Like Tree1Likes
Old 02-15-2012, 01:12 PM   #5791
Originally Posted by ChampRC View Post
Anyone one know of any other short shaft pinions they have tried that give significant distance from the belt?
I'm using a Kawada pinion and didn't notice any fitment issues, but I wasn't looking super closely. I put it on backwards so the gear is towards the motor, and the screw is toward the battery.
Is it really the pinion that's hitting the belt, or just the set screw? I've got some Robinson pinions but haven't tried them in the TC6, so I don't know exactly what the problem people are facing is.
-Mike
Old 02-15-2012, 01:25 PM   #5792
Would it be possible to use one 1* insert and one 0* insert on the rear upright to achieve 0.5* of toe? That might also have the side effect of making the hub grip the hinge pin a bit better and reduce slop.
-Mike
Old 02-15-2012, 03:57 PM   #5793
cwoods34's Avatar
-Mike
On most of my black pinions (variety of brands) the set screw clips the teeth of the belt. There are a few where the body itself of the pinion rubs. Even if the friction is miniscule, it's still friction. Possible heat from the rubbing could damage the belt, also.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-15-2012, 04:06 PM   #5794
Team Grid RC's Avatar
Are people using AE pinions? If anything else, they should work.
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 02-15-2012, 05:00 PM   #5795
Can you grind down the set screw, or buy a shorter one?
-Mike
Old 02-15-2012, 06:02 PM   #5796
cwoods34's Avatar
-Mike
Sure, but even screws that are "short" tend to stick out at least a little due to the size of the rotor.
I wasn't going to bother finding the few pinions that did magically fit then either buy more or change gearing. Dremeling the rotor was a simple cure-all.....
Old 02-15-2012, 06:22 PM   #5797
Angry
-Mike
I grind the set screw. And I haven't had a problem same belt for 6 months and I race every weekend
f1o7x9 is offline   Reply With Quote
Old 02-15-2012, 06:41 PM   #5798
BMenard17's Avatar
Trader Rating: 88 (99%+)
Hey guys, Im looking at purchasing a TC6.1 to do some VTA racing. I need to know what servo to buy, I currently run savox in all my offroad stuff so which one would you recommend?
Tekno R/C-Sweep racing tires-Rc addiction products
Lead finger racing-Hobbico-OS engines-Futaba-Odonnell
BMenard17 is offline   Reply With Quote
Old 02-15-2012, 06:49 PM   #5799
We just got a quick and prompt reply back from Robinson Racing. It looks like their "Alum Pro" pinions could work well in a TC6. Only 0.340 thick which is thinner than the ones we have now.
We will order a bunch up and let you know how it works.
www.GridRC.com
Old 02-15-2012, 07:04 PM   #5800
Default LRP product problem.
dear all, pls help on this issue.
recently, i just brought the LRP firware update pc bridge link cable and trying to update my ESC to V2, but i facing the fail connection on it, pls help me on this issue.
1st of all, i plug in the LRP USB Bridge - Speedo Firmware Update + PC-Link into the computer, and it auto install the driver from window XP, after that the blue led at the bridge light up, after that i plug in the sensored cable from ESC to the bridge, and start up the LRP firware update tools v2.0.4 for pc and click connect, it pop out a instruction asking me to off the on/off switch, and unplug the batterry, after i click ok on the instruction, it start to search and take time around 15-20 seconds, and i saw the bridge light up the yellow/orange led together with the blue led at the same time, meanwhile, ESC also light up BLUE (not red, suppose to be red according to the user manual) LED, and after that it show can't establish the connection. pls help on this issue. thanks.
~Team Associated AE TC6~ Disable
~Team Associated AE TC6.1~ SOLD
~Team Associated AE TC6.1WC~ Retire
Switching to YOKOMO ~Yokomo BD7~
**Swan Radio Control Club (SRCC)**
icefish is offline   Reply With Quote
Old 02-15-2012, 07:24 PM   #5801
cocojam's Avatar
Trader Rating: 47 (100%+)
-Mike
I have a similar concern on pinions on my TC6. So far I have tried Xenon, Kawada, and Zeppin pinions mounted with the gear facing the motor and the pinion body rubs on the belt just a small bit. But as one said, its still friction, and I can notice sone uneveness on the teeth of the belt. The Zeppin pinions appear to have the thinnest body with the grub screw flushed in the body when fully tightened. This should minimize belt rubbing for the meantime until I can find the ideal pinion.
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 02-15-2012, 07:36 PM   #5802
We don't suggest running the gear towards the motor body. Reason is that during running the belt tension changes and will rub against the other end of the pinion even with the set screw flush. If you prefer it this way, a belt tensioner should be used.
The best way to deal with the various pinions on the market, is to extend the flat on the motor shaft like many racers have done with a dremel tool. Also the best way to grind the flat is to take out the rotor first.
www.GridRC.com
Old 02-15-2012, 07:38 PM   #5803
CristianTabush's Avatar
3Racing pinions have not given me any trouble on the car. I have not tried the revtech, but have run the D3. I don't know if it's the same, but I know the 3R pinions work great.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-16-2012, 03:51 AM   #5804
Paul.Spencer's Avatar
Ice fish, probably the wrong thread mate for things like this I would usually haul out the sxx threads.
Any how, to fix your problem.
Plug in the USB
Load up the updater
Press connect
Plug in the speedie
Press ok
It will connect then.
Mild to Wild RC | DeadStarRC.com |ACE Hobby Australia |
TEAM Associated TC6.1WC |Team Orion | Reedy| Sweep
TEAM Associated 12R5.2 |Team Orion| Reedy| Matrix
TEAM Associated B44.1.5 |Team Orion| Reedy| Sweep
TEAM Associated B8.2eFT |Team Orion | Reedy| Sweep
Paul.Spencer is offline   Reply With Quote
Old 02-16-2012, 04:12 AM   #5805
BMenard17's Avatar
Anyone?
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
