Like Tree1Likes
Old 06-14-2012, 01:36 PM   #6961
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by nitrous36 View Post
For the guys running 17.5 stock motors(no boost) what gear ratios are you running? EX: 4.59, 4.87, 3.90 etc
I run mine at 4.09:1 96t spur 47t pinion, 64 pitch.
I have an LRP Stock Spec 17.5 timing 4dot and a Stock Spec ESC blinky mode. My car is as fast or faster (down the straight) as any of the other cars. The temps are good. I have run the same gearing on asphault and carpet with no changes.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 06-14-2012, 08:52 PM   #6962
jhautz's Avatar
Trader Rating: 85 (100%+)
Im going to try to run a 72 or 68 spur on there.
edit: OK. I think Im going to run a 69/39 setting. That will give me a FDR(not the president) of 3.54
Thats exactly the gearing I'm running. 38. if its a tighter layout.
jhautz is offline   Reply With Quote
Old 06-16-2012, 05:31 AM   #6963
rcracer947's Avatar
Default tc6
Hey guys looking at doing a bit of on road and looking at the tc6 just wondering if these are imperil or metric hardware ?? Thanks in advance
Kyosho RT5|LRP SXX|X12 8.5T
Kyosho RB5 wc|LRP SXX| X12 8.5T|Kyosho SC-R SP|LRP SXX TC| X12 7.5T
Kyosho mp9 tki2 ,OS Speed,KO-PROPO,NITRO X,AKA
KO-PROPO SERVOS & KO EX-10 EURUS D.D.S
rcracer947 is offline   Reply With Quote
Old 06-16-2012, 06:06 AM   #6964
TC6 & 6.1 are Metric.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 06-16-2012, 12:05 PM   #6965
Default need help "NEW"
hey guys my name is Roddy.I just got a used TC6 and will eventually turn into a TC6.1.Here's what i need help with i been out of RC for a while and only bashed,now i want to get into on-racing both carpet and asphalt.since i been out they had a lot change and now I'm totally lost.I never seen so many options available with all the esc and i don't know which one to choose.here's my thing i do have a budget in a way,then don't.i know everybody usually get the tekin or mamba max,but i want to be different i would like to know which esc out of all the manufactures that would best fit the tc6/6.1 and that has the best features period.Also i can not choose the esc that best fits my driving style cause i never been on the track yet.I have been looking at the speed passion reventon s and r,the viper,hobbywing xerun v3,novak,tekin,lrp,vampire racing esc,orion,losi almost all of them.if you guys can tell me the pros and cons of each that you use and the features on then it would be very helpful for me
Thanks,
Roddy
Mr.Louisiana is offline   Reply With Quote
Old 06-16-2012, 12:39 PM   #6966
Madulla's Avatar
It all depends on the class you are going to run. Need more info. VTA vs Mod is a completely different answer.
Hobbywing North America Team Driver
hobbywingdirect.com
CARCAR VP carcar.ca
Madulla is offline   Reply With Quote
Old 06-16-2012, 02:01 PM   #6967
sorry that what i forgot.i want to run either vta and 17.5 to start out then move up to like 13.5 and mod classes
Old 06-16-2012, 05:54 PM   #6968
dirtydan's Avatar
Trader Rating: 47 (100%+)
Hey guys I have a question about setups. I have a tc6.1 and im running the box stock setup at the moment. I like the way the car feels with a few exceptions. My f/r camber is -2 and toe is at +.5. Shock oil is 40wt losi f/r and I'm running 35wt losi in gear diff. I would like the car to have more steering, and also rear traction as the rear drifts around corners. What adjustments would I need to do? I'm running 17.5 blinky with full timing and 96/52 on a medium to large asphalt track in hot weather. Any tips would be appreciated.
!!!!The Rc Assassin!!!!
Kyosho RB5 SP2 WC
S811 B-E 2.0
S811 B-TE 2.0
Serpent America ~ Crown Hobbies ~ Desoto Racing ~ VP Pro ~
dirtydan is offline   Reply With Quote
Old 06-16-2012, 09:34 PM   #6969
LasagnaCat's Avatar
Trader Rating: 138 (100%+)
Send a message via AIM to LasagnaCat
Longer rear camber links...
less rear droop...
less front camber...
slightly lighter rear shock oil and/or spring...
play with the dual rate on your radio...
lots of things to try.
If you're losing traction in the rear you already have too much steering.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 06-16-2012, 09:55 PM   #6970
dirtydan's Avatar
less rear droop...
thanks for the suggestions. the only pushes when its on power, and loses rear traction off power during hard turns. it doesn't spin out, but it tends to slide the rear around the turns and slows me down. so to clarify off power steering is great, but the mid corner on power steering is lacking. i think i might have the droop at 6 when it should be at 5 and maybe thats it. im also thinking of going to 37.5wt losi oil and see how it reacts. ill try 1 at a time and report back.
Kyosho RB5 SP2 WC
S811 B-E 2.0
S811 B-TE 2.0
Old 06-16-2012, 11:33 PM   #6971
jhautz's Avatar
I felt the same way with the stock setup. The green rear springs, 35wt losi oil all around and adding another degree of rear toe made a big difference in locking the rear end in off power.
Old 06-17-2012, 02:55 AM   #6972
thats what i changed too in my setup, also change the droop to 5, that will make a huge difference
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 06-17-2012, 09:15 AM   #6973
vito's Avatar
do need to run droop in the street? i just play
vito is offline   Reply With Quote
Old 06-17-2012, 11:18 AM   #6974
Why is it that every kit comes with a spool and rear diff now?
If the problems with wheel chatter are known due to spools, why not provide DCJ's from the mfr or at least with the kit?
Since gear diffs pretty much eliminate the possibility of slipping, why is there really a need for a spool in the front ? I suppose under low traction conditions i can see but wouldnt a diff provide better steering in med to high traction situations?
I have been driving a spool/rear diff for some time now and am considering trying a gear diff up front. Has anyone tried this with any success or is the spool really needed?
wcalaker is offline   Reply With Quote
Old 06-17-2012, 12:48 PM   #6975
Infinite 12th's Avatar
Wink
TC6 for sale in pretty good shape
Includes:
Entire rolling chassis with yokomo gear diff, Springs, spare parts and some bearings
LRP TC Spec speedo with fan and deans plug
Thunder power battery with deans plug - 5300/65C - no puffing
Super heavy duty Hitec servo - HS-7950TH - High Voltage Torque
Futaba receiver - R2104GF
Make me an offer for everything via pm
Will get pictures as soon as I can borrow an camera!
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
