Like Tree1Likes
Old 02-25-2012, 05:02 PM   #5926
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Originally Posted by littlealex View Post
i just put kyosho 500k diff oil in my front diff but it dont feel as stiff.
can anyone tell me how i can make the front diff harder to turn?
I had the same problem need to put more in it
When I opened it up it was like it was gone
I just added and now it's fine
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 02-25-2012, 07:33 PM   #5927
Infinite 12th's Avatar
Norcal Hobbies had it's first asphalt race today and it was rad
TC6 was totally dialed in the main when the traction went down about a .5 second/lap
Geared 54/96 with revtech at 1 notch back from full timing for 3.55 rollout and was pretty fast but could use little more torque
Guess I noticed that during the qualifiers it had less steering but towards the main steering for me increased so might try something during qualifying to have steering then also
Running solaris mediums. Most we're running Team Powers 36R
Wonder what I'd notice if I was running same setup with TC6.1
Will post setup if anyone wants it?
Great car
Infinite 12th is offline   Reply With Quote
Old 02-25-2012, 11:44 PM   #5928
Default Need some TC6.1 pictures?
Too much reading.....not enough pictures!
Team Associated TC6 Thread-tc6.1-feb-2011.jpg   Team Associated TC6 Thread-tc6.1-chassis.jpg
red7fifty is offline   Reply With Quote
Old 02-26-2012, 05:01 AM   #5929
i want to order som spares for my tc6.1, does the 6.1 steering block fit on the old tc6 c hub?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 02-26-2012, 09:04 AM   #5930
Default Shock pistons
Originally Posted by hobbs View Post
Thanks guys for the info.
Went to quick look at Losi site, there are 2 types of losi #56 pistons.
1) LOSA 5046 - shock pistons #56, Red (4)
2) LOSA 5341 - 10mm shock piston #56 (4)
Which one should I get??
These are both three holes pistons?
If so, what is the difference between the two?
Is there any noticable difference in the characteristics as to behaviour of the car when racing?
And same question when compared three holes with 2 holes kit #3.
I see LOSA5045/5046/5047/5048. All three holes. It gets more and more complicated.
Which ones to use? Racing on asphalt, most of the time low grip. Some tracks medium grip.
Or is it all too much of a hassle and just go with the kit #3(3/64")?
What brand pinions and spurs best to use on the 6.1?
Preferably supplied from Hong Kong.
Kensei is offline   Reply With Quote
Old 02-26-2012, 09:49 AM   #5931
Maybell's Avatar
LOSA5046 are the correct ones.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 02-26-2012, 10:13 AM   #5932
X14
Thumbs up
Great car
Please post setup ... great help
X14 is offline   Reply With Quote
Old 02-26-2012, 11:00 AM   #5933
Big Features's Avatar
Nice! Foam tire racing! I do miss stock foam....
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 02-26-2012, 01:29 PM   #5934
17.5 blinky setup
It was totally dialed in the main. Not really sure how my motor compared to the two leaders but one of them said I was catching them. Unfortunately I got too far back early on to dice it out with them but a 3rd place finish with a bunch of great 17.5 racers was fine for me first time out racing sedan in 8 years
Can't wait to run mod in the near future
I will try the Team Powers 36R tires next time to see how they do since they are the Reedy tires.
Later
Old 02-26-2012, 01:46 PM   #5935
Default Pinions
http://www.rc-mushroom.com/advanced_...ort=1a&page=11
Do these fit for TC6/TC6.1?
Old 02-26-2012, 02:36 PM   #5936
FYI, It seems like Tamiya x-rings don't seal the tc6 dampers properly. On the bench, it felt like they were getting air in them immediately. I threw some blue schui orings in there, and it seems much better.
-Mike
Old 02-26-2012, 02:48 PM   #5937
Maybell's Avatar
Originally Posted by Kensei View Post
Those should work fine. If you have a spur/pinion alignment issue, you will have to cut the motor shafts flat-spot back a little.
Old 02-26-2012, 02:49 PM   #5938
Originally Posted by Maybell View Post
Those should work fine. If you have a spur/pinion alignment issue, you will have to cut the motor shaft flat-spot back a little.
lol...I actually didn't even notice that the flat spot wasn't far back enough but pinion didn't slip ...lol
Old 02-26-2012, 06:32 PM   #5939
BMenard17's Avatar
Trader Rating: 88 (99%+)
Is the ballast weight kit stackable? I need to reach a 1550g weight for VTA so Ill need two sets.
https://www.ssl-stormerhobbies.com/c...ns&pn=ASC31296
Tekno R/C-Sweep racing tires-Rc addiction products
Lead finger racing-Hobbico-OS engines-Futaba-Odonnell
BMenard17 is offline   Reply With Quote
Old 02-26-2012, 06:49 PM   #5940
cocojam's Avatar
Trader Rating: 47 (100%+)
Im using the Zeppin pinions on my TC6 and they work just fine but flattening the motor shafts helps in giving more clearance from the belts.
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
