Old 03-27-2012, 02:56 PM   #6361
Maybell's Avatar
Originally Posted by BlackStarRacing View Post
ok so don't use the shims with the horseshoe shape?
You can use them, but I wouldnt recommend using them for long. IMO and long story short, they are made from too soft a material. Most of us use aluminum #4617 shims.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-27-2012, 03:00 PM   #6362
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
ok I'm putting in an order tomorrow ill grab some.....
I'm trying to adjust ride height...i do this by adjusting the shocks correct?
Hey man thanks for all your info!!!
Daryl
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-27-2012, 03:05 PM   #6363
Maybell's Avatar
Daryl
Yes, you adjust the collars/nuts on the shock body for your height. Order yourself a pack of #31305 turnbuckle eyelets and use them instead of the ballcups for your shock shafts. They fit better and they are longer witch is better for a couple reasons.
Old 03-27-2012, 03:19 PM   #6364
Got it ill add them to my cart on Associated Warehouse! What are some of the other parts i should have in back up...I know C cups i broke one the other day so I'm ordering those as well.....?
Old 03-27-2012, 03:26 PM   #6365
Maybell's Avatar
Yeah, I would order some caster blocks, driveshaft blades and rear hubs for the most part. Extra arm mounts wouldnt be a bad idea either.
Old 03-27-2012, 04:35 PM   #6366
Hey appreciate all the info...hope you don't mind me picking your brain! lol
What system are you running in your TC6?
Thanks again
Daryl
Old 03-27-2012, 05:19 PM   #6367
Maybell's Avatar
Thanks again
Daryl
No problem!
I run the LRP SXX TC Spec speed control and Reedy Sonic motors.
Old 03-27-2012, 05:38 PM   #6368
No problem!
Ok i have the Stock version 2 w/ firm ware 3 i think just purchased it from amain! I'm running a 13.5 but i haven't been able to get it programed correctly!
Counting colors lol!
I think I'm going to grab a 6.5T X12 model!
Old 03-28-2012, 05:48 AM   #6369
Default MISSING SCREWS
HI GUYS,
I AM BUILDING THE TC 6.1 AND I SEEM TO BE MISSING SOME SCREWS.. HAS ANYONE HAD THE SAME PROBLEM
CHEERS
gazzazh is offline   Reply With Quote
Old 03-28-2012, 06:03 AM   #6370
tmaxx26power's Avatar
Trader Rating: 39 (100%+)
Originally Posted by gazzazh View Post
HI GUYS,
CHEERS
Call their customer service, they will take care of you.
Kyosho RB6 Stock Buggy
Kyosho ZX6 Mod 4wd Buggy
Kyosho SC6 Pro2
tmaxx26power is offline   Reply With Quote
Old 03-28-2012, 07:00 AM   #6371
HenryC's Avatar
HI GUYS,
CHEERS
Sometimes you need to look in other parts bags to find the screws required for the section of the build you are on. I thought I had been shorted as well until I found the needed screws in a different parts bag.
HenryC is offline   Reply With Quote
Old 03-28-2012, 09:24 AM   #6372
easye's Avatar
HI GUYS,
CHEERS
Id also!!
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
leisure hours hobbies and raceway. Ez duz it customs.
Al Richards #1 fan Mr.Mellow #5 fan
easye is offline   Reply With Quote
Old 03-28-2012, 09:38 AM   #6373
tha Beast's Avatar
Trader Rating: 100 (99%+)
do any of you guys know if the Dial-A-Grips are still available?? im looking for some but ive had no luck
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
tha Beast is offline   Reply With Quote
Old 03-28-2012, 11:11 AM   #6374
Big Features's Avatar
Why do you need these? I've had minimal movement using the offset suspesion mounts and/or 12R5.1 bulkhead shims.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 03-28-2012, 01:57 PM   #6375
tha Beast's Avatar
Mike
i just want to try them out i hear good things about them.
does anyone know the guy that makes them i cant remember his name
REFLEXRACING
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
