Like Tree1Likes
Old 02-13-2012, 11:19 PM   #5746
LOSI123's Avatar
Trader Rating: 63 (100%+)
Does the 6.1 come with 5x10 bearings in hubs as per the manual i downloaded or is this a typo?
LOSI123 is offline   Reply With Quote
Old 02-13-2012, 11:34 PM   #5747
SlideMasteR's Avatar
yes the 6.1 comes with 5x10 bearings
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 02-14-2012, 09:01 AM   #5748
Rick Hohwart's Avatar
Originally Posted by jonu View Post
So I just recently purchased one of these and am looking forward to getting it on the track. The only thing slowing me down so far was the lipo battery straps/holder was not in the kit. Currently i'm waiting on it so I can finish assembly. I'm going to be using a Spectrum dx2s with a Spectrum S6070 low profile servo. I will be using a mamba max pro with the castle creations 4 pole 4600kv motor. I'm curious where you guys would start gearing wise on a medium length asphalt course (using the stock 48 pitch spur)?
The car is designed to use strapping tape to hold the battery. A Velcro strap will work as well but tape is perfectly acceptable.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 02-14-2012, 10:12 AM   #5749
tofuburger's Avatar
Rick,
on your set up sheet you use putty for the front gear diff. can you tell what type of putty this is?
Larry "Chef LT" Tom
StickIt1Racing.com
HobbyAction.com
tofuburger is offline   Reply With Quote
Old 02-14-2012, 10:45 AM   #5750
wwddww34's Avatar
Trader Rating: 9 (91%+)
Hey all you TC6 racers, have you signed up to race your TC6 in the modified Sedan Class at the 2012 ROAR Carpet Nationals coming on March 16? Hurry up and register before time runs out! Click here to get signed up.
Click
HERE to see a countdown to the 2012 ROAR Carpet Nationals
wwddww34 is offline   Reply With Quote
Old 02-14-2012, 10:56 AM   #5751
What i meant was the plastic parts you screw to the chassis were missing. I currently have nothing to strap tape or keep the battery in position at all unless I put slots in the chassis.
jonu is offline   Reply With Quote
Old 02-14-2012, 11:45 AM   #5752
hanzo3's Avatar
Trader Rating: 55 (100%+)
There are slots to fit the strapping tape though. It is thick enough to fit the velcro strap. I use the top racing strap and it fits.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 02-14-2012, 11:48 AM   #5753
Originally Posted by tofuburger View Post
Rick,
I use this.
gotcha
www.reedypower.com
Old 02-14-2012, 12:37 PM   #5754
Questions?? Shimming motor out.
Hey guys, did anyone have to take those blue spacers and place them on the motor side instead of the motor mount side so that the pinion doesn't hit the belt?
Idk if the flat part of my motor shaft doesn't go in far enough but I actually had to do this to push my motor back alittle bit.
Could this just be an issue with the motor shaft or are there pinion gears that arent so lengthly?
I run a speed passion 17.5 sportsman series motor:
http://www.redrc.net/wp-content/uplo...assion17-5.jpg
Basically I have the spacers in between the motor and motor mount.
ChampRC is offline   Reply With Quote
Old 02-14-2012, 12:44 PM   #5755
That is going to push the motor, which is one of the heaviest items on the car aside from the batteries, outward away from the chassis centerline.
Companies like AE have done tons of R&D and design/engineering work to get the motor where it is.... I would be very carefuly making a change like that. It is going to change the balance and weight distribution of the car.
JamesL_71 is offline   Reply With Quote
Old 02-14-2012, 01:05 PM   #5756
I had the same problem with a RevTech motor. You can use a Dremel to extend the flat on the shaft. Try not to get filings in the bearings.
Steve S is offline   Reply With Quote
Old 02-14-2012, 01:22 PM   #5757
piper48
Guest
Posts: n/a
+1. I run the D3 and that's exactly what I did.
Old 02-14-2012, 04:08 PM   #5758
cwoods34's Avatar
Th gold Trinity pinions seem to fit with no issues, as in no Dremeling required. Every other brand needs the flat spot extended on the rotor.
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 02-14-2012, 04:34 PM   #5759
Infinite 12th's Avatar
Hi, this post got passed. If anyone could give their best answer I would appreaciate it
Also I was curious if someone could define what roll centers go in order from lowest to highest
I know the 0 is the longest but when you change holes in the bulkhead which then in that order do they become higher or lower
For instance: 0B, 1B, 2B, etc but when does the 2A and 3A come close to the same as 0B
Hope that makes sense
I just am trying to wrap my head around when to go to A with the higher roll centers from where B is as low as you can go
Infinite 12th is offline   Reply With Quote
Old 02-14-2012, 04:55 PM   #5760
cwoods34's Avatar
I don't remember the exact measurements, but the very lowest is 0A, and the very highest is 3B.
0A, 1A, 2A, 3A, 0B, 1B, 2B, 3B
The closest 2 mounts in terms of numerical difference are 3A and 0B......The common combination for pro- or anti-dive at the front is these two. I personally like 0B or 3A fronts, and 2B rears.
Hope that helps!
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28963 Today 05:20 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
