Like Tree1Likes
Old 06-12-2012, 06:57 PM   #6931
Chaz955i's Avatar
Originally Posted by nitrous36 View Post
I know the tape goes over the battery. Im talking about using velcro under the battery.
Why, a proper tape job is reusable and doesn't raise the center of gravity?
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 06-12-2012, 07:26 PM   #6932
LasagnaCat's Avatar
Trader Rating: 140 (100%+)
Send a message via AIM to LasagnaCat
Smile
How do some of you guys mount your batteries in the chassis. I thought about using velcro between the batt and chassis instead of tape. That would be cheaper/reusable and easier to mount or remove the battery between charges. But is or would that be legal for racing? I dont know if tracks would allow it.
My other concern is that the velcro may raise the battery slightly higher, effecting handling and weight distribution.
Look at the Puretech straps... much better option than most of the standard velcro straps. The part of the strap that goes under the pack is super thin, the thicker velcro part is on top. You can very easily snug the pack down with this strap without going Hercules tight.
http://www.puretechproducts.com/ptprod_straps.htm
Pic at the bottom shows how thin these straps are.. good stuff.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 06-12-2012, 07:32 PM   #6933
Regional Moderator
nitrous36's Avatar
Good point.
Thanks. Ill have to check those out.
nitrous36 is offline   Reply With Quote
Old 06-12-2012, 07:35 PM   #6934
vito's Avatar
need a good motor and esc set up that will run 70 mph
vito is offline   Reply With Quote
Old 06-12-2012, 07:45 PM   #6935
rbcts's Avatar
Trader Rating: 34 (100%+)
Good stuff. For anyone using these, what is the correct size strap for this car?
Also the top racing strap doesn't go under the battery. Just FYI.
http://www.amainhobbies.com/product_...nt-Strap-Black
-AE FT RC8.2
-AE RC8T CE
-Kyosho RB5 SP2 WC
rbcts is offline   Reply With Quote
Old 06-12-2012, 08:02 PM   #6936
LasagnaCat's Avatar
The TOP strap isn't as nice. It's thicker, much less flexible, has to be pulled tighter, and is much more likely to cause tweak. The Puretech strap running under the battery is partly why you can get away with running it a bit looser... the strap is attached to itself, you can slide it back and forth with the battery in place. Since the Top style straps are attached to (and pulling against) the stock battery mounts - that's where the tweak can appear, you're pulling inward from the two end points.
Old 06-12-2012, 08:20 PM   #6937
LasagnaCat's Avatar
The bottom part of the Puretech strap is roughly .4mm thick... it's really not an issue or a worry running under the pack. You really can't tell it's running under the pack when it's in the car. The 5 inch strap is the right one, and you get a pair for the price. For any other old-timers, yes.. same Puretech that made the straps you may have run on your rc10/jrx2/etc. once upon a time.
Old 06-12-2012, 08:29 PM   #6938
rbcts's Avatar
Wow. Nice pic. I have to say it is much thinner than the top racing strap. Thanks for the info
-AE FT RC8.2
-AE RC8T CE
-Kyosho RB5 SP2 WC
Old 06-12-2012, 11:39 PM   #6939
racer x 1's Avatar
Trader Rating: 27 (100%+)
I really hope im not the first to discover this but the tc6.1 castor blocks do not fit straight on the tc6 without any grinding. Im a bit lost on that but nothing the dremel cant handle once charged should finally have my newly acquired tc6 in photographable shape tomorrow night.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 06-13-2012, 02:27 AM   #6940
Big Features's Avatar
First hears for me, other then a little wiggle (easily fixed with a set screw) I e haven't seen or heard about this issue. Are the caster block inserts pressed in all the way? This may be the case.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 06-13-2012, 03:53 AM   #6941
Chaz955i's Avatar
If I remember correctly the 6.1 arms are different than the 6 arms and have a wider opening.
At The Gate Bizzos
Old 06-13-2012, 07:01 AM   #6942
racer x 1's Avatar
Ha that they do but its ok i took care of the situation I just wish I knew and I would have bought .1 arms while i was at the hobby store.
Matt Bell
Old 06-13-2012, 08:29 AM   #6943
Rick Hohwart's Avatar
Default Tape
This is how most of the team guys run their tape. It does not go under the battery.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 06-13-2012, 09:37 AM   #6944
Trader Rating: 19 (85%+)
Originally Posted by WD40 View Post
Put a bead of glue around the outside edge of the tires. It helps....everyone is doing it at the track I raced at this past weekend.
A bead of glue on the sidewall of the tire? The inside or outside or both? And how thick of a bead ?
ChRIs MeNeAr TLR 22 2.0 ,22-4 AiRtRoNiCs M11x TEKIN TRINITY
SPONSORED BY MY CREDIT CARD LOL
AEcarpetracer is offline   Reply With Quote
Old 06-13-2012, 10:10 AM   #6945
WD40's Avatar
The outside only. It makes sense if you think about it. You are wanting to harden the outside of the tires so the car doesn't roll. The thickness is not the important thing....it's just a matter of making the outside hard enough for the car not to roll. When I did mine, I put a bead around it....then wiped it smooth to make a smooth hard surface on the outside of the tire. And my traction rolling went away for the most part (unless I was being super super aggressive). If that doesn't make sense then let me know and I'll try to get a picture up for ya.
WD40 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
