Old 10-22-2012, 08:19 AM   #7756
Default My tc6.1 WE ver666
bigger pictures there:
http://abram.eu.org/files/tc6.1_we_ver666/
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-22-2012, 09:33 AM   #7757
wtcc's Avatar
I see some nice ideas! How do they work on track?
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 10-22-2012, 11:20 AM   #7758
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by team mopar View Post
Can someone direct me where to find info to correct front end chatter on my tc6 on roadcoarse turns? Car is being run in vta. Who's setup sheet would i most benefit from?
I set up my TC6 for VTA with the setup sheet in the back of the manual or kit setup. I copied it exactly even building the diff and shocks the recomended way. The only difference I can think of is that my shock caps are vented. The car was awesome!!
When the car is driving the CVD's dont seem to chatter on mine. Are you hearing/feeling it when actually racing it or just when holding it up and running the throttle while turning?
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 10-22-2012, 12:39 PM   #7759
Originally Posted by FourWheels View Post
Hi Guys,
I have a question regarding the spur and pinon size on the tc6.1. I have mounted a silver can (Tamiya 540) motor and I faced the same problem of the bushing and the screws not lining up so added a stack of washers upto 5mm as spacers and I have installed the motor but I have a 72t 48p spur gear and I have 24, 25, 26t pinions and non of them touch the spur gear So I need to buy a bigger spur gear and around 3 pinions.
I am looking at the following spur pinion sizes :
Spur-pinion = drive ratio
81-31 = 5.22
81-30 = 5.40
81-29 = 5.58
81-28 = 5.78
87-33 = 5.27
87-32 = 5.43
87-31 = 5.61
87-30 = 5.8
What combination should I get, any suggestions ?
I am very new to racing and still learning to drive so I am looking at a 5.7 ratio to start with ...
Thanks.
According to the gear chart posted, 76/39 fits, and 76/40 doesn't. That puts the max tooth count at 115. Also, 80/22 fits, but 80/21 doesn't, putting the min tooth count at 102. That means none of the 87T combos will fit in the car, so you'll have to go with the 81T combos. Just get the spur for now, and I can loan you a few pinions to try and figure out what works, since I don't use the ones I have in that range. Then you can just by one and focus on driving.
EDIT: If you can't find the 81T 48P locally, anything down to about a 78 should still work.
-Mike
Old 10-22-2012, 01:11 PM   #7760
-Mike
Ah, I didn't look at the chart I was just crunching numbers .
______________
~TC6.1~Tekin RS~Futaba bls451~Futaba 4pk~FS603
www.programmerhaven.com
FourWheels is offline   Reply With Quote
Old 10-22-2012, 02:38 PM   #7761
Rick Hohwart's Avatar
Default New setups posted
Keven Hebert - IIC - Super Stock 13.5
Keven Hebert - IIC - Modified
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 10-22-2012, 03:11 PM   #7762
team mopar's Avatar
Default tc6 front end shake/chatter
Friends watching plus myself can see front end shake in the middle of turns. Entry and exit seems to be ok? ordered reflex cardan axles in hopes to cure issues today. Venting shocks is this a must do trick? Thanks for the responce!
team mopar is offline   Reply With Quote
Old 10-22-2012, 03:27 PM   #7763
AdrianM's Avatar
Originally Posted by Rick Hohwart View Post
Was he running front kick up or am I reading the sheet wrong?
Adrian Martinez
Old 10-22-2012, 03:31 PM   #7764
DARKSIDE's Avatar
Originally Posted by Just1More View Post
Just throwing this out there but since my LHS had no battery tape, we used a Losi 22 battery strap(velcro), cut the plastic end off the loop and slid the carbon fiber battery hold down piece through the loop.
Can someone verify it though? Don't take this to be gospel just yet, he had it in the back and said it was from a 22. From the pics the 22 strap looks too short. Spektrum makes long ones also(found on Amain)
I use some straps from Family Dollar store on all my TC6's and 6.1's...and they work great and only $1...Ive never had a battery come out either..even in VTA
Team Associated TC6 Thread-img_20121022_160621.jpg   Team Associated TC6 Thread-img_20121022_160719.jpg   Team Associated TC6 Thread-img_20121022_160703.jpg   Team Associated TC6 Thread-img_20121022_160655.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 21, 2017 Thunder RC Raceway
http://events.rcsignup.com/events/displayEvent.cfm?id=5313
DARKSIDE is offline   Reply With Quote
Old 10-22-2012, 04:45 PM   #7765
hm ....
maybe 17/XI will check it
now with custom fiberglass I think I have more flex then modified top deck Juho style
1320g ready car for run.
previous = 1353g
can use 30g lead for perfect tune
Michal Abramowicz
Old 10-22-2012, 04:48 PM   #7766
at front should be front mount 3A/ rear mount3B
it reduce cater from 6 deg to ~5
Michal Abramowicz
Old 10-22-2012, 04:51 PM   #7767
The setup sheets are wrong. Links now fixed.
www.reedypower.com
Old 10-22-2012, 04:53 PM   #7768
AdrianM's Avatar
Thanks Rick. I was about to say WTH and give it a shot lol! I haven't tried kick up on a sedan in almost 10 years. My TC3 may have been the last time I tried that.
Adrian Martinez
Old 10-22-2012, 05:03 PM   #7769
We actually have tried it on the front. And rear too sometimes. Bob S. used front kick up at the ROAR Nationals.
http://www.teamassociated.com/pdf/ca...stock_2012.pdf
www.reedypower.com
Old 10-22-2012, 05:10 PM   #7770
Took the plunge and ordered the FT on sale at the AE site. Can't wait
I think I'm only going to do a partial conversion to the WC, maybe use a different chassis, but at the very least I'm going to do the WC vertical ballstud caps and towers. I couldn't beat the $150 difference.
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
SEO by vBSEO 3.5.0
