Old 09-11-2012, 03:48 AM   #7396
Originally Posted by evo8guy View Post
I am thinking about getting back into onroad and I am leaning towards the tc6.1. Are there any parts I should order for spares? what are the weak spots on the car? or anything you might recommend for upgrades? any help would be great.
After 4 national races here in Portugal and many practice days I have only broken 2 C-Hub's, replaced some front outdrives and replaced a knuckle because I stripped the threads on it. Besides that, I've gone trough a pair of belts and some blades, so this is basically what I would consider having at hand, maybe add some spare bearings in case you loose them or they seize when you break the knuckles.
As for upgrades, the RSD shock bladders are a must. They make the whole shock building process a lot easier. I can get zero rebound with ease, these are a great improvement over stock. I would also give their shock pistons a try. Also their springs are great match for the car. Although the car performs great out of the box, these are great tuning options that should get you going around the track easier.
z3zinho is offline   Reply With Quote
Old 09-11-2012, 10:52 AM   #7397
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Got a couple races on the 6.1 and am really liking the higher roll centers.. New lid in from Mike is really pretty cool also.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 09-11-2012, 07:06 PM   #7398
G4ZZ4's Avatar
Default LRP fan mount
Hi guys thought i'd share this I'm not too sure if it works yet I haven't tested it but at least I get to use the heatsink
cheers Garry
YOKOMO BD7, 21.5 boosted • M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 09-12-2012, 10:03 AM   #7399
Ammdrew, you mind sharing what your setup was and what you changed to? Thanks
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 09-12-2012, 10:08 AM   #7400
has anyone tried the higher roll center setup on carpet yet?
read that keven h was going to do that, any reports on how it worked out?
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Schumacher Cougar KF2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 09-12-2012, 12:57 PM   #7401
bertottius's Avatar
Trader Rating: 16 (100%+)
when you say "higher roll center" do you mean mounting the camber links higher on the shock towers?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 09-12-2012, 12:57 PM   #7402
AM03GT's Avatar
This works. I was doing this for a while using the short motor mount front bracket...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 09-12-2012, 02:32 PM   #7403
G4ZZ4's Avatar
Good stuff
cheers Garry
S2H bodies
Old 09-12-2012, 11:53 PM   #7404
ammdrew's Avatar
sure
http://www.rctech.net/forum/attachme...drewmowery.jpg
Old 09-13-2012, 06:15 AM   #7405
Default Modified Chassis
I used to race on road glow touring back in the mid 90's but got out of it and am in the process of getting back in and running electric touring; I have decided on the TC6.
Like my old car I had, I wound up spending close to $1,000 extra on after market parts and hop ups in order to compete at local tracks here in Houston.
I have noticed that there are some after market chassis, shock mods, body stiffeners, etc that one can buy to increase performance.
Question: if I plain to get back into racing like in the past, are these extra parts advisable?
Davinci7_gis is offline   Reply With Quote
Old 09-13-2012, 09:12 AM   #7406
CristianTabush's Avatar
A stock TC6 or 6.1 will be plenty competitive here in Houston out of the box. The only musts that I would advise for is a spring set, a fan for your motor and some RSD bladders. Other items are tuning options but not a total must have.
If you need some help with your TC6 and want to see your options, see me at M&m tonight or possibly Mike's this weekend. I will be more that glad to help.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 09-13-2012, 12:33 PM   #7407
Potoczak's Avatar
Trader Rating: 107 (100%+)
Hey guys when switching to the vertical camber links do i need a longer turnbuckle? If so what length do i need. thanks
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 09-14-2012, 03:44 PM   #7408
Fjeld's Avatar
Did try the high diff roll center to day. It did realy calm the car down did realy like it
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 09-14-2012, 03:55 PM   #7409
evochick's Avatar
Not needed just use the standard ones,
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 09-14-2012, 04:04 PM   #7410
R Doyel's Avatar
If you use the V3 position it extends the link pretty far. I put longer links on mine just to be safe. That way you don't run the risk of them stripping themselves out during an impact.
R Doyel is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
