Like Tree1Likes
Old 10-30-2012, 04:43 PM   #7891
rigelkent09's Avatar
Trader Rating: 44 (100%+)
Default new tc6.1 build help
im building my rear gear diff now, im a little confused of what kind of oil that has 35 wt for the diff, i've been looking around online but cant find one, does shock oil will work on diff in my tc6.1 since i have a couple laying around, thanks...
rigelkent09 is offline   Reply With Quote
Old 10-30-2012, 04:50 PM   #7892
found already the answer in the manual, sorry i should have read it first lol...
Old 10-31-2012, 07:39 AM   #7893
Resqnu's Avatar
Trader Rating: 37 (100%+)
Default Building TC6.1 ft
Just got my car and staring to build. What cam do you guys recommend for asphalt parking lot practicing and concrete racing?
Any other tips on the build is appreciated.
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 10-31-2012, 09:22 AM   #7894
Resqnu's Avatar
Default shock shaft length
what length are you guys making your shock shaft?
Old 10-31-2012, 09:46 AM   #7895
I don't recall the actually measurement. For the rears, I screwed in the shock end all the way, minus 2 threads. For the front I when in all the threads.
Your droop screws will ultimately control how far your suspension goes down. As long as the shocks are long enough that they don't limit travel before the droop screws you'll be ok.
jha07 is offline   Reply With Quote
Old 10-31-2012, 10:25 AM   #7896
RussF's Avatar
Trader Rating: 21 (100%+)
Actually its important to make the shocks all the same length. I used calipers to measure mine and make them all the same. I think it was 63mm from top of the cap to bottom of the mount. I could be off the measurement a bit but try your best and make them equal.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 10-31-2012, 10:35 AM   #7897
YoDog's Avatar
Trader Rating: 26 (100%+)
Cam???
Do you mean camber?
Use the setup suggestions found in the manual. This is a good starting point for the TC6.1 and the new shock shafts are long enough for "normal" droop settings as you won't need to leave any threads exposed. just screw the ball cups to the end of the threads and you will be fine.
YoDog is offline   Reply With Quote
Old 10-31-2012, 10:51 AM   #7898
Jochim_18's Avatar
50wt Associated shock oil on the rear gear diff.
Racer edge putty on the front.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-31-2012, 10:55 AM   #7899
Why? I can see this being important if we didn't have droop screw.
I used calipers when I built mine as well, but I really don't see the need for it.
Old 10-31-2012, 11:05 AM   #7900
Resqnu's Avatar
Originally Posted by YoDog View Post
Cam???
Do you mean camber?
In the manual under the front spool and rear diff building. Options for setting the cam are low/mid low/mid high/high, depending on surface traction.
Old 10-31-2012, 11:23 AM   #7901
trigger's Avatar
^^^^ I think he's referring to diff height.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 10-31-2012, 11:46 AM   #7902
Resqnu's Avatar
Yes. What is a good starting point? Manual says mid-low. It that good for asphalt parking lot?
Old 10-31-2012, 11:51 AM   #7903
Resqnu's Avatar
Got it. Had a brain fart.... When with standard set up in manual
Old 10-31-2012, 11:56 AM   #7904
YoDog's Avatar
Hey Kim, he found the magic manual...now all is clear.
Old 10-31-2012, 12:21 PM   #7905
CristianTabush's Avatar
It is important so that at ride height, your pistons sit at the same position in all 4 corners. The piston height has a bit of an effect on how the oil flows through. Having all shocks the same length ensures all 4 shocks are "equal" which should make the car more consistent.
This also allows you to set your shock collars at the same height L/R and can help you identify when your car might have some tweak.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
