Like Tree1Likes
Old 07-02-2012, 04:16 AM   #7066
Trader Rating: 32 (100%+)
Hi,
Just checking if any one here has tried the AE 6443 Bleeder Shock Caps 1/10???
Kindly share your experience.
Thanks.
hobbs is offline   Reply With Quote
Old 07-02-2012, 09:35 AM   #7067
Rick Hohwart's Avatar
Originally Posted by geeunit1014 View Post
Thought Id share my mod setup from this past weekend's cash race at Jackson RC. TQd and won Mod. You can find the setup here
Thanks for posting this!
Originally Posted by R Doyel View Post
Thank you! What kind of tool do you use to do this?? A small metric ruler?
I guess when I've seen people talk about measuring uptravel, this is what they're reffering to??
Greatly appreciated.
As mentioned you can use a ride height gauge. An easy way to do this is to set your ride height first (5mm for example). If you want your droop 2mm above right height. Place the ride height gauge under the back of your chassis and place the chassis on the 7mm mark. Then adjust the droop screws until the tires just touch the ground.
Originally Posted by hobbs View Post
Hi,
Thanks.
These caps have a different thread pattern than the TC6 shocks. However they will work on the TC5 shocks.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 07-02-2012, 09:56 AM   #7068
Infinite 12th's Avatar
Default FOR SALE
Some great prices on a TC6 with parts at this link. Other stuff is also for sale
Brand new Associated 12RC5.2 inline, Used TC6, Futaba 4PL, and TP charger
Enjoy your racing
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 07-02-2012, 12:43 PM   #7069
Default RSD021 RSD AE TC6 Double Cardan Joints
$30 including shipping world wide
You get the dcj's + the special wheel adapters.
All brandnew, never been used, in original packing.
Say the word and I'll ship immediately.
Payment via PayPall if possible.
Kensei is offline   Reply With Quote
Old 07-02-2012, 02:44 PM   #7070
Suspended
Trader Rating: 86 (100%+)
can anyone please explain which inner camber link hole on tower, short or long ball stud and shims under ball stud to use?
i have been using what the team drivers used but i have no idea when to
add or remove shims or choosing the right inner camber positions
also how would i know is my droop or camber is too little or too much?
thanks for your help
littlealex is offline   Reply With Quote
Old 07-02-2012, 07:24 PM   #7071
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
I just rebuilt my TC6.1 shocks and noticed they feel a bit 'stuck' when on the car. What should I check in the shocks? The suspension arms themselves are moving freely. I am running the RSD bladders and pistons.
Also, how long should I build the shocks out to?
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 07-02-2012, 07:31 PM   #7072
Suspended
Hey everyone, I'm looking in getting a gear diff for the front of my tc6.1. I race at medium/low traction open asphalt track. I am stumped on what diff fluid would be good. I want something thick, I'm only really looking for the diff to slip under extreme loads in the corners. example: If I'm racing someone hard into a chicane for position. I was thinking 100,000wt. I have never used a gear diff so I don't know if 100,000wt is too thin. I was looking at OFNA diff lock. I'm afraid that might be waaaay to thick. . If anyone has any insight on this and could help I'd greatly appreciate it.
Chassis: AE Tc6.1
Class: USVTA
Thanks!
Ant Mitchell
Jedi Master
6x IPPA Pog Champion
Biggie85 is offline   Reply With Quote
Old 07-02-2012, 08:05 PM   #7073
Trader Rating: 49 (100%+)
Chassis: AE Tc6.1
Class: USVTA
Thanks!
I know in 17.5 blinky we were running 35wt shock oil, seems to be working fine for me. You could try that and see how that works for you. A local fast guy is running 1000 cst. That should be an okay starting point.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 07-02-2012, 08:55 PM   #7074
geeunit1014's Avatar
Check the O rings. They swell over time. IIRC I think I did mine to 63mm from the top of the cap to the bottom of the shock end.
Chassis: AE Tc6.1
Class: USVTA
Thanks!
If you want to go with a front gear diff, get the thickest oil you can find. A couple companies do 500K, and I think ive seen exceed with 1 and 2 million cst.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 07-02-2012, 09:47 PM   #7075
Suspended
Thanks, Quick question, do you mean 500k WT or CST? Kyosho has 500k wt. diff fluid.
Ant Mitchell
Jedi Master
Old 07-03-2012, 02:14 PM   #7076
LasagnaCat's Avatar
Trader Rating: 141 (100%+)
Send a message via AIM to LasagnaCat
The Traxxas 500k (part #5039) is often the easiest one to find, and runs six or seven bucks.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 07-03-2012, 11:53 PM   #7077
JS
JS's Avatar
Trader Rating: 70 (100%+)
I finally took the dive and entered the world of on-road sedan.
Picked up the TC6.1 and waiting for its arrival.
Been researching the thread and had a few questions for you guys.
Will be running 17.5 Blinky with a Revtech and Tekin RS.
Here is what I gathered so far:
FDR should be around 3.5-3.7 - Start with 96/52
Timing on the can about 1 notch back from max.
Which rotor should I use with the Revtech? Stock or HT or ?
Servo - I have a 1258 I can use or will the 1251 be a better choice?
thanks
JS is offline   Reply With Quote
Old 07-04-2012, 04:11 AM   #7078
Suspended
Anyone?
Old 07-04-2012, 08:08 AM   #7079
Anyone?
I would start with whatever link position you ran on the shock tower (1/3 are V1, 7 is V3), and shims to make it close to what you ran on the tower, and then go form there.
Mike Gee
Old 07-04-2012, 10:59 AM   #7080
Madulla's Avatar
thanks
I ran the 1258 fine in stock, but found the glitching problem when running mod with a spectrum radio. Switched to a 1251 and the problem went away. The 1251 must draw less power from the bec. I like the 1251 and run it in every car I own.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
