Like Tree1Likes
Old 02-09-2012, 01:04 PM   #5686
Originally Posted by acerracing View Post
We are proud to announce the release of our Team Associated TC6.1 Factory Team kit with a full set of ACER Racing Ceramic Ball Bearings, Ceramic Differential Balls and Ceramic Thrust balls as well as a bottle of our SIN 100% synthetic bearing oil, for only $397.99! Check out our growing stock of high performance RC cars that we have bundled with the #1 performance upgrade for your ride: our Ceramic Nitride Pro Series ball bearings and diff balls.
Why does it come with diff/thrust balls, when the 6.1 comes with a gear diff?
-Mike
Old 02-09-2012, 02:59 PM   #5687
Dog Bone's Avatar
That's a huge amount of money to spend on bearings....
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 02-09-2012, 03:57 PM   #5688
Madulla's Avatar
It comes with a car Ken
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 02-09-2012, 04:06 PM   #5689
heh
When drive modified I just need normal bearing
Cheap ones, change each event.
Forget ceramics, they will not give you 0.1sec per lap, 0.1sec per lap give more training and learning how to set car
Regards!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-09-2012, 05:49 PM   #5690
AE-Reedy
Originally Posted by Steve S View Post
The instructions are a bit ambiguous as to where exactly on the arm you measure with the droop gauge, and the included gauge isn't the most precise thing in the world. That said, my best attempt to follow the kit setup gave me 2mm up-travel in the rear and 1.5mm in the front.
If you look close there is a specific flat area by the outer pin that is where you should measure droop. I don't have any arms around right now or I would photo it.
Sean Cochran is offline   Reply With Quote
Old 02-09-2012, 05:50 PM   #5691
AE-Reedy
Originally Posted by bhambrent View Post
Same here
Bring back the slipper spool!!
It never went any where!
Old 02-09-2012, 05:58 PM   #5692
AeRacer805's Avatar
+1
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 02-09-2012, 07:05 PM   #5693
Dog Bone's Avatar
D'oh, missed that . That's an all-right deal then
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Old 02-09-2012, 07:19 PM   #5694
bhambrent's Avatar
Originally Posted by AeRacer805 View Post
+1
It will not fit in a tc6.1.
bhambrent is offline   Reply With Quote
Old 02-09-2012, 09:52 PM   #5695
Suspended
Trader Rating: 86 (100%+)
i have a gear diff in front.
should i use 300k or 500k diff fluid?
putty dont seem works for me
littlealex is offline   Reply With Quote
Old 02-09-2012, 10:23 PM   #5696
The Evicerator
I've had a slipper spool fit just fine in my 6.1...
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-09-2012, 10:42 PM   #5697
SlideMasteR's Avatar
there has been no change in the bulkheads so there is no reason it shouldn't fit
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 02-10-2012, 01:15 AM   #5698
Anyone got any tips for freeing up the droop screws? Mine are super tight. It makes adjusting droop a bit of a chore. It flings the car off the blocks.
-Mike
Old 02-10-2012, 01:51 AM   #5699
piper48
Guest
Posts: n/a
Chase the threads with an M4 tap.
Old 02-10-2012, 05:37 AM   #5700
I have used kyosho 500k & it worked verry well.
Shortbusallstar is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
