Like Tree1Likes
Old 08-07-2012, 04:08 PM   #7261
evochick's Avatar
Originally Posted by losi888 View Post
How do u get all the play out of the front caster blocks and the rear hubs. I have a lot of play is this normal.
Team Associated TC6 Thread
there needs to be a sticky on this
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 08-07-2012, 05:15 PM   #7262
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Beth.
Beth, do you know if he shaved/notched the hinge pin so the screw sits in that notch rather than try to stay in the circular shaped pin? I ask because in my losi they are the same and I always loose them due to the movement of the pins but in my kyoshos they have flat spot notches where the screw sits and I have yet to loose one in half a year.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 08-07-2012, 05:57 PM   #7263
evochick's Avatar
I have been running the same setup for about 2 months without a notch in the pin,
I dont even bother with the screw that holds the pin in.
Here i just made sure the pin rotates freely in the arm, so the set screw is always holding it in the hub tight. i just check them after every meeting, but have not come loose just yet.
I used a 2.5mm drill bit and a 3mm set screw to get lots of thread bite on the screw.
Beth.
UnRetired
Old 08-08-2012, 04:55 AM   #7264
Team Grid RC's Avatar
We don't notch the pins so it is easier to install and remove, but we do use the pin retaining screws on the arms so the pins can't come out accidentally.
By the way TC6 racers, we just released our new single point servo mount for those that want to squeeze more performance out of their cars.
Team GRID Touring Car Performance Upgrades and Tools
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 08-08-2012, 06:04 AM   #7265
bigtez's Avatar
Having issues with my steering not centring on my TC6 and it seems the servo saver may be at fault. What is the best solution for this? Should I turn the servo as shown in the post below and add a Kimbrough or Associated servo saver? Whats the best way to attach the servo to the chassis? Epoxy or will tape surfice?
Originally Posted by P.I.M.P View Post
Hi guys thought i would share a pic of my servo turned gives better room for electrics and plus great for moving weight forward if needed have not tested to see how the car likes it so cant say if its for the best or not.but if going on how my t3 11 felt it should be a good mod.cheers
Attachment 782864
bigtez is offline   Reply With Quote
Old 08-08-2012, 06:19 AM   #7266
TIGHT more servo saver nut
use screw blue glue
or do servo mod
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-08-2012, 08:16 AM   #7267
Rick Hohwart's Avatar
Crank the servo saver nut to full tight and use a little loctite on it so that it does not come loose. Also be sure that there is no binding in your steering system. Pop the ball cup off the servo horn and make sure that you have bind free travel 100% in each direction.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 08-08-2012, 02:24 PM   #7268
cneyedog's Avatar
Send a message via AIM to cneyedog
Originally Posted by Rick Hohwart View Post
This is Keven Hebert's car but the spacing of the shocks just allows for more movement at the shock bushing. If the angle is too great there is not a lot of movement or play.
Rick, what size are the spacers Keven is using behind the shock mounts ? 2 MM ?
cneyedog is offline   Reply With Quote
Old 08-08-2012, 06:45 PM   #7269
bigtez's Avatar
Pulled the servo out and checked the steering system. It was smooth but not loose. Greased ball cups and freed them up a bit. Also noticed some marks on the servo case where the arm had been rubbing, so I shaved that down. Also tightened the servo saver right up.
Steering seems much better, but won't be able to test it til next week, but hopefully that has solved my issues. Thanks for the help.
Old 08-08-2012, 08:11 PM   #7270
Default FREE flex mod for Lipo battery
If want your TC6 to handle like a dream, then give this FREE mod a try. We discovered it while developing our single point servo mount.
Your battery is one of heaviest items strapped onto the chassis, that is also preventing it from flexing freely as well.
www.GridRC.com
Old 08-08-2012, 08:16 PM   #7271
Thumbs up NICE FREEBIE!!!!
Awesome Doing it now! Ordering servo mount later this week.
Peace,
Story Rice
DUALSKY RACING TECHNOLOGY - CKHOBBY - AshevilleRC
Story
Greenskeeper is offline   Reply With Quote
Old 08-09-2012, 01:12 AM   #7272
Johno's Avatar
how far up the shock shaft do you have the the turnbuckle eyelet???
www.sydneyrc.com
Johno is offline   Reply With Quote
Old 08-09-2012, 08:28 AM   #7273
I'm not sure what he uses but 2-3mm is the range. I use 3mm.
www.reedypower.com
Old 08-11-2012, 05:24 AM   #7274
cneyedog's Avatar
2mm spacer and 8mm screw to hold the shock mount and spacer in place ........ that'll work
Old 08-11-2012, 07:16 PM   #7275
Question - just built my TC6.1 and on first bench test spool up the rear (gear) diff leaked a bit of oil, not a ton, but enough to coat the rear belt. I think I may have overfilled it. The diff doesnt seem to be leaking anymore and offers smooth resistance when turning the wheels - do you think I need to rebuild? Or did it just get rid of the 'excess' oil?
Thanks in advance!
brgr56 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
