Like Tree1Likes
Old 02-14-2012, 05:09 PM   #5761
can anyone tell me if tc6.1 cva kit compatible with tc6?
~Team Associated AE TC6~ Disable
~Team Associated AE TC6.1~ SOLD
~Team Associated AE TC6.1WC~ Retire
Switching to YOKOMO ~Yokomo BD7~
**Swan Radio Control Club (SRCC)**
icefish is offline   Reply With Quote
Old 02-14-2012, 05:24 PM   #5762
The Evicerator
Originally Posted by Infinite 12th View Post
Hi, this post got passed. If anyone could give their best answer I would appreaciate it
Also I was curious if someone could define what roll centers go in order from lowest to highest
I know the 0 is the longest but when you change holes in the bulkhead which then in that order do they become higher or lower
For instance: 0B, 1B, 2B, etc but when does the 2A and 3A come close to the same as 0B
Hope that makes sense
I just am trying to wrap my head around when to go to A with the higher roll centers from where B is as low as you can go
Regarding your post on the tire question... that's a difficult question to answer because every tire and situation is a little different.
Tell tale signs that a tire is probably "done" is when the inside edge of your fronts is visibly far more worn than the rest of the tire.
When the tire itself gets very thin that's also another sign that it's probably time to get a new set!
In certain situations these tires can still provide good lap times... but oftentimes they are less consistant than newer tires will be.
Now once those situations are out of the way is when it gets a little bit more difficult to determine when to move to a new set of tires:
Generally on carpet, tires tend to break in get better after several runs... on asphalt, this can be the exact opposite: Usually your first run or two will be the best that the tires will be...then performance will start to drop off.
There are of course, exceptions to this general guideline... and I would definately pick the brains of the local fast guys at your local tracks to try to get as much tire info for your particular track as possible.
There are certain situations on carpet or sometimes high bite indoor asphalt tracks where a tire can be "over sauced" and start to act funny... this generally only happens if you happen to run a lot of runs on the tire in a relatively short period of time... sometimes these tires can "come back" if they are left to dry out a bit... if I think this is happening I'll switch to another set of tires and keep the tires in question around to try out another day.
Hope this helps a little bit!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-14-2012, 05:27 PM   #5763
Infinite 12th's Avatar
Originally Posted by cwoods34 View Post
I don't remember the exact measurements, but the very lowest is 0A, and the very highest is 3B.
0A, 1A, 2A, 3A, 0B, 1B, 2B, 3B
The closest 2 mounts in terms of numerical difference are 3A and 0B......The common combination for pro- or anti-dive at the front is these two. I personally like 0B or 3A fronts, and 2B rears.
Hope that helps!
Thanks that is the answer I was looking for
@Steve Weiss
Thanks now I have some things to think about regarding sedan tires
Do you know however what it means when there is a bead on the outside of the tire where perhaps the rubber has been worn too
It can actually be scratched off with my finger nails
What is that...lol
I see it mostly on the fronts
Infinite 12th is offline   Reply With Quote
Old 02-14-2012, 05:29 PM   #5764
AE-Reedy
No, the axle is a different size and the bone length is different.
Sean Cochran is offline   Reply With Quote
Old 02-14-2012, 05:42 PM   #5765
The Evicerator
@Steve Weiss
What is that...lol
I assume that this is on a carpet track...? Sometimes you will get some sort of "build up" on the tire like that... I've experienced it on newer sets of tires mostly... I think it's a mixture of sauce/tire debris/and track pickup ... it can usually be removed pretty easily via finger nail or a rag/towel with some motor spray or sometimes sauce.
Steve Weiss
Old 02-14-2012, 05:48 PM   #5766
Yea carpet...lol
Old 02-14-2012, 05:58 PM   #5767
Team Grid RC's Avatar
Th gold Trinity pinions seem to fit with no issues, as in no Dremeling required. Every other brand needs the flat spot extended on the rotor.
Is anyone using the Robinson "Aluminum Pro" pinions? Robinson seems to be readily available.
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 02-14-2012, 06:05 PM   #5768
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
anyone know who has rear 6.1 arms in stock?
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 02-14-2012, 06:08 PM   #5769
mr fit's Avatar
I'm going to try the xray pinion gears. It's almost the same set up, as you adjust the set screw from the hole under the chassis.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 02-14-2012, 06:10 PM   #5770
geeunit1014's Avatar
What is that...lol
That is buildup that happens from the car rolling a lot. If you watch your car go around the track, you will probably see some corners where it looks like it hikes up the inside front tire. Depending on how your car is set up, you could try taking out some front droop, a heavier front sway bar or a shorter front camber link.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-14-2012, 06:17 PM   #5771
mr fit's Avatar
Arrowmax probably makes a set of spring steel axles. They are just as strong as the xray axles.
Old 02-14-2012, 06:36 PM   #5772
That makes sense since it's on the ft outside
I will experiment with those changes
My previous setup and first race with my TC6 was like drift car. Fun but not very fast then I made some changes after the race day and it got a lot better. Corners good with decent rear bite. Probably could use a little more over all grip
My current setup
Old 02-14-2012, 06:40 PM   #5773
My current setup
Your link is for the blank setup sheet
Mike Gee
Old 02-14-2012, 06:45 PM   #5774
Aww crap I thought I saved it...lol
brb
Old 02-14-2012, 06:53 PM   #5775
Real one...lol
http://www.datafilehost.com/download-0fb60e2c.html
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
