Like Tree1Likes
Old 03-23-2012, 08:54 AM   #6316
Rick Hohwart's Avatar
No matter how you retain your battery, it must drop in easily and be allowed to move around a bit. Too tight may cause a chassis tweak.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 03-23-2012, 09:44 AM   #6317
daleburr's Avatar
Originally Posted by Rick Hohwart View Post
I have just posted the following:
Olly Jefferies - Cotswold UK Testing
Holy soft-setup batman ! Green springs, 30wt oil and A3 mounts all round. Maybe I can find some 6.1 drivers to sell my green springs to...
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is online now   Reply With Quote
Old 03-23-2012, 10:11 AM   #6318
What is the new bulkhead clamp listed on hebert's setup?
Kyle GSR is offline   Reply With Quote
Old 03-23-2012, 11:12 AM   #6319
Rick - I always use a couple of strips of double sided tape on the bottom of the battery so it wont slide around then tape it in with a strap. Would this cause a lot of tweak?
wcalaker is offline   Reply With Quote
Old 03-23-2012, 11:21 AM   #6320
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
it has freedom to move a couple of mm
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-23-2012, 12:30 PM   #6321
jirish617's Avatar
Trader Rating: 20 (100%+)
hey guys, new guy here, well to on-road atleast. Im lookin into trying my hand in it, and i've always owned AE so thats what i'll be buying. Sorry if you guys get the question alot, but what are the difference from 6 and 6.1, money is a big factor so I was thinking just getting a t6 for cost reasons, unless the 6.1 is that much better. My other question is, for both the t6 and t6.1, what are reasonable prices on used rollers, so I have an idea what a fair price range was.
Associated SC10B.2
Losi Mini 8ight
Associated B4.1
Leisure Hours Raceway
jirish617 is offline   Reply With Quote
Old 03-23-2012, 12:38 PM   #6322
geeunit1014's Avatar
The bulkhead clamps had vertical ballstud adjustments. If you read his settings, it only makes sense w/ vertical ballstud adjustments
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-23-2012, 12:52 PM   #6323
Geberit's Avatar
You mean something like this?
Geberit is offline   Reply With Quote
Old 03-23-2012, 03:24 PM   #6324
Originally Posted by grippgoat View Post
Check your droop to make sure it's even. Also, try 3* of toe, or maybe even more.
-Mike
Droop screw settings are fine. It's only when the car is going straight and I suddenly punch the throttle that the car hooks sharply to the left. I'll try running more rear toe and see how that works out.
MySlowZ is offline   Reply With Quote
Old 03-23-2012, 04:12 PM   #6325
Yes, that kind of idea basically
Mike Gee
Old 03-23-2012, 04:27 PM   #6326
Chief's Avatar
Trader Rating: 14 (100%+)
Questions?? Screws
Are these screws an upgrade anywhere for the tc6? These were included in a used kit I purchased.
ProTek R/C 2.5x16mm "High Strength" Socket Head Cap Screws (10)
[PTK-H-1105]
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 03-23-2012, 05:23 PM   #6327
LasagnaCat's Avatar
Trader Rating: 140 (100%+)
Send a message via AIM to LasagnaCat
[PTK-H-1105]
Little on the long side, but most likely purchased for the spur gear shaft.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 03-24-2012, 05:45 PM   #6328
R1wurks's Avatar
Originally Posted by R1wurks View Post
more tc6 dcj testing in action. click on the picture to play the video
r1wurks.com
r1wurks at gmail.com
R1wurks is offline   Reply With Quote
Old 03-24-2012, 06:09 PM   #6329
Trader Rating: 49 (100%+)
What is this white c-hub I see?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 03-24-2012, 06:15 PM   #6330
Nice product!
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
