Like Tree1Likes
Old 10-26-2012, 11:44 AM   #7831
Trader Rating: 77 (100%+)
I just got the reflex battery hold down. Do I need to make sure the battery is held down tight or should it wiggle a bit?
Thanks.
goin2drt is offline   Reply With Quote
Old 10-26-2012, 12:04 PM   #7832
Still no shipping notification
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 10-26-2012, 12:08 PM   #7833
Originally Posted by asuradahk001 View Post
TDX launched new version TC6 chassis
where can i get that chassis from
goslow is offline   Reply With Quote
Old 10-26-2012, 12:24 PM   #7834
wtcc's Avatar
Thanks.
Give it a little space, about 0.5mm, to allow the chassis to flex freely.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 10-26-2012, 12:25 PM   #7835
Thank you
Old 10-26-2012, 01:05 PM   #7836
Originally Posted by frenchchris View Post
hello all
if you want to try the tc6 by turning the servo , just replace the ackerman setting screw by a pivot ball the do a hole on the main chassis plate and that all
this is a good way to try before going to rsd conversion for exemple
here some pics
many thanks
What advantage is there to mounting the servo this way?
jha07 is offline   Reply With Quote
Old 10-26-2012, 01:24 PM   #7837
wtcc's Avatar
More space for your electronics, equal chassis flex, more equal right left weight distribution. At least if you do it like I did...
Old 10-26-2012, 02:00 PM   #7838
if i wanted to update my tc6.1 ft to a wc is it the chassis and ballstud brackets that are different ? or is the wish bone different flex again?
also i use a losi 22 velcro battery strap and just cut the plastic ring off
tcboy1983 is offline   Reply With Quote
Old 10-26-2012, 02:50 PM   #7839
My TC6.1FT came today Along with all my RSD goodies! Woohoo!
Chassis, towers and bearing caps are the different parts.
If you order bearing caps, make sure to order 2x A and 2x B. I was under the impression that they came in pairs but they don't.
Old 10-26-2012, 05:26 PM   #7840
Resqnu's Avatar
Trader Rating: 37 (100%+)
[QUOTE=Vostok 7;11371683]Still no shipping notification [/
Was responding, but saw your post
WoodyzArt.com custom painted RC bodies
Resqnu is offline   Reply With Quote
Old 10-27-2012, 01:20 AM   #7841
frenchchris's Avatar
Thumbs up servo mounting
you got a direct link between the servo head and the steering axel, the servo took less space so you can fit receiver and combo more freely you can also use it to balance the electronics in order to be less concentrated in mid or rear part of the car.
the handling is really more predicable so you turn quicker using less steering ratio
good way to avoid understeering you can stay inside the corner and get full gaz faster
this is convenient for me maybe other driver will not like it but the reflex conversion is using the same way and got good result on high level so...
not difficult to modify too
try and let me know
frenchchris is offline   Reply With Quote
Old 10-27-2012, 04:35 AM   #7842
JustWill75's Avatar
Send a message via AIM to JustWill75
I wonder why none of the team drivers tried this servo mod. The BD7 mount looks awesome on the TC6.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 10-27-2012, 12:03 PM   #7843
Team Grid RC's Avatar
Default Let your chassis flex!
If you want your TC6 to have predictable handling, all the adjustments won't be as effective unless you get one of the heaviest component off the chassis so it can flex freely. Not clamping the battery down tight does not give it more flex. The weight of the battery prevents the chassis from flexing freely.
Team GRID Touring Car Performance Upgrades and Tools
The other component is the servo. Mounting sideways has an advantage, but either ways, you need to float it. By floating, a single mounting point is used allowing free flexing under the servo area. We have a lot of racers using ours as well the Yokomo BD7 sideways mount.
Team GRID
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 10-28-2012, 06:50 AM   #7844
adriang79's Avatar
Anyone got a discount coupon code for Team Associated store?
www.stmcc-hobart.weebly.com STMCC Secretary
Team Associated TC7 - Hobbywing V3.1 Stock spec -Team Powers Actinium 13.5
http://stmcc-hobart.weebly.com/rcmaker-tas-challenge.html
adriang79 is offline   Reply With Quote
Old 10-28-2012, 09:14 AM   #7845
Resqnu's Avatar
Default Servo ?
I've got a new Savox sc-1256tg servo. Is this a good servo for my tc6.1 or should I look for something else? What servos and specs are you guys running?
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
