Team Associated TC6 Thread
#7652
#7656
Any reason the TC6.1WC wouldn't be a good car for a first time builder? Not new to RC or building models, but never built an RC before.
#7657
Trader Rating: 102 (100%+)
release
I thought it was out and available or at least Tower is showing in stock...wonder if it's true.
http://www3.towerhobbies.com/cgi-bin...&I=LXCWGH&P=ML
#7658
Tower has been showing them in stock for a couple of days. I pre-ordered mine from Speed Tech RC. They are showing them in stock as well, but mine hasn't shipped yet. I'm getting anxious!
Nah. Piece of cake. I prefer to build all of my cars. It helps me understand better everything that is going on with it and how it works. Plus, they're just fun to build! I am just getting back into it, but I've built seven or eight Team Associated vehicles in the past. Their instructions were always very clear. I can only imagine that it's even better now.
#7659
wire
Also suggest running the transponder wire under the servo horn (a little glue and never moves) then route wire under suspension mounts.
#7660
Front Inner Shim 4mm ?
Any Idea why ? To compensate the bigger Tire Diameter of the Ride Tyres ?
To avoid Traction Role ?
#7661
We are not sure why this is good but even going back to the TC5 days we set up the car this way.
#7663
No real need for tuning parts or build tips. Maybe get four M3x3 grubscrews to reduce slop in the hubs and the ReflexRacing shock bladders for an easier/better shock build and zero rebound adjustment.
For the setup start with the Keven Herbert carpet setup as starting point.
#7664
Yes, right in the middle of the downside.
#7665
got my my worlds car kit
got it last night from a local dealer... I started the build I would say i was somewhat disappointed specially the front and rear bulk heads first of all the color was off it was lighter in color it really looked like it was a part that came from remotest part of china. The second issue was the machining of it was very rough compared to the other parts of the car, it so ugly that you see machine cuts on the metal it was like they did not even polish it, maybe sanding it down would even be better ... I emailed AE support about it hope they fix this issue
