Like Tree1Likes
Old 02-19-2012, 01:42 PM   #5836
Geberit's Avatar
Originally Posted by HenryC View Post
I tried that but it will not do the trick. The slots in the spur gear hub will only allow the spur gear pulley to go down so far. In order to get the spur gear pulley to seat farther down, you will have to grind the slots in the spur gear hub deeper.
I hoping somebody with more experience will let us know if leaving the shims out will become an issue.
Henry
Never used the shims and never had any problems.
Regards
Geberit is offline   Reply With Quote
Old 02-19-2012, 05:25 PM   #5837
Jochim_18's Avatar
Originally Posted by cwoods34 View Post
The XRAY steering setup is 302506, and the Serpent servo mount is 401369.
I removed the front battery brace and just cut a tape slot.... I don't like velcro straps anyway, and I've NEVER had the battery come loose using tape.
Tried my mod dual steering bellcrank but I use the tamiya 416 setup... It was a night in day difference the car was so easy to drive and more predictable... The car was on the rail...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-19-2012, 05:46 PM   #5838
cwoods34's Avatar
It also let me experiment with cutting the topdeck for added flex, which made a BIG difference on our low/sometimes medium bite carpet
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-19-2012, 06:18 PM   #5839
LOSI123's Avatar
Trader Rating: 63 (100%+)
With a 310g lipo and regular weight body and rubber tyres is it easy for this car in stock form to acheive 1350 grams? with a tekin rs esc.
Just approx opinions are fine.....
LOSI123 is offline   Reply With Quote
Old 02-19-2012, 06:48 PM   #5840
Mine was 1360ish with Viper VTX10 (about 47g, 20 more than TekinRS), TP 5300/65c (310-315g), and savox 1251mg (only about 47g?). And LW speed 6. So, I think you'll be close with the full weight body, depending on servo, but you might need a bit more like Ti or aluminum screws.
-Mike
Old 02-20-2012, 12:17 AM   #5841
LOSI123's Avatar
thanks
Old 02-20-2012, 12:34 AM   #5842
thanks
The other thing is balance. I was about 20g heavy on the battery side, so you might be even more so.
-Mike
Old 02-20-2012, 07:43 AM   #5843
Trader Rating: 38 (100%+)
What, if any, are the benefits of running the offset arm mounts versus using shims? Just the need for less shims?
or8ital is offline   Reply With Quote
Old 02-20-2012, 08:03 AM   #5844
AE-Reedy
Yes less shims and shorter screws.
Sean Cochran is offline   Reply With Quote
Old 02-20-2012, 08:28 AM   #5845
Ciao to all,
i'll like to know if anybody has to suggest me a tc6 asphalt setup with 2 caster block.
Tnks in advance
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 02-20-2012, 08:47 AM   #5846
R Doyel's Avatar
Default 6.1 Parts
Does anyone know when Associated is going to release replacement parts for the 6.1? I've been following this thread since I bought it, and haven't noticed a conversation about it. I broke a couple parts the first time out, and haven't been able to drive it since.
Seems silly that AE would release a car that cannot be repaired
R Doyel is offline   Reply With Quote
Old 02-20-2012, 08:50 AM   #5847
If I had to guess, most of the parts shortage has to do with the fact that AE probably didn't anticipate existing TC6 buying up all the spares to convert their cars to 6.1 spec. I could be wrong, though..
Serzoni is offline   Reply With Quote
Old 02-20-2012, 09:06 AM   #5848
cwoods34's Avatar
-Mike
My car was 30g light on the electronics side....
6000mah Revtech battery.....
KO short servo, micro RX, Cirtix speedo, Revtech motor, and Reflex fan mount other side..... I bolted on a 30g XRAY weight behind the servo and it balanced almost perfectly!
Old 02-20-2012, 11:50 AM   #5849
evochick's Avatar
The only spare part i havnt been able to find is rear hubs. But everything else is available if you do some googleing.
Also 6 caster hubs can be used if you cant find 6.1 ones.
Beth
UnRetired
evochick is offline   Reply With Quote
Old 02-20-2012, 12:19 PM   #5850
R Doyel's Avatar
Beth
I haven't been able to find Rear A arms.
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
