Like Tree1Likes
Old 10-31-2012, 12:49 PM   #7906
Originally Posted by CristianTabush View Post
It is important so that at ride height, your pistons sit at the same position in all 4 corners. The piston height has a bit of an effect on how the oil flows through. Having all shocks the same length ensures all 4 shocks are "equal" which should make the car more consistent.
This also allows you to set your shock collars at the same height L/R and can help you identify when your car might have some tweak.
Total shock length will have no affect on the shock collar height.
Yes, it will change piston location. But even without calipers, you wouldn't be out by more than 0.5mm as long as you use the threads as reference. I'd be surprised if 0.5 difference in piston height had a noticeable effect.
jha07 is offline   Reply With Quote
Old 10-31-2012, 01:01 PM   #7907
CristianTabush's Avatar
It does make a difference in collar height because of the position of the threads in relationship to the bottom spring cup. This applies when running a different length shock end at the bottom, since the spring cup does bottom out on the shock end. Personally, I use TC6 ball cups for ball ends and I cut off 2mm off of the front ones to get the spring cup lower and get my ride height low enough. I should have specified this in the previous post.
While it is true that most people won't notice a difference in handling with the piston height, it does not make the procedure correct. You'd be surprised if you actually measure your shocks with calipers, your variance might end up being 1.5mm between the shortest and longest shock.
FWIW, If you want your car to be at its best, measuring your shock lengths is day 1 stuff. It does make a difference.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 10-31-2012, 01:18 PM   #7908
Johnny Wishbone's Avatar
Just to re-enforce what Chritian is saying, Hiro/Hotbodies goes to the extent of making sure the piston is in the same location on all four corners to ensure that the have equal pistion pack. If you look at Andy Moores setup from the worlds thats why they have different shock shaft lengths between the front and rear shocks. Also the more the angle of the shock changes, the more that piston moves up or down and changes the pack. These adjustments where even within .03mm difference, but still adjusted for.
Of course we are talking about drivers that could actually feel those differences and take advantage of those changes.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 10-31-2012, 01:23 PM   #7909
Like you said, the spring cup bottoms out on the shock end. So how could the amount the shock shaft is threaded into the shock end affect your shock collar height?
If you don't believe me, unscrew one of your shock ends by 10 turns and recheck your ride height. You'll see nothing has changed.
I agree if you have different shock ends, that will affect your collar height. But I'm assuming the shock ends are the same.
When I put my car together, I thought it was critical too, and used a caliper on them. But the more I thought about it, the more I realize it's not that important.
I'm really not trying to start an argument. I just think people put too much importance on shock lengths.
Old 10-31-2012, 01:42 PM   #7910
Again, read my statement about the different ball ends. We agree here.
On the other item, I am not trying to argue either, you are entitled to your opinion and thinking that it does not make a difference. You also have the choice to measure or not measure your shocks- that's up to you. Your skill level may or may not be high enough to tell the difference, however equal shock lengths, at least side-to-side do make your car more consistent. This is a fact.
Whether you achieve this by using calipers or by calculating total threads showing or not is not as important, however the extra step of measuring with calipers does not take but an additional 30 seconds per shock and the result is more consistent. This is why people measure them.
Shock lengths can also be used to adjust for piston position, which is an additional adjustment that allows you to change the behavior of your car when switching directions.
Old 10-31-2012, 02:15 PM   #7911
mtbboy's Avatar
Your wrong.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 10-31-2012, 02:41 PM   #7912
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
WRONG it makes a big difference
At the southern nats we had a hard time gitting the tc6 down to 5.5 mill
With the VTA tires the collars were all the way up and we had to shave
2mm off the shock end and not screw them up all the way leaving about 3thread showing just To get the cars to 5.5 mm in the front before we did this the lowest we could get them was 6.5 to 7 mill
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 10-31-2012, 02:49 PM   #7913
When you introduce different shock ends, that is a completely different matter, so lets not confuse the two.
As I said before, if you don't believe me, simply try unscrewing one shock end and then check your ride height. Nothing will change. Your car won't be tweaked. This is simple mechanics.
No, it doesn't take very long to use caliper to set your shock ends. In fact, I've be doing that to all my off road cars for sometime. I just don't like to tell new people, that probably don't have calipers, you must get all your shocks the same length because it's extremely critical. Tweak and droop are far more important.
Old 10-31-2012, 02:50 PM   #7914
Spillertwo's Avatar
What kind of CVA front drive axles are most of you guys using for the front end ?
Everybody just using the standard single joint or are people using aftermarket double joint drive axles ? If so which aftermarket parts are beeing used ?
I read a lot now about cars where people are buying aftermarket double joint front drive axles to reduce shatter under full steering.
Too bad no manufacturer is installing them as standard yet in the high end models like the new Asso TC6.1 worlds kit.
Spillertwo is offline   Reply With Quote
Old 10-31-2012, 02:54 PM   #7915
Exactly, you had to shave off 2mm off the shock end to get the height down. It really doesn't matter if you screwed it in all the way or leave 3 threads showing. The shock end height is what matters because the spring cup rides on it.
Old 10-31-2012, 02:55 PM   #7916
Originally Posted by mtbboy View Post
Your wrong.
Sorry, but I am right. And it's "You're" not "Your"
Old 10-31-2012, 06:30 PM   #7917
Resqnu's Avatar
Trader Rating: 37 (100%+)
Originally Posted by RussF View Post
Actually its important to make the shocks all the same length. I used calipers to measure mine and make them all the same. I think it was 63mm from top of the cap to bottom of the mount. I could be off the measurement a bit but try your best and make them equal.
I don't recall the actually measurement. For the rears, I screwed in the shock end all the way, minus 2 threads. For the front I when in all the threads.
Your droop screws will ultimately control how far your suspension goes down. As long as the shocks are long enough that they don't limit travel before the droop screws you'll be ok.
Thanks for the info. I used a caliper and set the shock shaft to 32 mm on all. Guess I'll start there
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 10-31-2012, 10:15 PM   #7918
Well, my build is done. Just need electronics now. Had only a couple hiccups, I'm really impressed. Most of the hiccups were my own stupidity (or following wrong instructions). Nothing that required replacement parts thank goodness. Only kit problems I had were that somehow two screws were missing (thankfully I found suitable replacements) and I learned that the inner camber link ballstuds for the FT do NOT work with the WC vertical ballstud bearing caps. They work in the outermost hole, but any other hole is going to interfere with the bearing carriers, and even in the outermost hole they are a little too long for my taste; I have some AE 3.5mm TiN ballstuds on the way.
Everything is out of the box except:
AE Gear Diff in front
WC Bearing Caps
WC Shock Towers
RSD Silicone Bladders
RSD 3mm Silicone O-Rings
RSD 1.5/1/1 Delrin Pistons
RSD Belt Tensioner/Battery Spacer
RSD Fan Mount
RSD Lipo Tab System
RSD Tuned Spring Set (not installed, just stock springs for now)
A-Plus Spring Steel CVDs all around
Zeppin Spring Steel Gear Diff Outdrives all around
Spec-R Rear Belt
For electronics I'm planning:
Team Orion R10 Pro ESC
Team Orion VST Pro Stock 17.5 motor
Savox SC-1267SG Servo
Airtronics MT-4 radio setup
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 11-01-2012, 07:16 AM   #7919
rigelkent09's Avatar
Trader Rating: 40 (100%+)
can anyone help me clarify what are those numbers for shock pistons??i only seen 1,2, and 3 in the kit. also in mike haynes set up, the shock piston he is using was 1,1,1.5 what does it mean? thanks for any help...
rigelkent09 is offline   Reply With Quote
Old 11-01-2012, 07:20 AM   #7920
slakr's Avatar
Trader Rating: 28 (100%+)
size of the holes in the piston (3 holes; 1 @ 1.5mm, 2 @ 1mm)
JQ THEeCar Black,THECar White~Mugen MBX7TR Eco~TLR 22 3.0SR,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
