Like Tree1Likes
Old 03-05-2012, 05:22 PM   #6076
LasagnaCat's Avatar
Trader Rating: 138 (100%+)
Send a message via AIM to LasagnaCat
Originally Posted by BlackStarRacing View Post
so i should be heading over to dicks sporting goods.....not the hobby store lol..... thanks for the heads up.....
Daryl
They'll probably be marked up quite a bit at a 'real' sporting goods store.. Wal-Mart/K-Mart/etc. should have them for around ten bucks.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 03-05-2012, 05:53 PM   #6077
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default got it!
bargain stores here i come
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-05-2012, 09:30 PM   #6078
tinman79's Avatar
I had my TC6 out to the track a few weeks ago, and it was awful. Ive posted here, and Ive gone over the set up sheets on AEs website. I havent race a touring car in 9 years so all of the tuning adjustments have me a bit overwhelmed.
Im running VTA on med. bite indoor asphalt.
Ill be running a 21.5 with a FDR of 4.20 per track rules.
Even if someone jost points out which set up might work best for me, that would be a big help too.
"Whose the more foolish, the fool, or the fool who follows him?"
tinman79 is offline   Reply With Quote
Old 03-06-2012, 02:39 AM   #6079
Big Features's Avatar
Pm me your email address.
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 03-06-2012, 08:15 AM   #6080
SlideMasteR's Avatar
I would really recommend the kit setup as a base starting point, I have recently build 6 x 6.1's for guys at my local track and 2 for myself to use in our national series here is SA, first off everyone has there own driving style and what they would like the car to do on the track, and with only a few small changes from kit setup I have got all of them well settled in the new cars
what is the problem you are having with the car ?
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 03-06-2012, 08:35 AM   #6081
Infinite 12th's Avatar
Found this on the petitrc site
Thanks Arno
Infinite 12th is offline   Reply With Quote
Old 03-06-2012, 09:01 AM   #6082
JustWill75's Avatar
Send a message via AIM to JustWill75
I love my TC6, I'm not the best driver at my tracK but I do believe the TC6 is very easy to drive and very durable so it makes me look better than I am and it allows me to finish more races. I'm currently in VTA but plan on getting a second one for 17.5 blinky.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 03-06-2012, 12:37 PM   #6083
ekim628's Avatar
Did you try the kit set-up. I think for most users the kit-setup is a good starting point. What tires are you using in t VTA class?
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 03-06-2012, 12:41 PM   #6084
tinman79's Avatar
I ran the kit set up. The car was not stable down the straightaway....it would drift left and right. I had very little on power steering and way too much off power. As I would slow down to set up a turn the car would hook. Once I got back on power coming out of a turn the car would push real bad.
I had good traction on the track, the rear end would only break loose if I really hammered it(which is how I like it).
Old 03-06-2012, 12:43 PM   #6085
tinman79's Avatar
Im running the kit set up.
Im using the HPI tires the USVTA rules call for. (I got them a few months back when they were still around)
Old 03-06-2012, 01:00 PM   #6086
geeunit1014's Avatar
Assuming everything is mechanically okay on the car, you didnt happen to get the caster block inserts backwards did you? Having caster the wrong way would do something like that. If you look at your car, the top of the c hub should be tilted towards the rear of the car if they are correct.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-06-2012, 01:28 PM   #6087
Default getting a new to me used TC6
hey guys just wanted to know what are some of the ares on the car i should check for and damage or wear? What would you suggest i replace sight unseen?
Thank you for the input!
Old 03-06-2012, 01:39 PM   #6088
ekim628's Avatar
I would check Arm Hinge Pins and diff/spool blades. Sometimes the new 6.1 castor blocks crack and you wouldnt know it until you checked. Everything else on the car is solid as a rock.
Eric K.
Old 03-07-2012, 02:58 AM   #6089
I would check those caster blocks if they in the right way first and that they not cracked, second I would check the rear diff and make sure there is no binding, third make sure there is no binding on the dog bones when the suspension compresses, there have been a few post here where the guys were not running the offset blocks and had some binding issues
then check and make sure your droop screws are even by lifting the car and seeing if both wheels lift at the same time, front and back
how much toe in are you running in the rear ? straight 0 on front/rear and 0 offset rear/rear is std
Old 03-07-2012, 03:10 AM   #6090
R Doyel's Avatar
Originally Posted by heattracer View Post
HVAC, HVAC Heaters Manufacturers in India, Hopper Heaters, Hopper Heaters Manufacturers in India, Titanium Heaters, Titanium Heaters Manufacturers in India, Heat Tracers, Heat Tracers Manufacturers in India, Duct Heaters, Duct Heaters Manufacturers in India.
Any Heat Exchangers, or Direct Fired Boilers? Manufactured on India, of course.
R Doyel is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
