Like Tree1Likes
Old 03-14-2012, 04:04 PM   #6211
Originally Posted by briankstan View Post
I'm running the Kimbrough spurs
I also like the Team Epic 64p pinions
Kimbrough I can get my hands on in Europe.
When using 75 teeth 48DP can I use pinions between 28DP and 36DP?
I mean these values are not in the gear charts in the manual on page 29.
Team Epic 48DP pinions not happening over here. Alternatives?
My starting point needs to be an FDR of 4.5 (not in the gear charts). From there on I got to test for lower or higher FDR.
Kensei is offline   Reply With Quote
Old 03-14-2012, 04:15 PM   #6212
Originally Posted by Edwin Pibal View Post
i use rw racing ones, as i found the 3 racing ones too wide and had to sand them down to make it fit.
dont know where to get them o nthe net as i buy them locally here in New Zealand
You means these?
http://www.rc-direct.co.uk/-c-60_169.html
And these pinions would do ok?
http://www.rc-direct.co.uk/-c-60_50.html
Old 03-14-2012, 04:17 PM   #6213
bvoltz's Avatar
Trader Rating: 44 (100%+)
Give this a look at: Gear Combos
bvoltz is offline   Reply With Quote
Old 03-14-2012, 04:20 PM   #6214
Very handy!
Thanks.
But do I have to worry about the colours.
I am in the red area.
That would be a "no-go"?
Old 03-14-2012, 08:15 PM   #6215
WillD's Avatar
The Kawada spurs are also a perfect fit.........i'm running a 70t 48p Kawada on mine
WillD is offline   Reply With Quote
Old 03-15-2012, 01:25 AM   #6216
thats them!
Ed
Edwin Pibal is offline   Reply With Quote
Old 03-15-2012, 02:28 AM   #6217
Very handy!
Thanks.
Could you guys please look at this gear chart and advise me if the "red area" is a go or no-go.
Old 03-15-2012, 02:48 AM   #6218
I think the colours have no meaning, although it depends on the motor you use of course.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 03-15-2012, 02:54 AM   #6219
double post. sorry
Team AME/ORCA
Old 03-15-2012, 03:10 AM   #6220
SpeedPassion 13.5t MMM
At the moment I, as you, don't know for sure what the meaning of the colours is. I thought they are there for a reason. Also because "the red area" in the gear chart is not printed in the gear chart in the manual of the car.
So I hope someone knows for sure. If not, the car is going down the drain and I'm gonna buy me another brand. Most likely the T3'12.
Old 03-15-2012, 03:57 AM   #6221
Chaz955i's Avatar
I think the colors just correspond to the first number in the overall gear ratio until it gets to 7 and above where they are grouped together. In this case the red section covers ratios 4.0-4.98.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 03-15-2012, 04:31 AM   #6222
Default What spurs fit 6.1 so you can still get to motor mounts
I am just starting to get into racing at my local club (only raced once) and have to run 21.5 motor and blinking speedy. I am building a 6.1 kit at the moment but have been told the kit gear ratio is wrong for 21.5 What would be the correct pinion and spur sizes?
I have tried to put a 64 T spur and a 36 t pinion but I now i can't get to the motor mount screw as the spur covers the mounting screw hole on the motor.
Anyone had this problem before? I can't find much on this issue.
hermet is offline   Reply With Quote
Old 03-15-2012, 04:43 AM   #6223
Look at the gearchart above.
You can see that 64 spur and 36 pinion is not an option.
Old 03-15-2012, 04:50 AM   #6224
Chaz maybe right, it looks like colours correspond to a group of ratio.
Team AME/ORCA
Old 03-15-2012, 05:12 AM   #6225
cwoods34's Avatar
I think the biggest you could run is 100/53, to give you a 3.84? (around what we gear for 21.5 here). To be safe pick up a 96 so you can go taller on the gearing if you need. The TC6 has 3 motor mount holes, so even if you don't have a spur with access holes you can use 2 screws. For mod motors I use all three!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
