Like Tree1Likes
Old 02-20-2012, 01:01 PM   #5851
Trader Rating: 38 (100%+)
Originally Posted by cwoods34 View Post
My car was 30g light on the electronics side....
"light" when it comes to balance isn't measured in weight. It all just depends where you put the weight. Slide all your electronics out and you'll be balanced.
or8ital is offline   Reply With Quote
Old 02-20-2012, 01:14 PM   #5852
6000mah Revtech battery.....
KO short servo, micro RX, Cirtix speedo, Revtech motor, and Reflex fan mount other side..... I bolted on a 30g XRAY weight behind the servo and it balanced almost perfectly!
But how much does your car weigh? I thinking getting balanced with a heavy battery, light electronics, and normal weight body at 1350g could be a challenge.
-Mike
Old 02-20-2012, 01:25 PM   #5853
just built my tc6.1, and i got some questions..
1: there is alot of sloop in the c hubs and rear hubs, seems like the hingepin is a tad too small, has anyone else noticed it?
2: i filled the rear diff with 30wt oil, and its really loose, is it supposed to be that? (my previous sakura had far tighter diffs, but they werent the best..) the tc6 diff is by far the best diff i have ever built, just sanded the gears a little to get the back of them smoooth, its smooth! no run in required, nice!
i`m quite new to gear diffs, last time i raced for real was 8 years ago
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 02-20-2012, 01:32 PM   #5854
Yes. For the front, you can go back to TC5 caster blocks.
However, I found that when I glued the inserts in, and also dribbled a tiny bit of CA down the inside of the hinge pin hole in the c-hub and rear hub, it took pretty much all the slop out. It does mean that the hub will grip the hinge pin a bit, so you need to make sure the pin is turning freely in the arm. I had to back off the hinge pin retaining screws a hair (1/8 - 1/4 turn maybe) to make sure things were moving freely.
I don't think you're supposed to sand the gears. That might be your problem.
When I built mine, I didn't sand because the instructions didn't say to. It was fairly notchy, but as soon as I put the car down and ran it for a couple minutes, it completely smoothed out.
-Mike
Old 02-20-2012, 01:51 PM   #5855
cwoods34's Avatar
The ESC and RX were at the edge of the chassis.... so yes, 30g literally did balance it out
Car with 2 gear diffs and a regular painted body was just a hair over 1400 (SpecR diffs). Front spool and liteweight body would go under 1380....
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-20-2012, 01:52 PM   #5856
just sanded each gear for 4 seconds with 1000grit paper so that cant be bad, just took of some flashing from the rear
Old 02-20-2012, 01:55 PM   #5857
The weight transfers back to front also..........so in theory you want equal weight side to side so it transfers equal front to back.
Josh Hohnstein is offline   Reply With Quote
Old 02-20-2012, 02:16 PM   #5858
cwoods34's Avatar
I would rather the gears go in smoothed by hand then have them "forced" to smooth out by running it on the track. I have built numerous gear diffs of 4 different brands and I did the same to every plastic gear - lightly sanded the back with a fine-grit.
Old 02-20-2012, 03:29 PM   #5859
was looking into getting a tc6 or 6.1 can a tc6 be converted over,my guess is yes. would it be worth it or would i be better off with the tc6 to start with. if i got the tc6 id probly look for a used on and convert it as parts broke,or needed replacing.
crash666 is offline   Reply With Quote
Old 02-20-2012, 03:51 PM   #5860
True but then the front / back weight itself comes into play then too. Obviously the battery side is much more consistent front to back then the servo/motor side.
Always a challenge balancing a car I guess.
Old 02-20-2012, 05:30 PM   #5861
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
The XRAY steering setup is 302506, and the Serpent servo mount is 401369.
I removed the front battery brace and just cut a tape slot.... I don't like velcro straps anyway, and I've NEVER had the battery come loose using tape.
I recently built 3 of these cars and tested them all from bench to track and I was very impressed with all of them
What is the advantage of this steering set up
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 02-20-2012, 06:03 PM   #5862
d2dap636's Avatar
A tc6 can be converted to a 6.1 as all parts are compatable but if you are gonna get serious it makes more sense getting the 6.1. The upgrades far out weigh the small price difference. Also, I find it very helpful in building my kit when getting something new or different.
Shut the door Brian, you're letting out all the stink! E-Revo Brushless Edition, Kyosho Inferno VE race spec, Losi Speed nt, Jammin SCRT 10, Team Associated TC3 VTA, Team Associated FT TC6
d2dap636 is offline   Reply With Quote
Old 02-20-2012, 06:16 PM   #5863
RahjahDat's Avatar
Trader Rating: 101 (98%+)
Default gotta
gotta get me one of these...
RahjahDat is offline   Reply With Quote
Old 02-20-2012, 07:01 PM   #5864
cwoods34's Avatar
It felt smoother to me, allows more room for electronics, and depending on the servo it balances easier (for me, anyway). Plus it allows more flex of the upper deck.
Old 02-20-2012, 07:09 PM   #5865
Suspended
Ok I can see how all that would work very nicely done
Are you as crafty with avatars I need to switch my serpent logo
To the AE logo cause one of those 3cars was mine lol
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
