Old 04-24-2012, 06:53 AM   #6646
carl jr's Avatar
Hi I just got a 6.1 and wanted to know if anyone has any setups for rubber tire carpet.
carl jr is offline   Reply With Quote
Old 04-24-2012, 09:16 AM   #6647
Chaz955i's Avatar
rc10.com has a bunch of them.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 04-24-2012, 09:20 AM   #6648
Is there a way to keep the front belt from touching the rear part of the top deck?
MySlowZ is offline   Reply With Quote
Old 04-24-2012, 06:33 PM   #6649
LasagnaCat's Avatar
Trader Rating: 137 (100%+)
Send a message via AIM to LasagnaCat
Which diff cam holder are you using, and at what setting?
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 04-24-2012, 06:37 PM   #6650
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by LasagnaCat View Post
What were you using? We went through a few last year (at Leisure) that ranged from bad to worse until we tried and stuck with the LG2.
Sorry I did not see this... LG2, first time with it.... I was thinking this may be some of the problem, but after your post, that is not the issue.
So how does one tell if the belt is slipping? Could this be the cause of my handling issues?
bvoltz is offline   Reply With Quote
Old 04-24-2012, 07:32 PM   #6651
I'm using the stock settings. I sanded the top deck a little, hope this helps. When I replaced the front belt, the teeth was worned out in an angle. \|
Old 04-24-2012, 11:57 PM   #6652
Hi guys would installing a 4 deg caster block rather than my existing 6 deg block help me turn faster in the low speed technical section? I have had my steering knuckles flipped and anti dive making effective caster at 5 degrees. No anti roll bars at a med size asphalt track.
I was also thinking about adding ackerman. Would that help?
zzztech is offline   Reply With Quote
Old 04-25-2012, 01:22 AM   #6653
From my previous testing i would rather go to the ackerman option.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 04-25-2012, 02:52 AM   #6654
Can you please elaborate a bit on this option?
thx
Old 04-25-2012, 05:25 AM   #6655
Brother, do you mind to take a pic and point me out where is Ackerman for tc6? Thanks
~Team Associated AE TC6~ Disable
~Team Associated AE TC6.1~ SOLD
~Team Associated AE TC6.1WC~ Retire
Switching to YOKOMO ~Yokomo BD7~
**Swan Radio Control Club (SRCC)**
icefish is offline   Reply With Quote
Old 04-25-2012, 01:12 PM   #6656
IndyHobbies.com's Avatar
I've been keeping the belt on mine a little tighter than I did on my TC5 for that reason.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 04-25-2012, 02:05 PM   #6657
I dont have the problem that the belt is touching the rear. Isnt your deck tweaked?
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 04-25-2012, 03:55 PM   #6658
thx
I could elaborate here for 10 pages, but in the end it's all on practice. So there's nothing like you try it.
it's all on page 26 of the manual of the TC6.1 and on page 23 of the TC6, if you need more help say it.
Team AME/ORCA
Old 04-25-2012, 04:37 PM   #6659
jhautz's Avatar
Trader Rating: 84 (100%+)
Hey. I just got a TC6.1 kit and put it together. I'm trying to gear it for blinky 17.5 and I'm being told that I should start around 3.6-4.0 FDR at the track I'm going to run. So i got the optional 72T spur gear but with that gear there isn't holes in it like the stock 87T gear so I cant get to the back motor mount screw to tighten it down? I thought about drilling a hole in it to allow myself to get to the front motor screw, but Im afraid it will need to be to close to the actual teeth of the spur and it will weaken it. I see there is another screw hole that lines up with the bottom screw on the motor. Should I be just using the front and bottom screw? Or is there another solution I'm not seeing to be able to tighten the back motor screw?
Thanks in advance for the help.
jhautz is offline   Reply With Quote
Old 04-25-2012, 04:55 PM   #6660
Losiho's Avatar
Yes, use the 3rd mounting hole (bottom hole) when using small size spur gears.
Losiho is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
