Like Tree1Likes
Old 03-01-2012, 05:41 PM   #6001
Hey guys,
My first time posting. Just bought an TC6.1. I have 2 questions.
1. What is the hop ups you guys recommend for this kit? will be running 8.5T brushless.
2. I realized there is not allot of spur gears available for the TC6.1 out there. So which brand will fit for the TC6.1?
Thanks for the help!!
hycinth is offline   Reply With Quote
Old 03-01-2012, 05:58 PM   #6002
Infinite 12th's Avatar
Originally Posted by hycinth View Post
Hey guys,
I use kimbrough gears. In stock I use 96
This is the most common hop up I've seen
Infinite 12th is offline   Reply With Quote
Old 03-01-2012, 08:34 PM   #6003
JustWill75's Avatar
Send a message via AIM to JustWill75
As of right now I'm driving a tc6 that I'm upgrading to a 6.1. So what 6.1 parts will I need to use the yokomo ecs shaft from Spec R
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 03-01-2012, 09:02 PM   #6004
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
Robinson racing product's spur gears fit the 6.1
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 03-02-2012, 05:26 AM   #6005
Default My tc6.1
I must work on wires but now is OK.
Team Associated TC6 Thread-421707_305228199538646_100001544063411_788219_879119028_n.jpg
Team Associated TC6 Thread-426728_305228022871997_100001544063411_788218_1443562756_n.jpg
1346g ready on RIDE ets tires.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-02-2012, 07:38 AM   #6006
durtbag's Avatar
Attachment 887295
Attachment 887296
Are you running the top deck flipped over and button heads? reason?
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 03-02-2012, 08:08 AM   #6007
Hm.
It produce better flex and also do not tweek car when screw is overtighted.
And also after inpact car back usually to flat state
Sorry for my english.
Michal Abramowicz
Old 03-02-2012, 08:28 AM   #6008
burgboyz's Avatar
Trader Rating: 70 (100%+)
Attachment 887295
Attachment 887296
What part numbers are you using for the that steering rack???
Thanks,
Jon
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 03-02-2012, 08:43 AM   #6009
Thanks,
Jon
Hi!
Its just part made from carbon like letter L.
Connected to this 2 holes just after a-arm.
I did one hole for middle there is servo mount blue part.
Servo saver is from monster truck. Trf is too soft.
Link is connected to snap which replace screw on servosaver.
All parts are non destroyed so if want test tc6 servo style I can just remove my mod.
But I prefer it, for me car easy turn into corner and also save space for electronics.
There was some movie on yt. User abrampl
Regards!
Michal Abramowicz
Old 03-02-2012, 10:14 AM   #6010
The Evicerator
Default Spec-R BD5 DCJ's
What hex adapter are you guys using with the spec r yokomo BD5 DCJ's...?
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 03-02-2012, 10:17 AM   #6011
CristianTabush's Avatar
Yokomo's will probably be your best bet.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-02-2012, 10:21 AM   #6012
The Evicerator
haha I figured but I thought I would ask just in case
Steve Weiss
Old 03-02-2012, 10:31 AM   #6013
masterhit's Avatar
Trader Rating: 15 (100%+)
I used Hotbodies thin PN 72044. It gives you a few more options for shimming at the hex that way. IIRC a 1mm shim puts you at stock hex width.
It is close at the C-hub but I did not have to grind once shimmed under the hex pin.
I spent last practice abusing them with a boosted 5.5 on carpet and no issues.
Mike Slaughter
masterhit is offline   Reply With Quote
Old 03-02-2012, 10:42 AM   #6014
Hi
How do you guys cut the top deck?
Any pictures pls!?
zzztech is offline   Reply With Quote
Old 03-02-2012, 11:43 AM   #6015
Redwood's Avatar
Originally Posted by or8ital View Post
Tamiya sells all sorts of shims of various sizes. I think those are 4mm pins (you'll need to measure to verify). Here is an example:
http://www.rcmart.com/rc-washer-tami...m-p-18082.html
Originally Posted by Big Features View Post
Neal, to remove outer hinge pin slop drill a hole in the bottom of the hub and use a set screw to secure it.
For the inner pins, use 12R5 bulkhead shims for width (6.1 offset blocks help too) and ballstud washers for wheelbase.
This is what me and the majority of the AE team drivers use with great results. Hope this helps.
Mike
Originally Posted by grippgoat View Post
To remove slop between the rear hub and hingepin, do the previously-mentioned drill + setscrew, or I've found that dribbling a very small amount of CA down the holes in the insert makes it grab the hinge pin. Do a small amount at a time. You may be able to put the pin through and back out very quickly before the glue sets, to make sure it won't be too tight. But you definitely want to let it dry before you do final assembly, or else you might not get it apart again. With either approach, you may have to back off the hinge pin retaining screw a hair to free up the pin in the arm and avoid binding.
If you still have forward/backward slop, your options are thin 3mm ID shims (Tamiya makes 'em, speedtech sells 'em, you can also I think get Atomic from HKS hobby or other places). Or, someone said you can loosely place the inserts into the hub, then install the hub into the arm to get them pushed in just enough, then glue them.
-Mike
Thanks for the help guys, I take it then that it is common to have the hubs rock a little in the wishbones? I didn't think it was so bad with the old parts but maybe I never noticed.
At first I thought it was because I had not glued the caster inserts into the C-Hub but that didnt help. I think the hole is just slightly too big for the shaft so the set screw or the glue option should work.
I am confident if I try the glue option I will mess it up, so I will try the set screw if I can find some, though all TC6.1 arms, hubs etc. seem to be out of stock here so maybe I will wait until I have a backup.
Thanks for the replies though, appreciated.
Regards,
Neal
Redwood is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
