Like Tree1Likes
Old 11-29-2010, 04:21 PM   #751
Trader Rating: 48 (94%+)
Sorry did not mean to high jack the thread just getting into touring cars and trying to learn asmuch as I can.
tcb22185 is offline   Reply With Quote
Old 11-29-2010, 04:32 PM   #752
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
My tc6 is on its way from tower
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 11-29-2010, 05:56 PM   #753
mine too!!!
DJG24 is offline   Reply With Quote
Old 11-29-2010, 06:44 PM   #754
Trader Rating: 14 (94%+)
we are also now stocked up!!!! thank god!! Thanks for those that were patient. i am so glad i am not answering that daily question. "when are they coming" LOL
Cant wait to get building a demo kit, haha
Spider Hobbies
Sales@t2crc.com
814-701-2537
Team T2C is offline   Reply With Quote
Old 11-29-2010, 10:54 PM   #755
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by M.Abramowicz View Post
Well done Juho!
4th place at ETS event
http://ets.redrc.net/2010/11/volker-...it-2-out-of-2/
Juho was using gear diff and question is which oil?
I know that trf416 friend was change from AE 2000 to 1000 for
better corner speed, 2000 was not right for him.
Now, why Juho use links at top?
Anyway, great job done by Juho, as usually all wait for setup
What gear diff was he using??? Yokomo???
STLNLST is offline   Reply With Quote
Old 11-30-2010, 05:52 AM   #756
It might be the spec-r bd5 diff i have been running one in my tc5 i had to add a lot off shims to get it to fit but looks like it would fit the tc6 i will let you know i have a tc6 that should arrive thursday.
Old 11-30-2010, 05:55 AM   #757
Trader Rating: 114 (100%+)
Do the stock shafts and blades fit the BD5 SpecR diff?
Chris Furman is offline   Reply With Quote
Old 11-30-2010, 10:19 AM   #758
JuhoL's Avatar
You can put the link on either side depending on what bumbsteer you want. With 6degree caster you need to put in on that side to make the link level and have neutral bumbsteer.
I used 50wt AE shock oil in the diff.
The blades fit but the ball at the end of the driveshaft is slightly too big. You can either drill the out the outdrives or use a different axle.
I got the Yokomo version of the diff to test now but havent tried it yet. It is quite a bit lighter than the SpecR and in my opinion looks and feels like its better quality.
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
Old 11-30-2010, 02:04 PM   #759
WOW!
It is thin oil ... compared to diff ae 1000
Why so thin? Thick was bad ?
Can you tell advice?
About gear diff, from yokomo bd5 it is possible to put it to tc5, only one washer 0.7mm and some "dremel" job in joint.
Regards!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-30-2010, 04:34 PM   #760
The manual is up on the website now.
Old 11-30-2010, 08:50 PM   #761
STLNLST's Avatar
Nice to know all this info so once I get mine I can go straight to what works. The gear diff seems to be the way to go.
Old 11-30-2010, 08:58 PM   #762
BD5(mfg. by yok) diff fits, You need to grind the ball of the bone or drill out the cups. the blades fit with just a little sanding. Keven and I ran 80 wt ae oil at the champs.
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 11-30-2010, 09:00 PM   #763
haywood's Avatar
Trader Rating: 48 (100%+)
Default Tc5
Most the guys that run the TC5 at my track run Photon gear diffs. TC6 would be the same I would think.
haywood is offline   Reply With Quote
Old 11-30-2010, 09:01 PM   #764
STLNLST's Avatar
Any shimming needed or is it a direct drop in like it was made for the TC6? So we can keep the AE drive shafts and blades and just sand the outdrives so the blade fits???
Old 11-30-2010, 09:09 PM   #765
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Its a straight drop in, you can keep the drive shafts and blades, you will need to dremel a bit though.
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
