Like Tree1Likes
Old 10-28-2012, 02:17 PM   #7846
Started my FT build today, shocks went pretty smooth considering this is my first build. Only major issue was getting the collars on, either the collars or the bodies had a ton of burrs. Only one went together 100% smooth on the collar. No biggie, though, just a tiny bit of gummed up anodizing was the only damage, all the collars are smooth all the way up and down once I got past the burrs.
Using the kit oil and kit springs for now with RSD bladders, 1.0/1.0/1.5 pistons and silicone o-rings. Shocks are crazy smooth (as far as I can tell!). I have a RSD tuned spring kit and some 50wt oil but I wanted to try (most of) the kit setup first.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 10-28-2012, 03:32 PM   #7847
tried rsd bladders and springs yesterday, the shocks are working alot better now, the car is easier to drive, quite a big difference! didnt make me faster on a single lap but made less misstakes over 5 minutes, a really good upgrade to the car!
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-28-2012, 03:57 PM   #7848
rigelkent09's Avatar
Trader Rating: 44 (100%+)
can you show me link where i can get those rsd bladders and springs??thanks..
rigelkent09 is offline   Reply With Quote
Old 10-28-2012, 04:00 PM   #7849
http://www.reflexracing.net/AE-TC6-_c_4.html
i dont know if im blind, but im looking for the part number for the pulley for the front spool
time to change belts and pulleys, and i dont want to buy a whole new spool for $30 just to get the pulley
Old 10-28-2012, 04:08 PM   #7850
Smile
great...
Old 10-28-2012, 06:53 PM   #7851
hanzo3's Avatar
Trader Rating: 55 (100%+)
Is there slop in the wc version? How do I fix it on a regular 6.1?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 10-28-2012, 06:58 PM   #7852
Can anyone tell me if the turnbuckles are set to different lengths between the FT and the WC? Also if there are any special instructions for the bearing caps?
The manual for the WC isn't up on the AE site yet.
Old 10-28-2012, 07:39 PM   #7853
JFuel11's Avatar
Trader Rating: 152 (100%+)
Who is running a Gear Diff in the front?
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 10-28-2012, 11:39 PM   #7854
wtcc's Avatar
Me.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 10-28-2012, 11:44 PM   #7855
Trader Rating: 32 (100%+)
Originally Posted by wtcc View Post
Me.
what cst of oil r u running???
what class???
hobbs is offline   Reply With Quote
Old 10-29-2012, 01:16 AM   #7856
i run a gear diff up front in 13.5 with boost, and cleaning putty in it
when running 6.5 with boost, i run a spool.
ed
Edwin Pibal is offline   Reply With Quote
Old 10-29-2012, 02:07 AM   #7857
wtcc's Avatar
what class???
See here:
http://www.petitrc.com/reglages/asso...enden20121007/
But it only works very good for medium grip carpet. In high grip conditions a spool/one way is the way to go.
Old 10-29-2012, 02:41 AM   #7858
ed
Thanks.
I am interested in your 13.5T boost set up.
Cleaning putty in front diff.
What cst for rear diff???
See here:
Thanks...
3000 cst in front diff???
Old 10-29-2012, 03:12 AM   #7859
wtcc's Avatar
What do you want a gear diff in front for?
I want it to make my car turn in better and to have a planted back end when accelerating. If you fill it with hard oil or even putty it will handle like a soft spool. So why not use a spool? The 3000cst worked best for me on the mentioned track.
If you have the time do some testing with different diff oils. The use of a gear diff also depends on the track layout and the way of your driving style (point to shoot or round flowing).
Old 10-29-2012, 03:16 AM   #7860
Thanks for sharing,
in the front diff, i have used 80,000 cst, 150,000 cst, 300,000 cst, but never as low as 3,000 cst.
Will try that....
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
