Like Tree1Likes
Old 05-15-2012, 02:10 PM   #6766
Mike Haynes's Avatar
The small bridge in front of where the steering post mounts and the small bridge just in front of the spur gear.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-15-2012, 02:56 PM   #6767
jhautz's Avatar
Trader Rating: 85 (100%+)
Like this?
I assume this increases flex and traction.
jhautz is offline   Reply With Quote
Old 05-15-2012, 04:04 PM   #6768
Yes, i liked just the front cut for carpet, seemed to keep the nose down in the corner better, on pavement cutting the rear seemed to help my car rotate better. Keep in mind there will be a large difference in how it effects your car depending on the rest of the setup, give it a try but i would recommend having an extra in case it doesn't fit your preference.
Old 05-16-2012, 04:26 AM   #6769
Losiho's Avatar
Originally Posted by Big Features View Post
The TC6 does come with a gear diff and solid front axle.
I think you mean TC6.1. My TC6 came with a rear ball diff.
Losiho is offline   Reply With Quote
Old 05-16-2012, 09:20 AM   #6770
Tower has the vertical ballstud mounts and shock towers if anybody is looking for them.
chuck
mackin is offline   Reply With Quote
Old 05-16-2012, 10:31 AM   #6771
Big Features's Avatar
Indeed, good catch. I was typing and thinking at the same time
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 05-16-2012, 12:42 PM   #6772
AJSanDiego's Avatar
Sorry in advance if this is a lame question and I think the answer is yes but want to make sure before going any further on my TC6.1 build. Arm Mount Shims = FWD and/or RWD Mount Shims? This is my first on road car and want to make sure I start off right. TIA and thanks for all the other stuff I've picked up here.
AJSanDiego is offline   Reply With Quote
Old 05-16-2012, 05:02 PM   #6773
Losiho's Avatar
chuck
At least Tower has them in stock on their website. I've been waiting for the new parts on the A Main website, and they simply say "search shows no product"
Has anyone tried the Zeppin Racing towers and bulkheads, and are they the same (in terms of geometry) to the Associated parts ?
Mike - no problem
Old 05-18-2012, 07:53 PM   #6774
lookieaefanboi's Avatar
Trader Rating: 37 (100%+)
Has anyone got a chart of what combinations of arm mounts produce what levels of toe? Yes I know I can measure it but I am at work Stock setup on rear 0 dot fwd and 0 dot offset rear produces 2.5deg. So what does 0 dot offset on both produce? Any help would be much appreciated.
lookieaefanboi is offline   Reply With Quote
Old 05-18-2012, 09:09 PM   #6775
hacker's Avatar
Trader Rating: 140 (100%+)
RTFM
hacker is offline   Reply With Quote
Old 05-18-2012, 10:05 PM   #6776
chevtech23's Avatar
Yes arm mount shims, FWD(forward) RWD(rearward) for that end of the car, you would run the same in the front forward and front rearward, and possibly different ones in FWD and RWD in the rear to adjust rear toe, along with a combination of offset and standard arm mounts.
I use these for the shims, Associated #3617
http://www.amainhobbies.com/product_...-Bulkhead-Shim
Hopefully this is a more helpful answer than "RTFM"
chevtech23 is offline   Reply With Quote
Old 05-18-2012, 10:08 PM   #6777
chevtech23's Avatar
If you run the same mounts fwd and rwd that would produce zero toe.
Again, hopefully a more useful answer than "RTFM"
Old 05-19-2012, 10:34 PM   #6778
WD40's Avatar
Can anyone post a good setup for medium grip concrete track for the tc6.1? It might be in this thread but I don't have time to look through 400 pages of posts. It will be a VTA and 17.5 class for reference.
WD40 is offline   Reply With Quote
Old 05-20-2012, 12:52 AM   #6779
Hi guys,
I've recently purchased a TC6.1 and have run it several times. I have noticed that the arms are rubbing on the inside of the wheels. Does anyone else have this issue or have any idea what may be causing it as I can't seem to find the problem.
RSD Spec TC6.1, Tekin RS, MMM, Savx, Sorex.
Steve89 is offline   Reply With Quote
Old 05-20-2012, 01:37 AM   #6780
Geberit's Avatar
Originally Posted by Steve89 View Post
Hi guys,
Same problem here.
It seems that the tires bend slightly under load when cornering.
Just locate the spots on the arms where the tire rubbed and sand them off a bit.
Geberit is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
