Old 03-18-2012, 07:36 PM   #6256
HenryC's Avatar
Learned my lesson today. I have been out of racing for over 20 years. I have had my TC6.1 built for a month now but my schedule has not allowed me to get out to the track yet. So I took it to a vacant parking lot today to run it a little. It only took a few minutes for it to start making a loud rasping noise, kind of like a playing card in bicycle spokes. Took it back home to find small rocks stuck in both the front and rear belt pullies and the spur gear ruined. I guess touring cars are just not meant for anything but a prepared track. I do not remember my old 1/12th or 1/10th scale pan cars being so sensitive to debris.
Hopefully I will get to the track next weekend.
HenryC is offline   Reply With Quote
Old 03-18-2012, 07:49 PM   #6257
Losiho's Avatar
Test / practice sessions, imo, are really dangerous. Our track has an open practice session before entries are taken, and I see so many bad accidents and damage to cars during practice, simply because there are so many cars on track, and drivers on the stand who have different driving ability / standards.
I honestly avoid it if possible.
Losiho is offline   Reply With Quote
Old 03-18-2012, 07:51 PM   #6258
Trader Rating: 38 (100%+)
What adjustment would I make to keep my chassis from rubbing on the sides?
or8ital is offline   Reply With Quote
Old 03-19-2012, 01:24 AM   #6259
SlideMasteR's Avatar
Questions?? DCJ's
I have seen a few guys posting that they have fitted the HB DCJ's in the TC6.1's but they are really expensive, does anyone know if the Tamiya 44mm DCJ's will fit ?
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 03-19-2012, 08:12 AM   #6260
Raise the ride height, 5mm front , 5.5 rear.
Shortbusallstar is offline   Reply With Quote
Old 03-19-2012, 08:20 AM   #6261
What other adjustment. That is already the RH I'm running.
Old 03-19-2012, 09:03 AM   #6262
That's a pretty general question.
If you could share your setup with us it would be much easier to answer.
Josh Hohnstein is offline   Reply With Quote
Old 03-19-2012, 09:58 AM   #6263
It was meant to be more of a general "what influences that" type question. But I am running mostly this setup but with the roll center changed to 3A:
http://www.petitrc.com/reglages/asso...RC20111123.pdf
Old 03-19-2012, 10:00 AM   #6264
cwoods34's Avatar
Add or go thicker on the swaybars, and try running less droop all around. Those seem to make the biggest difference to me (besides ride height, of course)!
Did you race last Sunday at RCAR? I'm not good with screennames to faces bring the car over next time you're in town and we'll take a look!
Edit: The setup sheet loads blank on my phone.... sorry!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 03-19-2012, 10:07 AM   #6265
I didn't. Wu and I should be there this weekend if I can fight whatever I'm sick with. You don't need to recognize my face. Just look for the Tamiya blue muchmore bling and fancy pit board.
I've never been much of a swaybar person. Perhaps I will try it.
I was also running a pretty heavy body which I've switched out. Wonder if perhaps that was making me a bit top heavy and causing it to roll more?
Old 03-19-2012, 10:37 AM   #6266
Wow, I have never been able to get my car to drag with those shock locations.
A lightweight body will help a lot.
A wider track width will help also (shims on bulkhead) I see bob is just running offset mounts with no shims on that setup.
Old 03-19-2012, 11:12 AM   #6267
cwoods34's Avatar
I always run swaybars at RCAR. With our size and typical layout they help a lot. On my TC6 I run silver front/black rear (1.45?/1.2).... for both 17.5 and mod. On my Serpent currently running 17.5 duties I also use 1.4/1.2 sways.
A heavy body will also cause those issues. I think I remember you ran an NSX? I DEFINITELY remember the F1 style pit board! Most of those bodies used in GT weigh 90-115g painted.... Weigh yours and see!
Old 03-19-2012, 12:39 PM   #6268
Was running the HSV-010 body with the big plastic wing. 157g!! Got the 350z and it is 30g lighter.
Old 03-19-2012, 12:51 PM   #6269
cwoods34's Avatar
Yeah, 157 is a bit much! What paint did you use? If you like the white bodies a couple coats of Sprint White works great without adding a lot, plus it seems to be the most durable (from rattlecans).... I back any bodies I do myself with it.
Old 03-19-2012, 12:57 PM   #6270
Yeah the pactra white is what I used. It's a tamiya body and I think their lexan is a bit thicker. Plus it had a ton of stickers and the plastic that goes down the back of the body. I'll run with the new body before making adjustments. Not too worried about it on the carpet. Just wanted to know in case I need to make adjustment for asphalt.
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
