Like Tree1Likes
Old 03-25-2012, 12:47 AM   #6331
sorry for i know it's not suit for the thread, but i really can not found where to ask.
my question,
I'm running on a lrp 4.5T x12 octa wind motor on my TC6, with 87 spur, 19 pinion, after few round (not complete 5 minutes) the motor heat to around 8x-9x degree, but even if i make it finish 5 minutes race with around 16-17 round, the heat still maintaince at 8x-9x degree, is there any problem with the heat on this figure? how to drop down the degree or what temperature should i maintaince for motor good health? Thanks for the help.
~Team Associated AE TC6~ Disable
~Team Associated AE TC6.1~ SOLD
~Team Associated AE TC6.1WC~ Retire
Switching to YOKOMO ~Yokomo BD7~
**Swan Radio Control Club (SRCC)**
icefish is offline   Reply With Quote
Old 03-25-2012, 12:55 AM   #6332
Your probably too hot (over geared) Drop to a smaller pinion.
Check your motor manual....most brushless motors, temp should be 160~175 F maximum. (my motors, after 5 minutes, 125*F
85*C, = 185*F.....that is above the maximum temp for most motors.
red7fifty is offline   Reply With Quote
Old 03-25-2012, 01:00 AM   #6333
what pinion should i gear then? 18?
seen my gear ratio at the moment is 9.16 with 87 spur and 19 pinion, if gear smaller pinion again, i will move up to 9.6 gear ration, i will lost my top speed then...even with 9.16 my top speed already very bad.
Old 03-25-2012, 04:01 AM   #6334
What speedo?
Maybe too much timing?
4.5T are hot engines ;-)
My gear ratio is in range 87 / (21-23) at 48p for 4.5, 5.5T, 8Tdelta or 9Tdelta. Just correcting boost
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-25-2012, 04:54 AM   #6335
Originally Posted by M.Abramowicz View Post
What speedo?
m.
Speedo is lrp sxx TC spec v1, timing set at default #4(#4-#6 is for touring show in manual)
Old 03-25-2012, 05:01 AM   #6336
AM03GT's Avatar
Dont know if the mod motors are like the stock.ones but ntthe LRP x12's can run fast and reliable into the 200F range...
my question,
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 03-25-2012, 05:19 AM   #6337
set boost feel to 1, all "timing" optioons to LOW walue
I'm happy that I do not drive lrp
thank you
m.
Michal Abramowicz
Old 03-25-2012, 08:52 AM   #6338
Big Features's Avatar
What timing insert are you using? You may need less timing and more gear.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 03-25-2012, 10:56 AM   #6339
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Best place for parts (online)
Hey guys need to grab some extra parts (castor, c hubs....) want to order online my local is very limited on parts.....
Best price and shipping?
Thanks guys!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-25-2012, 01:19 PM   #6340
Thanks guys!
You try this place, http://www.hobbysuperstore.com/browse.cfm/2,6.html, I've been there and it seems to have a decent selection...not sure on tc6/6.1 stuff. Its probably 30 mins or less from Miramar if you take 95 to 595...
This place, http://www.superiorhobbies.com/ has alot of tc6 stuff, its in Orlando if your looking to get something shipped locally.
Otherwise I just go with amain .... http://www.amainhobbies.com/advanced...ds=tc6&x=7&y=4.
ChampRC is offline   Reply With Quote
Old 03-25-2012, 01:24 PM   #6341
Yeah i know of Warricks, but they some times lack the selection and with gas the way it is its like cheaper to ship and buy bulk! lol
I am a true amain fan.....has any one tried associated warehouse?
Old 03-25-2012, 02:31 PM   #6342
Trader Rating: 38 (100%+)
Thanks guys!
Ask your local hobby shop to order them for you. Won't have yo pay shipping and support them.
or8ital is offline   Reply With Quote
Old 03-25-2012, 07:51 PM   #6343
do you mean motor timing? i don play with that at all, it's all default from lrp. By the way, after i try to adjust a bit from my gearing, the temp has been drop to around 7x-8x degree at the moment, may be i will try to adjust 1 or 2 more teeth on next time after i try for few days.
my gear ratio was 9.16 (87spur, 19pinion), now i add 1 teeth for pinion from 19 to 20, and gear ratio at the moment is 8.7, it's getting good on the temperature, i will monitor it and try to add 1 more teeth and see how it's go.
Old 03-26-2012, 01:26 AM   #6344
daleburr's Avatar
my question,
LRP X12 is okay upto an external temperature of 100degC. So if you're in the 80s or 90s I wouldn't worry about it.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-26-2012, 12:12 PM   #6345
JustWill75's Avatar
Send a message via AIM to JustWill75
I currently race with a TC6 in VTA and was wondering do I have to convert it to a TC6.1 before I can use DCJ'S? Im thinking about using the hotbodies or soon to be released Reflex racing ones.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
