Old 07-16-2012, 07:23 AM   #7141
racer x 1's Avatar
Trader Rating: 27 (100%+)
no more shifting of the suspension blocks for 1. and id assume more traction overall as the chassis looks liek its going to flex more.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 07-16-2012, 07:34 PM   #7142
Rodrigo360's Avatar
Smile TC6 Spool
Hi, I want to show you my last mod to my TC6.1
Home Made "integral" Spooldrive
And the initial test video!
+ YouTube Video
Team Associated TC6.1 - Xcelorin 10.5T - Reedy - XP
Rodrigo360 is offline   Reply With Quote
Old 07-17-2012, 05:29 AM   #7143
29TC's Avatar
Send a message via ICQ to 29TC
How long are you guys building your TC6.1 shocks?
Can someone measure the bottom of their shock body to the tip if the ball joint.
Thanks in advance.
29TC is offline   Reply With Quote
Old 07-17-2012, 02:08 PM   #7144
Holmenkollen's Avatar
Im thinking of getting a TC6.1, I race modified. What parts do I need except the car to stay competitive? Do the car have enough steering with a modified motor? I used to race a Corally and that car was quite a handful to drive in modified with a constant on-power push and lack of low speed steering....
Serpent - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 07-17-2012, 02:20 PM   #7145
geeunit1014's Avatar
I think the car is very good as is out of the box in mod. You may want the vertical ballstud bulkhead caps, swaybar set, and a spring set to give yourself tuning options, but there are no real "mandatory parts" you need to make the car be competitive.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-17-2012, 03:40 PM   #7146
bhambrent's Avatar
http://www.ppdbillet.com/dial-a-grip.htm These make block changes so much easier, best thing I have got for my tc6.1.
http://www.reflexracing.net/AE-TC6-U...s_c_4-3-3.html Piston and bladders.
And your good to go.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 07-19-2012, 09:57 PM   #7147
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
So I'm new to this tc6 crap I'm about to go race tomorrow for first time in gt3 brushed class and this damn motor mount is garbage? Is there a special mount I have to get that allows a silver can gear mesh djustment? Can anyone guide me the right way? I'm about to go run this turd over one thing after another
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 07-20-2012, 02:35 AM   #7148
wtcc's Avatar
I don't know of any after market motor mount. Also never anybody ever complained about it in this thread. Do you have to use regulated Spur/Pinion sizes? How come you don't get it set properly?
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 07-20-2012, 03:26 AM   #7149
My friend, just cut off some material from silvercan busing case, I did it before for HPI saturn 20/27T engines.
Just use file
Wish you good luck!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-20-2012, 06:07 AM   #7150
Rockin G's Avatar
I have a 27T brushed on one of mine and have no problems adjusting for mesh. What Spur are you using? You might have problems with the 80T spur. I have the 72 on mine and dont have any problems getting it to mess with the range of pinions I mess with, arount a 36.
Rockin G is offline   Reply With Quote
Old 07-20-2012, 06:51 AM   #7151
Mr.juarez's Avatar
The bushing case on the motor sits on the oval part of the mount and the holes do not line up for the motor screws.
I'm using the 80-87 with 31 pinion as that's what I was told for fdr
I grinded the motor mount aj the bushing case drops more but still needs more
Old 07-20-2012, 06:55 AM   #7152
Mr.juarez's Avatar
I had a 17.5 in it before with 94-47 64 pitch but I wanted 48 as the track doesnt get swept and I dont want to be changing them often as 48 pitch
Old 07-20-2012, 08:54 AM   #7153
Rockin G's Avatar
Which holes are you trying to hit? I have mine in the forward hole and the bottom hole. I dont remember if that location raises the motor up a bit or not. Our 27T class uses the Axial 27T as the spec motor. I am not sure if there is a size difference in the shaft bushing.
Old 07-20-2012, 09:15 AM   #7154
YoDog's Avatar
Trader Rating: 26 (100%+)
I'll be at the track tonight and I'll be happy to help out.
Using 2 screws is probably the way to go and I'd have to say that you will want to use a smaller spur gear to get the right spacing. What FDR is suggested?
We can always come up with a different combination that will both fit and give you the FDR you are looking for.
I have a bunch of 48 pitch stuff so I think we can find the right combo.
YoDog is offline   Reply With Quote
Old 07-20-2012, 12:47 PM   #7155
whiteflagwar's Avatar
Anyone running the one-way spool? I'm running on high grip carpet and could use a little more steering while on the brakes, do you guys think it's worth trying?
whiteflagwar is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
