Quote
Old 11-02-2012, 01:59 AM   #7935
Default Yokomo Springs?
Sorry to ask a daft question!
I have purchased a set of Yokomo springs to try out but how do you guys get them to sit correctly on the shocks?
The Yokomos have a larger diameter than most other brands?
On mine they just slide around and catch the suspension arms and as they move about they change the ride height!!
008-Racer is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
