Like Tree1Likes
Old 10-20-2012, 03:47 PM   #7726
wtcc's Avatar
That is the Reflex Racing Battery Hold Down System. Just check their shop reflexracing.net! Christian has a lot of great products for us AE TC6 drivers.
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 10-20-2012, 04:59 PM   #7727
Originally Posted by wtcc View Post
I just finished building my Yokomo BD7 and like the servo mount!!!
ha ha ha!
don't say that yokomo holes are perfect for ae holes ??????
In my case, I just glue by yokomo tape servo to chassis
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-20-2012, 09:15 PM   #7728
Trader Rating: 24 (100%+)
Will the TC6 aluminum shock collars fit the TC3 aluminum shock bodies?
JoeyE is offline   Reply With Quote
Old 10-21-2012, 01:53 AM   #7729
KC10Chief's Avatar
My TC6.1 World's Car came in today. I've been out of RC racing for 7 or 8 years or so and never raced on road. I've had quite a few AE vehicles in the past. This thing is all quality. I spent the evening putting it together. There's so many set up options on this thing! I just set it up like the instructions recommended. Anything different that I should do from what the instructions said? I am going to be racing on carpet with foam tires. 17.5T motors. Maybe 13.5T later on.
KC10Chief is offline   Reply With Quote
Old 10-21-2012, 01:58 AM   #7730
CL
CL's Avatar
Trader Rating: 32 (100%+)
FYI:
Associated is selling TC6.1 for $250 on their website special.
Believe in yourself!
CL is online now   Reply With Quote
Old 10-21-2012, 02:12 AM   #7731
Originally Posted by CL View Post
FYI:
With free shipping. Just ordered one. Will see if its in stock when the order is processed.
Dave
dave is online now   Reply With Quote
Old 10-21-2012, 04:18 AM   #7732
wtcc's Avatar
Check out my latest Indoor Setup from Senden on PetitRC. Did a just for fun run with foam tires (26mm front and rear) and the car was even more awesome! You can't follow the car with your eyes so fast! I think I even broke the lap record
@Michael: I had to drill one hole in front of the forward hole.
AE / Reedy / RSD
Old 10-21-2012, 04:25 AM   #7733
Appreciate if u can show some photos with the servo on & also bottom plate where u drilled an extra hole...
Thanks...
hobbs is offline   Reply With Quote
Old 10-21-2012, 04:26 AM   #7734
Looking good wtcc :-)
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 10-21-2012, 05:01 AM   #7735
wtcc's Avatar
Thanks...
Thank you guys!
Here you go with a pic:
I don't have a picture from the bottom of the chassis. It is very easy. Make a 3mm hole 14mm in front of the most forward hole of the center line and countersunk it. Also cut away one little pin from the bottom side of the servo mount and thats it
AE / Reedy / RSD
Old 10-21-2012, 06:55 AM   #7736
Thank you guys!
Thanks..
Old 10-21-2012, 07:38 AM   #7737
Trader Rating: 77 (100%+)
FYI:
They had a warehouse sale for 1 day last week and I got one for $199. The whole reason I got sucked back in to on road.
goin2drt is offline   Reply With Quote
Old 10-21-2012, 07:56 AM   #7738
team mopar's Avatar
Can someone direct me where to find info to correct front end chatter on my tc6 on roadcoarse turns? Car is being run in vta. Who's setup sheet would i most benefit from?
team mopar is offline   Reply With Quote
Old 10-21-2012, 08:17 AM   #7739
Trader Rating: 49 (100%+)
the cvd's will chatter in the front end. Make sure your blades are good and the cvd is not by itself in the outdrive cup. DCj's will fix the front end chatter, but I never had an issue with the chatter causing much of a problem.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 10-21-2012, 08:25 AM   #7740
Potoczak's Avatar
Trader Rating: 109 (100%+)
Thank you guys!
Wtcc what servo mount is that?? Also how did you attach the turnbuckle to that bellcrank? Is that that stock single one in the picture??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
