Like Tree1Likes
Old 06-13-2012, 10:30 AM   #6946
AJSanDiego's Avatar
Originally Posted by Rick Hohwart View Post
This is how most of the team guys run their tape. It does not go under the battery.
What kind of tape works best? I have the lipo velcro'd to the chassis and hadn't though about how it raises the center gravity load.
AJSanDiego is offline   Reply With Quote
Old 06-13-2012, 10:45 AM   #6947
Maybell's Avatar
High quality fiber strapping tape. If you get the good stuff, one piece can last quite a while. Sliontech and Hudy for example. I think the sliontech stuff is sold in a Integy package in a few colors.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 06-13-2012, 04:05 PM   #6948
Team Grid RC's Avatar
If you find any play on the front or rear suspension it would be from the rear hub or front C hub. The pins need to be pinned to tighten things up. On a XRay, the hubs are pre drilled for a set screw.
On the TC6, you can drill a 2.5mm small hole and put in a M3 setscrew to pin the pivot pin. It works great.
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 06-13-2012, 04:09 PM   #6949
Originally Posted by rbcts View Post
Good stuff. For anyone using these, what is the correct size strap for this car?
Also the top racing strap doesn't go under the battery. Just FYI.
http://www.amainhobbies.com/product_...nt-Strap-Black
Any strap that is 21mm or less in width will work. Ours is 21mm exactly.
www.GridRC.com
Old 06-13-2012, 06:49 PM   #6950
WD40's Avatar
Does anyone know of an aftermarket harder than stock foam bumper that is also wider than the stock one? The stock one doesn't even cover the front suspension at all....I might as well just take the thing off.
WD40 is offline   Reply With Quote
Old 06-13-2012, 06:57 PM   #6951
LasagnaCat's Avatar
Trader Rating: 137 (100%+)
Send a message via AIM to LasagnaCat
Parma TC5 ultimate bumper should fit
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 06-13-2012, 07:00 PM   #6952
Trader Rating: 49 (100%+)
The Parma bumper needs to be modified slightly because it is such a tight fit on the bumper bracket. It wants to tear one of the holes. I got one because it's supposed to help with saving front end parts, ended up with a torn bumper because it was too tight. Didn't hit anything more than normal. Maybe I got a bad one?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 06-13-2012, 10:02 PM   #6953
Default question
hi guys i recently get a tc6.1 ad the reedy 13.5t reedy sonic... i am new in 1/10 electric so i dont have any clue aout the gearing... what pinion should i buy ( its for a medium small track)...
thanks
segreda is offline   Reply With Quote
Old 06-13-2012, 11:28 PM   #6954
Regional Moderator
nitrous36's Avatar
For the guys running 17.5 stock motors(no boost) what gear ratios are you running? EX: 4.59, 4.87, 3.90 etc
nitrous36 is offline   Reply With Quote
Old 06-13-2012, 11:37 PM   #6955
Trader Rating: 32 (100%+)
I have gone to as low as 3.3 (approx).
But I prefer to run it at around 3.5
Be sure to check your motor temp from time to time.
hobbs is offline   Reply With Quote
Old 06-13-2012, 11:47 PM   #6956
piper48
Guest
Posts: n/a
3.5 to 3.7 with a 96t 64 pitch Spur with a D3 and LRP SS.
Old 06-14-2012, 01:42 AM   #6957
Hiya
Are you running Boost or Blinky ?
Boost i run 7.2 (82/23) blinky i run 3.8 (68/35) with the reedy 13.5 with the motor timing at 20
Ed
thanks
Edwin Pibal is offline   Reply With Quote
Old 06-14-2012, 09:30 AM   #6958
Regional Moderator
nitrous36's Avatar
Im going to be running 17.5 blinky(no boost/no timing). After building the kit and looking at the gearing chart(in the book), it was clear this car was intended for modified motors. And after reading the gear chart its clear I cant and want be using the 87t spur that came in the kit with a 175.5 motor.
I searched online, read the charts and did the math. I cant believe the 17.5(w/timing) needs a gearing so high. So now Im debating if I should get a 72, 75, or 77 spur. That would allow me to gear the motor for 3.5-4.0
Old 06-14-2012, 09:37 AM   #6959
Rockin G's Avatar
For comparison, I have an 80/35 on mine and I dont think I could squeeze a 36 on there. I am at the end of the slotted motor mount. 17.5 Blinky
Rockin G is offline   Reply With Quote
Old 06-14-2012, 11:40 AM   #6960
Regional Moderator
nitrous36's Avatar
Im going to try to run a 72 or 68 spur on there.
edit: OK. I think Im going to run a 69/39 setting. That will give me a FDR(not the president) of 3.54
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
