Like Tree1Likes
Old 02-06-2012, 07:26 AM   #5641
JonesyCGY's Avatar
Originally Posted by Redwood View Post
The new hubs and steering blocks are similarly more rugged. The inserts to choose caster and rear hub toe are also very nice, I had my doubts but they really impressed me. The manual says to glue them in but they fit so snug that I will leave them loose, which means I may change them in future if necessary.
Regards,
Neal
Huh,
You obviously got a different kit than I did.
Did they fix the Weak C-Hubs yet and the sloppy Inserts that go into them?
Tamiya M-03R // BMI DB12RR // AE TC5R // AE TC6.1
JonesyCGY is offline   Reply With Quote
Old 02-06-2012, 08:56 AM   #5642
Redwood's Avatar
I cannot comment on strength as I have not raced the car yet but they look like there is more material on the hubs all round.
As for the inserts, mine fit very well indeed. I put one in the wrong way up and had to fight to get it back out because the fit was so close. Maybe you had a sloppier set of hubs but mine fit very well.
Regards,
Neal
Redwood is offline   Reply With Quote
Old 02-06-2012, 10:27 AM   #5643
roger999's Avatar
Originally Posted by icefish View Post
one more pic, locate on the left is my custoem DIY spacer to stop the battery moving in, right side is the factory spacer.
Here is simple solution for your problems.
Team Associated TC6 Thread-20120206_182145.jpg   Team Associated TC6 Thread-20120206_182155.jpg
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 02-06-2012, 11:53 AM   #5644
8KCAB's Avatar
Does anybody know where you can get other sizes of roll bars for the 6.1? I see the roll bar set #31362 comes with more bars than the kit box did. I have found #31364, but do not know if that comes with just 4 bars (stock kit bars) or 4 pairs.
DEX410
RC10B6
Sabre X3
8KCAB is offline   Reply With Quote
Old 02-06-2012, 02:17 PM   #5645
You can go to your local hobby shop or hardware store and look for music wire (or piano wire). It comes in small sizes in small steps, and you can cut it to length for the TC6.
-Mike
Old 02-06-2012, 03:54 PM   #5646
Maybell's Avatar
Each bar set (31364) comes with 4 pairs of bars.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 02-06-2012, 04:38 PM   #5647
inconceivable's Avatar
Generally speaking ... for high grip indoor asphalt, or even high bite carpet, what is the starting point most of you are going with regarding spacing the front and rear arms (track width) ? Specifically what shims are you running between the arms and the inner uprights ? Thanks !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 02-06-2012, 04:57 PM   #5648
Roger, is that double side tape stick on the graphite low deck?
~Team Associated AE TC6~ Disable
~Team Associated AE TC6.1~ SOLD
~Team Associated AE TC6.1WC~ Retire
Switching to YOKOMO ~Yokomo BD7~
**Swan Radio Control Club (SRCC)**
icefish is offline   Reply With Quote
Old 02-06-2012, 05:35 PM   #5649
8KCAB's Avatar
Maybell, thanks that is exactly what I was looking for.
Grippgoat, I have heard of people doing that. But I wasn't sure if the steps between each size of wire was similar to the actual set. Plus the music wire at my store is sold in bundles of 4. I don't need that much wire laying around.
DEX410
RC10B6
Sabre X3
Old 02-06-2012, 05:54 PM   #5650
piper48
Guest
Posts: n/a
Try running 1.5mm in the front on each side to give you 3mm total and none in the rear. (Thanks Kody) That reduced traction rolling on high bite carpet. I used AE 1/12 spacers.
Old 02-06-2012, 05:58 PM   #5651
Team Grid RC's Avatar
Hello TC6 and TC6.1 racers,
We will be releasing shortly upgrades and accessories for you racers.
We did some stuff for the RC8Be a year ago and this year will be doing stuff for the TC6.1 now that it is readily available.
Our support thread for the on-road is Team GRID Touring Car Performance Upgrades and Tools
And if you want to see some history on our electric off-road read it here: http://www.rctech.net/forum/electric...ts-thread.html
Our product announcements will be mostly be done on our website at www.gridrc.com
www.GridRC.com
Team Grid RC is offline   Reply With Quote
Old 02-06-2012, 06:48 PM   #5652
guys, what does they mean to buy a used car as roller? what does the roller mean?
Old 02-06-2012, 06:50 PM   #5653
8KCAB's Avatar
Generally a chassis with no electronics. Probably no tires or body either.
DEX410
RC10B6
Sabre X3
Old 02-06-2012, 08:22 PM   #5654
tofuburger's Avatar
does someone make ecs drive shafts for the tc6.1?
Larry "Chef LT" Tom
StickIt1Racing.com
HobbyAction.com
tofuburger is offline   Reply With Quote
Old 02-06-2012, 08:44 PM   #5655
cherokee95's Avatar
Reflex Racing is working on some.
Sioux Falls RC Crawlers
*Futaba*Hitec*Savox*Tekin*Castle Creations*i-Charger*Team Brood*Holmes Hobbies*
~Axial~Tamiya~Locked Up RC~RC4WD~Rogue Element~
cherokee95 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
