Like Tree1Likes
Old 05-30-2012, 10:37 PM   #6841
Originally Posted by rangerjkb View Post
vito: you'll get addicted quickly and it will improve your offroad abilities as well.
Or dare I say, you'll get hooked on the speed and precision, and lose interest in offroad? lol
red7fifty is offline   Reply With Quote
Old 05-31-2012, 08:13 AM   #6842
vito's Avatar
thanks . it will be here on the frist 1 of june
vito is offline   Reply With Quote
Old 05-31-2012, 11:45 AM   #6843
Man Im having issue after issue lol...
I took apart my D3 to do some maintenance, when I put it back together and hooked everything up to the speedo etc, the motor turned in the reverse direction...regardless of how I set up my radio....all wires are hooked up correctly.
Anyone know how I can reassemble it so that it spins forward...are there any indicators on the endbell and motor to say how to properly put it back together?
ChampRC is offline   Reply With Quote
Old 05-31-2012, 11:53 AM   #6844
Has nothing to do with a TC6, but check your sensor board.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 05-31-2012, 07:08 PM   #6845
vito's Avatar
what trun motor do i need. i just play in the street
Old 05-31-2012, 08:29 PM   #6846
cocojam's Avatar
Trader Rating: 47 (100%+)
Default Gear Diff Oil for TC6
What gear diff oil and weight is advisable for an asphalt track with medium traction? TIA
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 06-01-2012, 12:35 AM   #6847
Regional Moderator
nitrous36's Avatar
Hey guys. Im slowly building a TC6.1 and just completed the chassis a few days ago. Any heads up or suggestions you guys have would be appreciated. Im planning to start adding the electronics soon.
nitrous36 is offline   Reply With Quote
Old 06-01-2012, 10:09 AM   #6848
Two-speed's Avatar
Trader Rating: 24 (100%+)
Has anyone tried the stock 6.1 shock towers with the associated vertical ball stud mounts to see if they will work together?
Two-speed is offline   Reply With Quote
Old 06-01-2012, 11:20 AM   #6849
jhautz's Avatar
Trader Rating: 85 (100%+)
Im told the stock shock towers will work with the vertical ball stud mounts if you cut the bottom portion of the shock tower off that has the holes where the camber links mount to the tower. Other than that the new towers are the same as the old.
jhautz is offline   Reply With Quote
Old 06-01-2012, 05:31 PM   #6850
Regional Moderator
nitrous36's Avatar
Ive looked everywhere, are the Solaris spoked wheels no longer available?
Old 06-01-2012, 05:34 PM   #6851
geeunit1014's Avatar
They are very much available. Have your LHS contact TOP USA. Both the shops in my area have them in stock.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 06-01-2012, 05:45 PM   #6852
Regional Moderator
nitrous36's Avatar
Old 06-01-2012, 06:50 PM   #6853
vito's Avatar
i think i got some bad parts in the kit. i have 4 silver springs is this right? in the book its green and silver. theres no mark on the to tell what they are help?
Old 06-01-2012, 06:59 PM   #6854
The 6.1 comes with 4 silver springs. The manual might not have been updated from the 6 which came with 1pr silver 1pr green. If you look at the kit setup sheet for the 6.1 it should show silvers all around.
Mike Gee
Old 06-01-2012, 07:00 PM   #6855
vito's Avatar
will do ill go look now
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
