Like Tree1Likes
Old 03-26-2012, 01:22 PM   #6346
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Originally Posted by JustWill75 View Post
I currently race with a TC6 in VTA and was wondering do I have to convert it to a TC6.1 before I can use DCJ'S? Im thinking about using the hotbodies or soon to be released Reflex racing ones.
You can use the hotbodies DCJ on the TC6 with the stock steering blocks, castor blocks (must be dremeled open), blades (must be drilled to a wider diameter), and front arms. I didn't have to buy any TC6.1 parts to do the conversion on my kit. What you will need are 2x10mm drive pins (should come with most wheel hex kits), 5mm shims to space the drive pin/bearing (I used Tamiya shim kit), 5x10x3 bearings (quantity 4 from AvidRC), and new hexes (I'm using Yeah Racing 5mm hexes).
This is how I had mine setup originally but I wanted to move over to a more standardized bearing size so I got a pair of TC6.1 steering blocks and crush washers. This allowed me to use the more popular 5x10x4 bearings which I have from other cars.
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 03-26-2012, 07:00 PM   #6347
StewartFan20's Avatar
What is the reasoning for going from 6x10 to 5x10 bearing in the rear hubs and steering knuckles?
Thanks in advance.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 03-26-2012, 07:05 PM   #6348
ekim628's Avatar
The hotbodies DCJ's have a different size axle diameter.
Thanks in advance.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 03-26-2012, 07:44 PM   #6349
Yes, I understand that the Hotbodies DCJ's have a different axle size. I'm wondering why Associated went from 6x10 in the TC6 to 5x10 in the TC6.1. Associated made the change for some reason, I'm just wondering why.
Thanks.
Old 03-26-2012, 08:03 PM   #6350
CristianTabush's Avatar
The 5x10 bearings have larger balls, so they are more durable.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-27-2012, 04:01 AM   #6351
Thanks kind of what I though, but I didn't know if there is a performance reason also.
Thanks.
Old 03-27-2012, 07:12 AM   #6352
Trader Rating: 38 (100%+)
Thanks.
Yes, bearings that aren't broken perform better
or8ital is offline   Reply With Quote
Old 03-27-2012, 10:13 AM   #6353
Thanks.
The 5x10x4 bearing better supports the axle due to the extra width compaired to the 6x10x3.
Kyle GSR is offline   Reply With Quote
Old 03-27-2012, 10:38 AM   #6354
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Adjusting rear toe
trying to figure out how to adjust the toe in? is it mechanical or a part that is needed I'm following a couple of setup guides from racing in jacksonville florida which would be the closes to what i will see this summer....Currently using my setup station I'm at 1 degree toe in need to get it to 2.5...
Thanks guys!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-27-2012, 11:10 AM   #6355
geeunit1014's Avatar
Thanks guys!
You need to adjust how many shims there are between the two rear arm mounts. For 2.5*, you will want about 2mm more shims on the rear rear arm mount than the front rear arm mount
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-27-2012, 11:10 AM   #6356
Maybell's Avatar
Thanks guys!
Inboard toe would be increased by adding shims to the arm mounts. You can also increase outboard with your rear hubs, but we usually only run inboard rear toe these days.
Check out the "arm mount position" section on page 27 in the TC6.1 manual.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-27-2012, 11:13 AM   #6357
Ok so i have two silver squares on the rear should i place the shim there? do i use the plastic ones that came with it?
Old 03-27-2012, 12:30 PM   #6358
Old 03-27-2012, 12:46 PM   #6359
Maybell's Avatar
We are increasing the angle of the inner hinge pins by adding shims to the 2 arm mounts that are closest to the rear of the car. The arm mounts are the "square ish" shaped plastic parts that you slide a Arm Mount Bushing into. If you add shims inbetween those arm mounts and the bulkheads, this increases the angle of the pins, therefore increasing your rear toe-in.
Old 03-27-2012, 01:36 PM   #6360
ok so don't use the shims with the horseshoe shape?
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
