Like Tree1Likes
Old 02-14-2012, 07:00 PM   #5776
geeunit1014's Avatar
Originally Posted by Infinite 12th View Post
I would go to 1 and 1 for your camber link positions. Going 7 to 1 on the front should help with the buildup. I also like 1 instead of 3 in the rear, it feels more stable to me.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-14-2012, 07:07 PM   #5777
Infinite 12th's Avatar
The guy who's setup I copied runs modified and does very well
The only difference between our cars is he use 1B roll centers in the rear of both front and back end
So basically (Ft 0B, 1B),(Rr 0B, 1B) so I guess that creates anti-dive?
His car looks in comparison to mine that it drives straighter when on power
Infinite 12th is offline   Reply With Quote
Old 02-14-2012, 07:32 PM   #5778
Trader Rating: 38 (100%+)
Are you also running modified?
or8ital is offline   Reply With Quote
Old 02-14-2012, 07:52 PM   #5779
Not yet although I usually run 12th modified
I want to get used to working with sedan a little as my TC experience is not as much as 12th
Are there better setups for stock?
An better approach for 17.5?
Old 02-14-2012, 08:15 PM   #5780
kghills's Avatar
Trader Rating: 40 (100%+)
I use Keven Hebert's 17.5 Super Stock set up from the 2011 IIC on Jason's TC6.
http://www.teamassociated.com/pdf/ca...iicss_2011.pdf
17.5 Blinky class. Large medium bite carpet track for club racing using Sweep Kitty Rug tires. Just tweek your front and rear camber settings to get it to handle to your liking. On high bite carpet tracks we will run a Jaco blue or Sweep 32. Car is fast and solid.
Keith.
Jason's dad
Check out Jason's video http://www.youtube.com/watch?v=eU2jqOnhJ9E
Photos: http://s816.photobucket.com/albums/zz90/kghills/Jason%20Hills%20RC/
Thanks to Team Associated and Reedy for their support.
kghills is offline   Reply With Quote
Old 02-14-2012, 08:27 PM   #5781
mtbboy's Avatar
Anyone have any experience with the difference between hub toe in and pin angle toe in?
Is there any?
Dave
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 02-14-2012, 08:44 PM   #5782
Keith.
Thanks I'll check that out
Old 02-15-2012, 06:07 AM   #5783
Yeah generally you would run a different setup for stock vs mod.
Old 02-15-2012, 07:18 AM   #5784
Originally Posted by JamesL_71 View Post
That is going to push the motor, which is one of the heaviest items on the car aside from the batteries, outward away from the chassis centerline.
Companies like AE have done tons of R&D and design/engineering work to get the motor where it is.... I would be very carefuly making a change like that. It is going to change the balance and weight distribution of the car.
Hmm could explain some straight line issues I'm having under full power; car veers left (motor side).
Originally Posted by Steve S View Post
I had the same problem with a RevTech motor. You can use a Dremel to extend the flat on the shaft. Try not to get filings in the bearings.
Ah good to see Im not the only one that had this problem...Im a noob with dremel tools etc, what bit did you use?
Originally Posted by cwoods34 View Post
Th gold Trinity pinions seem to fit with no issues, as in no Dremeling required. Every other brand needs the flat spot extended on the rotor.
This is what I figured, my hobby shop didnt seem to have any pinions with a shorter shaft than the one I was using...
Anyone one know of any other short shaft pinions they have tried that give significant distance from the belt?
ChampRC is offline   Reply With Quote
Old 02-15-2012, 07:26 AM   #5785
bjanzen's Avatar
I had the same issue...... When i switched to a D3.... Just took a plastic bag and poked the motor shaft through. Keeps the metal shavings out of motor and bearing. Made the flat long enough that any pinion fits now.
BTW....... I just figured out why newer setups don't work. The 6.1 setups make my TC6 pushy. Just went back to the KHebert setup above and WOW! Car drives MUCH BETTER.
bjanzen is offline   Reply With Quote
Old 02-15-2012, 07:45 AM   #5786
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Which dremel bit did you use to grind the shaft?
tr1kstanc3 is offline   Reply With Quote
Old 02-15-2012, 08:38 AM   #5787
bjanzen's Avatar
Just a cut off disc...... Fiber disc..... Held at a low angle
Old 02-15-2012, 08:40 AM   #5788
Any suggestions for where I should start gearing wise for a medium sized track? I haven't had a chance to run it since i'm waiting on a couple of parts but I will be using a 10.5t motor. Currently I have the stock spur coupled with a 20 tooth pinion. Does this sound like a decent starting point?
jonu is offline   Reply With Quote
Old 02-15-2012, 09:28 AM   #5789
racing_jason's Avatar
the new set ups wont work unless you are using the new arms. the new arms provide alot more mechanical grip then the old arms do.
Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 02-15-2012, 09:32 AM   #5790
Is there any?
Dave
main thing that i find between pin toe and and hub toe is it changes the angle of shock as you shim the pin out to get your toe it moves the shock bottom out making the shock have more lean causing more side bite where the hub toe will increase forward bite and have alot less of a effect on the side bite of the car.
Thanks Jason
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
