Like Tree1Likes
Old 02-17-2012, 01:51 PM   #5821
Chief's Avatar
Trader Rating: 14 (100%+)
Originally Posted by cwoods34 View Post
Yes, I can post them later when I get on the desktop. I just pulled the electronics out, but I'll see if I have a good older pic with electronics, also!
I too would like to see this mod. Anyone have the part numbers for this?
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 02-17-2012, 02:00 PM   #5822
kghills's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Bappe View Post
What would be a good starting setup on low/medium traction carpet running sorex 28 tires?
Jason runs this setup on his TC6 low to med bite carpet 17.5 blinky Sweep 30 Kitty Rug tires.
http://www.teamassociated.com/pdf/ca...iicss_2011.pdf
Keith.
Jason's dad
Check out Jason's video http://www.youtube.com/watch?v=eU2jqOnhJ9E
Photos: http://s816.photobucket.com/albums/zz90/kghills/Jason%20Hills%20RC/
Thanks to Team Associated and Reedy for their support.
kghills is offline   Reply With Quote
Old 02-17-2012, 10:14 PM   #5823
For mounting bodies, are you guys trimming the bumper back to let the body wheel wells center on the axles? My mazdaspeed 6 is like 5mm forward, and the 37 I was gonna try would be even farther forward.
-Mike
Old 02-17-2012, 11:26 PM   #5824
Had a blast today with my TC6.1, dialed my set up in for my local track - Tarmac - medium grip and lots of sharp corners. I started with stock kit settings but found the car oversteered too easily. So i Moved the rear shock mounts inside 1 hole on both arm and tower then made both front and rear ride height ~6mm (bumpy track).
Anyhow this is the damage i did today to the car. Destroyed an old body shell and smashed the C-Hub.
Forgetful_Duck is offline   Reply With Quote
Old 02-18-2012, 10:46 AM   #5825
cwoods34's Avatar
The XRAY steering setup is 302506, and the Serpent servo mount is 401369.
I removed the front battery brace and just cut a tape slot.... I don't like velcro straps anyway, and I've NEVER had the battery come loose using tape.
Team Associated TC6 Thread-tc6steering.jpg   Team Associated TC6 Thread-tc6steering2.jpg   Team Associated TC6 Thread-tc6steering3.jpg
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-18-2012, 02:42 PM   #5826
piper48
Guest
Posts: n/a
Default Losi #57 pistons
I know most of you run the Reflex pistons or the stock #2's that come with the kit, but I've also heard others running the Losi #57's. What's the reason and advantages for running the Losi #57 over the stock #2's? If running the #57, do you couple them with different spring combo? We have a temp track 100x60 CRC ozite med to high grip that I would like to try the #57's on but I don't want to spend the day testing it since the track is temporary. Any constructive input would be much appreciated.
Old 02-18-2012, 02:46 PM   #5827
cwoods34's Avatar
The 57 is just better quality and fits perfect compared to the stock Associated piece. You can't go wrong running that or the Reflex piston!
Old 02-18-2012, 03:08 PM   #5828
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Speedtech Stealth Edition in all black! "Black is better!"
http://www.speedtechrc.com/store/ebp...l.asp?id=12410
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-18-2012, 03:10 PM   #5829
GreenSC10's Avatar
Default Hanger 30 Battle
Great race between the TC6.1 and the Awesomatix, check it out.
http://www.youtube.com/watch?v=BZe721lnSrk
Green FT RC8.2e
GreenSC10 is offline   Reply With Quote
Old 02-18-2012, 06:17 PM   #5830
HenryC's Avatar
Default Spur gear shaft question
Building a TC6.1. Noticed that when building the spur gear shaft assembly, if I include the shims between the bearing and the C clip, the resulting assembly does not spin freely. If I leave out the shims it seems OK. Anyone else experience this?
Thanks,
Henry
HenryC is offline   Reply With Quote
Old 02-18-2012, 06:36 PM   #5831
Trader Rating: 38 (100%+)
Thanks,
Henry
Yes. Experienced the exact same thing. Just left them out. Assume it won't be a problem.
or8ital is offline   Reply With Quote
Old 02-18-2012, 06:40 PM   #5832
Chief's Avatar
Thanks. I will have to look into this.
____________
TC6
B4.1
FT SC10
Old 02-19-2012, 06:57 AM   #5833
Question is: how this mod for steering made you faster?
Regards!
Michal
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-19-2012, 10:55 AM   #5834
cherokee95's Avatar
Thanks,
Henry
I was just going to do a search, I noticed the same thing. I think I'm going to sand the inside of the pulleys to make them a little narrower. Looks like the outer bearing race could rub on the e-clip if the shims are not used.
Sioux Falls RC Crawlers
*Futaba*Hitec*Savox*Tekin*Castle Creations*i-Charger*Team Brood*Holmes Hobbies*
~Axial~Tamiya~Locked Up RC~RC4WD~Rogue Element~
cherokee95 is offline   Reply With Quote
Old 02-19-2012, 11:20 AM   #5835
HenryC's Avatar
I tried that but it will not do the trick. The slots in the spur gear hub will only allow the spur gear pulley to go down so far. In order to get the spur gear pulley to seat farther down, you will have to grind the slots in the spur gear hub deeper.
I hoping somebody with more experience will let us know if leaving the shims out will become an issue.
Henry
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
