Like Tree1Likes
Old 02-06-2012, 09:17 PM   #5656
stitchy's Avatar
Originally Posted by 8KCAB View Post
Does anybody know where you can get other sizes of roll bars for the 6.1? I see the roll bar set #31362 comes with more bars than the kit box did. I have found #31364, but do not know if that comes with just 4 bars (stock kit bars) or 4 pairs.
We have 31364...31362 will be here soon..
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-06-2012, 09:35 PM   #5657
roger999's Avatar
Originally Posted by icefish View Post
Roger, is that double side tape stick on the graphite low deck?
No that tape is only to protect graphite from scratches. But two weights will stop the battery from movements.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 02-06-2012, 10:26 PM   #5658
Any recommendations whether to put a 5th body post on the front or the back of the shock tower?
-Mike
Old 02-06-2012, 11:09 PM   #5659
roger999's Avatar
-Mike
Yep on the front shock tower is two holes for that.
Old 02-06-2012, 11:17 PM   #5660
Originally Posted by roger999 View Post
Yep on the front shock tower is to holes for that.
I was asking about putting it on the front vs the back side of the tower.
Also, I mounted up a speed 6. It seems to sit quite low. I put 2mm spacers under the front body posts, bit I think it will still drag. Do you guys just cut higher than the cut line?
-Mike
Old 02-06-2012, 11:29 PM   #5661
roger999's Avatar
-Mike
Ah sorry. I use back side of the tower. And never use spacers under body posts. But most guys in my club use it. Anyway cut lines are never correct and always is needed to correct cutting after first run.
Old 02-07-2012, 06:26 AM   #5662
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 152 (100%+)
My local track is putting on a little carpet race later this month and im thinking about picking up a 6.1 to race in the 17.5 boosted rubber tire class. The last time i ran carpet it was with a tc5 on foams. After reading through this thread it seems like it would be a good idea to pick up the reflex bladders and pistons (or losi pistons). I see on Hebert's latest setup he is using yokomo springs but i see that some guys here like the reflex springs too, preference? I am not aware of a specific tire that we shoud use but it looks like the popular one is the sweep qts between the major races. It looks like the Hebert setup would be a good starting point for my track, is there anything that would also be recommended? Thanks in advance!
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 02-07-2012, 06:50 AM   #5663
rc pete's Avatar
-Mike
In order to run the speed6 ROAR legal (on the upper cut line), I use the 12r5.1 posts on the front (same thing, just one hole taller), and I space those up by 1 to 2mm depending on the track and how much dive/roll I'm running in the car.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 02-07-2012, 06:59 AM   #5664
Originally Posted by inconceivable View Post
Generally speaking ... for high grip indoor asphalt, or even high bite carpet, what is the starting point most of you are going with regarding spacing the front and rear arms (track width) ? Specifically what shims are you running between the arms and the inner uprights ? Thanks !
If you are running the 6 with the old mounts you should be somewhere around 2mm per side...........if you're running the 6.1 with the offset mounts you won't need much if any shims.
I would say check the setup page on AE's website, there are quite a few setups for indoor asphalt.
I'm told the setup from Bob carries over very well to carpet.
Josh Hohnstein is offline   Reply With Quote
Old 02-07-2012, 09:22 AM   #5665
Matt-
The Reflex bladders and Pistons are Great!! i also use the springs too on some set-ups. Get an extra gear diff for the front.
Scott
-Scott Spear
Team Associated, Reedy, LRP, Proline, Winning Edge Designs, Byrons Fuel, AVID Bearings, TFR Racing. ***Team Associated Region 10 Administrator***
Scott S. is offline   Reply With Quote
Old 02-07-2012, 12:11 PM   #5666
Default Aluminum 12mm hex rc rims..
Has anyone ever used aluminum rc rims made by Dongguan Qiying Precision Hardware Products Co., Ltd.
i'm haveing trouble finding the specs on them or even some comments since i dont know any chinese folks.. look perfect for some foams, but dunno how wide the rims are.. ha anyone ever seen these or know someone that has used them before???
Trick Icarus is offline   Reply With Quote
Old 02-07-2012, 05:15 PM   #5667
AM03GT's Avatar
AL rims/wheels are for shelf queens only... unless you can drive without hitting anything... EVER... they will bend...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 02-07-2012, 06:28 PM   #5668
+ 1 on the reflex bladders, pistons and springs. Best investment you can make.
RCMAKER | BITTYDESIGN | MUCHMORE
Lionel S is offline   Reply With Quote
Old 02-07-2012, 06:48 PM   #5669
LasagnaCat's Avatar
Trader Rating: 138 (100%+)
Send a message via AIM to LasagnaCat
My two cents...
The nicest thing about the Reflex springs is that (so far) they've always been the same length right out of the pack. No more buying multiple sets of AE springs and mixing/matching to find one good set.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 02-07-2012, 09:19 PM   #5670
Hi guys!
I am a pretty experienced Nitro driver but I just entered the Electric class and bought a Team Associated TC6.1 car.
I have a question regarding the setup of the car.
According to the basic setup you should have 5mm Ride Height and 6mm Droop at the front and 5mm Droop at the rear.
If I use these settings with my Sweep 32 tyres (I don't know if different tyres have different diameter in the electric class ) then the droop screws almost touch the chassis and there is really small up-travel for the suspension.
If I lift the car the droop screws immediately touch the chassis.
Is this normal or I am doing something wrong?
Thanks a lot!
panayos is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
