Like Tree1Likes
Old 02-11-2012, 07:37 PM   #5716
Infinite 12th's Avatar
So I ran a 51/96 and it was ok but apparently the motor is only like 140 so I guess I'll gear up one or two more. Could use a little more straightaway
Did some adjustments after the race and is working ok
Look forward to the next race
Blinky 17.5 Revtech motor full timing advance towards the +
Any comments ...lol
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 02-11-2012, 07:49 PM   #5717
manny021803's Avatar
I race 96/48 in my tc-6 with Blinky 17.5 Revtech motor and it work perfect in the infield like strethgway too,so i think that it depend wich track you race !!
Any comments ...lol
manny021803 is offline   Reply With Quote
Old 02-11-2012, 07:53 PM   #5718
!!!!LOL!!!! That is not come with 2 lap inside the car
Originally Posted by M.Abramowicz View Post
heh
When drive modified I just need normal bearing
Cheap ones, change each event.
Forget ceramics, they will not give you 0.1sec per lap, 0.1sec per lap give more training and learning how to set car
Regards!
Old 02-11-2012, 07:57 PM   #5719
yes i have good tips for you ,listen try to get lunch before tighten or adjust the screws
Originally Posted by grippgoat View Post
Anyone got any tips for freeing up the droop screws? Mine are super tight. It makes adjusting droop a bit of a chore. It flings the car off the blocks.
-Mike
Old 02-11-2012, 08:04 PM   #5720
geeunit1014's Avatar
Any comments ...lol
From what I have seen on the revtechs, back off the timing about 1 notch. ! from full seems to be the sweet spot on those. I would prolly go up in gear like you suggested, the guys at my track who run the revtechs run it around 3.6-3.5, even though its a small track.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-11-2012, 08:21 PM   #5721
Thanks Dude
Old 02-12-2012, 01:03 AM   #5722
Geberit's Avatar
Made some changes to get more flex.
http://www.rctech.net/forum/electric...dy-lrp-26.html
Geberit is offline   Reply With Quote
Old 02-12-2012, 06:34 AM   #5723
Big Features's Avatar
Originally Posted by burgboyz View Post
I did not make it to the Birds but I am curious what esc,motor,rotor,timing you were running. Thanks!
Bob Stellflue and I were both running an LRP stock-spec ESC with the settings::0,0,0,10.
We were also running stock reedy 17.5 sonic motors with the timing advanced up to the motor screw. This gearing seemed well suited to the track we were on.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 02-12-2012, 07:09 AM   #5724
AeRacer805's Avatar
Mike
What is the advantage of running no lipo cutoff on the ESC. I'm just curious why you would turn off the lipo cut off.
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 02-12-2012, 09:17 AM   #5725
No real reason, I guess. In my own mind it's more efficient. No cut off to worry about. I only run the battery 6 minutes at a time anyways.
Mike Kling
Old 02-12-2012, 02:52 PM   #5726
mtbboy's Avatar
Hey Guys ,
Not the right thread for this but wth.
Starting fdr for
Tc6 Blinky.
Lrp x12 17.5
110 foot straight.
Thanks.
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 02-12-2012, 03:01 PM   #5727
@Rick Howhart
Can you post your setup for the regionals
Old 02-12-2012, 03:19 PM   #5728
d2dap636's Avatar
Default spool vs slipper spool
Hey guys, I just picked up a tc6 and I'm trying to set it up, but I'm not sure what the difference between them are. What are the characteristics of each. Spool or slipper spool, what's better for asphalt 17.5 stock spec? Any info is appreciated.
Shut the door Brian, you're letting out all the stink! E-Revo Brushless Edition, Kyosho Inferno VE race spec, Losi Speed nt, Jammin SCRT 10, Team Associated TC3 VTA, Team Associated FT TC6
d2dap636 is offline   Reply With Quote
Old 02-12-2012, 04:30 PM   #5729
Originally Posted by mtbboy View Post
Hey Guys ,
Starting fdr for
Tc6 Blinky.
Lrp x12 17.5
110 foot straight.
Thanks.
Dave.
I would start with a 4.0FDR and go from there. With 110ft straight, You'll most likely end up around 3.91 or so with a 96 Spur. I would use the "...." or "..." insert and tune for about 170 degrees or so. If the car feels flat, take some of the timing out and re-gear.
Mike
Mike Kling
Old 02-12-2012, 04:32 PM   #5730
I always ran mine very tight. The main difference is that the slipper is more forgving. Instead of breaking parts, the spool "slips" and allows less fatigue on parts. The solid spool is lighter, more direct and will provide a bit more steering on-power.
Mike
Mike Kling
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
